Tamadrummer Posted November 24, 2018 Share Posted November 24, 2018 I was good with xj’s but cannot determine suspension height with tire size on mj’s yet. I bought this as it sits now. It’s on 31’s and the coils springs look painted/newer? The truck has almost no rust on the exterior and the leaf springs are surprisingly clean looking but not brand new. I think the suspension is at stock height and want see if anyone else can verify just by pictures. Link to comment Share on other sites More sharing options...
Minuit Posted November 24, 2018 Share Posted November 24, 2018 Measure your ride height to know for sure. It looks like it has a lift in the front. Not sure on the rear. Link to comment Share on other sites More sharing options...
Eagle Posted November 24, 2018 Share Posted November 24, 2018 Those are 31s? DEFINITELY not stock height. Probably 3" to 4" lift. Link to comment Share on other sites More sharing options...
grumpiebill Posted November 25, 2018 Share Posted November 25, 2018 Looks much higher than stock to me...but as you said tough to tell from pics. I'm looking at wheel well area... I was good with xj’s but cannot determine suspension height with tire size on mj’s yet. I bought this as it sits now. It’s on 31’s and the coils springs look painted/newer? The truck has almost no rust on the exterior and the leaf springs are surprisingly clean looking but not brand new. I think the suspension is at stock height and want see if anyone else can verify just by pictures. Sent from my LG-M210 using Tapatalk Link to comment Share on other sites More sharing options...
Tamadrummer Posted November 26, 2018 Author Share Posted November 26, 2018 Measured the height from the ground to the fender and the front is sitting at 35” and the rear is at 35.5”. Can anyone out there on stock suspension and 31’s tell me their measurements?? Link to comment Share on other sites More sharing options...
Eagle Posted November 26, 2018 Share Posted November 26, 2018 11 minutes ago, Tamadrummer said: Measured the height from the ground to the fender and the front is sitting at 35” and the rear is at 35.5”. Can anyone out there on stock suspension and 31’s tell me their measurements?? Height from the ground is useless. Tire size, tire make and model, and even tire pressure and wheel width affect that. The best measurement is by following the link that Minuit provided, above. Please do that, and post back with your results. Link to comment Share on other sites More sharing options...
Eagle Posted November 26, 2018 Share Posted November 26, 2018 Your truck: Stock height: Link to comment Share on other sites More sharing options...
grumpiebill Posted November 26, 2018 Share Posted November 26, 2018 Your truck: Stock height: Does the front bumper look like it's extended out or is it just me...either the wrap around is trimmed back or the bumper is extended out maybe...Sent from my LG-M210 using Tapatalk Link to comment Share on other sites More sharing options...
grumpiebill Posted November 26, 2018 Share Posted November 26, 2018 Does the front bumper look like it's extended out or is it just me...either the wrap around is trimmed back or the bumper is extended out maybe...Sent from my LG-M210 using Tapatalk Wrap around should meet the fender wheel opening...Sent from my LG-M210 using Tapatalk Link to comment Share on other sites More sharing options...
Eagle Posted November 26, 2018 Share Posted November 26, 2018 Optical illusion. On the lifted truck, the fender and flare have been removed up to the top of the bumper. The yellow lines I added follow the line of the bottom of the rocker panels. Notice how at stock height the line cuts well into the wheels, about to the top of the center cap. On the lifted truck, the line just nicks the tops of the rims. I stand by my original estimate of a 3" to 4" lift. Link to comment Share on other sites More sharing options...
Smokeyyank Posted November 26, 2018 Share Posted November 26, 2018 Here's mine stock height before and after ACOS to adjust the front. Its on 29ish tires. Link to comment Share on other sites More sharing options...
grumpiebill Posted November 26, 2018 Share Posted November 26, 2018 Here's mine stock height before and after ACOS to adjust the front. Its on 29ish tires. I see what eagle means about the flare now. My flares are gone. Didn't realize they extend down past the fender and bumper. Might be why they're the first thing to get damage...Sent from my LG-M210 using Tapatalk Link to comment Share on other sites More sharing options...
grumpiebill Posted November 26, 2018 Share Posted November 26, 2018 This one may be same color as mine was before 2 different owners painted it two different colors. John Deere green over refrigerator white over O.E. maroon...blah. Prepping for Hugger orange now. Are all flares painted? Or molded in color...? I see what eagle means about the flare now. My flares are gone. Didn't realize they extend down past the fender and bumper. Might be why they're the first thing to get damage...Sent from my LG-M210 using Tapatalk Sent from my LG-M210 using Tapatalk Link to comment Share on other sites More sharing options...
yxmj Posted November 26, 2018 Share Posted November 26, 2018 Stock you would also have about 1.25" of rake? Link to comment Share on other sites More sharing options...
Eagle Posted November 27, 2018 Share Posted November 27, 2018 7 hours ago, grumpiebill said: Are all flares painted? Or molded in color...? Base model (SporTruck) were black. Higher trim levels were painted. Link to comment Share on other sites More sharing options...
grumpiebill Posted November 27, 2018 Share Posted November 27, 2018 Base model (SporTruck) were black. Higher trim levels were painted. Mine seemed very thin and fragile. Previous owner had bondo over cracks. I took them off and threw them away. Havnt decided to replace or leave the holes for next owner to make that decisionSent from my LG-M210 using Tapatalk Link to comment Share on other sites More sharing options...
grumpiebill Posted November 27, 2018 Share Posted November 27, 2018 Mine seemed very thin and fragile. Previous owner had bondo over cracks. I took them off and threw them away. Havnt decided to replace or leave the holes for next owner to make that decisionSent from my LG-M210 using Tapatalk According to some badging mine is an XLSSent from my LG-M210 using Tapatalk Link to comment Share on other sites More sharing options...
Tamadrummer Posted November 29, 2018 Author Share Posted November 29, 2018 On 11/23/2018 at 7:42 PM, Minuit said: Measure your ride height to know for sure. It looks like it has a lift in the front. Not sure on the rear. I finally measured the ride height and the front is at 10.25” and rear is at 10.5”. I figure it’s a 3” lift in the front? And maybe new leafs in the rear to match? I was going to do SOA but idk anymore with those leafs Link to comment Share on other sites More sharing options...
Tamadrummer Posted December 9, 2018 Author Share Posted December 9, 2018 @Eagle would a SOA give me more than 6” on those measurements I gave? The leafs and shackles look stock Link to comment Share on other sites More sharing options...
cruiser54 Posted December 9, 2018 Share Posted December 9, 2018 I'll measure mine later and post back.... Link to comment Share on other sites More sharing options...
Eagle Posted December 9, 2018 Share Posted December 9, 2018 8 hours ago, Tamadrummer said: @Eagle would a SOA give me more than 6” on those measurements I gave? The leafs and shackles look stock A SOA will generate a minimum of 5 inches above wherever you sit now (not relative to stock height, relative to YOUR height). It can be more, depending on the thickness of your spring pack. Here's what's involved: Link to comment Share on other sites More sharing options...
cruiser54 Posted December 9, 2018 Share Posted December 9, 2018 19" rear and 18.25" front measured from axle hub center to fender flare lip. Link to comment Share on other sites More sharing options...
