Pete M Posted May 21, 2019 Share Posted May 21, 2019 I like that steering support. I should add that on my to-do list. Link to comment Share on other sites More sharing options...
JMO413 Posted May 21, 2019 Author Share Posted May 21, 2019 1 hour ago, Pete M said: I like that steering support. I should add that on my to-do list. It was fairly cheap at $70 and it definitely stiffens the steering. Link to comment Share on other sites More sharing options...
JMO413 Posted May 28, 2019 Author Share Posted May 28, 2019 Finally got my taillights done! This is after cleaning off most of the silver spray paint. After a bath and allot of sanding they needed a repaint. Black repainted and a couple coats of clear coat. Hopefully it will quit raining someday and I can put them in. Link to comment Share on other sites More sharing options...
Pete M Posted May 28, 2019 Share Posted May 28, 2019 Nice!! Link to comment Share on other sites More sharing options...
JMO413 Posted May 30, 2019 Author Share Posted May 30, 2019 Installed the painted taillights today. You can't see the pieces missing out of these in the picture. These sure do look better! I always thought the orange marker lights looked out of place. Installed some clear ones today and I like them. They are DEPO brand and fit nicely. I had the crown ones and they fit so bad I didn't install them. These are very nice and fit good. The wonderful world of eBay $20. Link to comment Share on other sites More sharing options...
JMO413 Posted June 11, 2019 Author Share Posted June 11, 2019 So I have been collecting parts again. I am off this week for my birthday and 20 year work anniversary. With that said I have some truck time. My rear manifold stud was broken and I was fairly confident the manifold was cracked. When I got the truck the motor mounts were shot. Knowing that and needing to replace the exhaust. The old muffler and tailpipe had holes and was undersized. The tailpipe was under 2" OD. The head pipe was still factory with the crush. No cat just a piece of random pipe to boot. I then came to the conclusion a HO manifold was cheaper in the long run. So I started to collect. My plan is just to delete the EGR. I love in Iowa and they're is no inspection for anything. EGR delete. Route 66 for the plate and Doorman 090-061 for the pipe hole. Plate and plug. The HO manifold had the bellows in it. Hoping that and a piece of flex pipe and it will live a while. These bolts suck! This could have sucked pretty bad. First time no go. Second time winner! The manifold is cracked and the gasket is blown thought on number 6. This crack goes around over half. You can barely see this one is about a quarter way around. Renix/HO Renix on top HO on bottom. Link to comment Share on other sites More sharing options...
JMO413 Posted June 12, 2019 Author Share Posted June 12, 2019 The exhaust ports match perfectly. Tailpipe is definitely going to be in a different location. HO head pipe to match the manifold. Going to see what a Thrush welded sounds like. Flex pipe where my missing cat should be. This flange whelded to the flex pipe. It matches perfectly with the head pipe. Still uses the factory gasket, wanted it to separate. Hopefully this will extended the manifolds life. You do have to grind a little off the edges of the intake for it to fit. Just round of the bottom corners. Both sides. It does fit!! All on and torqued! I wasn't sure what torque sequence. HO or renix. I went renix first and then double checked with the HO pattern. These are a life saver! Link to comment Share on other sites More sharing options...
JMO413 Posted June 12, 2019 Author Share Posted June 12, 2019 While I was at it I decided I was done with my oil leak. I had already done the valve cover, distributor gasket, and oil filter adapter o-rings. And still had an oil leak. Pretty sure the oil pan gasket was leaking. It came out like this, chunks missing. I didn't feel like leaving it to chance so I did the rear main also. And I can't leave good enough alone so. I was pleasantly surprised it came right out. The best part right back in. I could move the timing chain way way too much. New one will be here tomorrow. Side note. You can reach all the manifold bolts except the back stud with this. Steelman Pro swivel extension. Link to comment Share on other sites More sharing options...
onebigmj Posted June 12, 2019 Share Posted June 12, 2019 My hats off to you sir. You’ve done some serious work to keep an old truck on the road and running good. I’m gonna have to do a rear main and oil pan gasket on mine soon and I’m dreading it haha. Link to comment Share on other sites More sharing options...
JMO413 Posted June 12, 2019 Author Share Posted June 12, 2019 37 minutes ago, onebigmj said: My hats off to you sir. You’ve done some serious work to keep an old truck on the road and running good. I’m gonna have to do a rear main and oil pan gasket on mine soon and I’m dreading it haha. Thank you. I think it was the Jeep God's knowing I would bring her back too life. I have a week spot for black Jeeps. The gray buckets, full console, full cluster, 4.0 5 speed signed the deal. Link to comment Share on other sites More sharing options...
onebigmj Posted June 12, 2019 Share Posted June 12, 2019 3 hours ago, JMO413 said: Thank you. I think it was the Jeep God's knowing I would bring her back too life. I have a week spot for black Jeeps. The gray buckets, full console, full cluster, 4.0 5 speed signed the deal. Yeah that certainly checks all the right boxes Link to comment Share on other sites More sharing options...
JMO413 Posted June 12, 2019 Author Share Posted June 12, 2019 Still waiting on a timing chain. The first one had a used cam gear in it. So why not start another project. I already did the drivers floor board so now the passenger side. Yep there's a little hole there. Out with the old in with the new. Seam sealer applied. Waiting for it to dry. Going to clean the surface rust off the rest and POR 15 it is. Then truck bed liner, sounds mat, & heat mat. Not a bad afternoon! Link to comment Share on other sites More sharing options...
JMO413 Posted June 14, 2019 Author Share Posted June 14, 2019 Finally got a timing set. New timing cover the old one cracked when I installed the crank seal. New balancer old one was falling apart. Installed the oil pan gasket. Hopefully no more leaks. Got the new head pipe installed. Wiring definitely reached. The O2 sensor is definitely easier to reach now. Factory flange to flex pipe. Thrush welded muffler. Walker tail pipe. And she runs again! Got the floor pan seam sealer and painted. Installed sound deadener pad and then heat pad. Now I just have to install the interior. Link to comment Share on other sites More sharing options...
Pete M Posted June 14, 2019 Share Posted June 14, 2019 sure sounds mean Link to comment Share on other sites More sharing options...
JMO413 Posted June 14, 2019 Author Share Posted June 14, 2019 20 minutes ago, Pete M said: sure sounds mean I like it allot! Link to comment Share on other sites More sharing options...
1989commanche Posted June 14, 2019 Share Posted June 14, 2019 On 6/11/2019 at 5:31 PM, JMO413 said: While I was at it I decided I was done with my oil leak. I had already done the valve cover, distributor gasket, and oil filter adapter o-rings. And still had an oil leak. Pretty sure the oil pan gasket was leaking. It came out like this, chunks missing. I didn't feel like leaving it to chance so I did the rear main also. And I can't leave good enough alone so. I was pleasantly surprised it came right out. The best part right back in. I could move the timing chain way way too much. New one will be here tomorrow. Side note. You can reach all the manifold bolts except the back stud with this. Steelman Pro swivel extension. I bought a 10 and 12 just like those of the snappy truck. Coulda probably paid for that whole set. Link to comment Share on other sites More sharing options...
JMO413 Posted June 14, 2019 Author Share Posted June 14, 2019 6 hours ago, 1989commanche said: I bought a 10 and 12 just like those of the snappy truck. Coulda probably paid for that whole set. The whole set was $100. Link to comment Share on other sites More sharing options...
1989commanche Posted June 14, 2019 Share Posted June 14, 2019 So were the two I bought, they are very handy though. Link to comment Share on other sites More sharing options...
trailnfish Posted June 15, 2019 Share Posted June 15, 2019 Great to follow along! Look forward to the rest of it. Link to comment Share on other sites More sharing options...
JMO413 Posted July 6, 2019 Author Share Posted July 6, 2019 My steering wheel cover was falling apart pretty bad. So I finally ordered a new sew on one. Not sure how long it had been on. It had definitely seen better days. I was pleasantly surprised the steering wheel still looks brand new. I'm guessing I can thank the old trashed cover for that. Amazon has everything! $13 what a deal. This definitely takes some time and patience. Looks like new again! Band-Aids are required so the thread doesn't cut into your hands. Link to comment Share on other sites More sharing options...
JMO413 Posted July 6, 2019 Author Share Posted July 6, 2019 Bought a couple more NOS crank sensors. Parking brake releases cables & horn buttons. Thanks again yellaheep for the horn buttons and cables. Rear Jeep/AMC mudflaps and 2 sets of Jeep front flaps. Hood relase cables are still available OEM but the pull handle has a car on it. Link to comment Share on other sites More sharing options...
JMO413 Posted July 7, 2019 Author Share Posted July 7, 2019 Decided it was time to install the door seals I had ordered a while back. They are Fairchild from Rock Auto. They fit descent, the doors are super tight now. While I had the interior out to do the weather strips I installed sound and heat mat on the roof. I also installed sound mat on the back wall of the cab. The weather strips were $36 for both doors. They installed nice and seen decently made. They look much better than the old torn ones. Hopefully it helps keep the rain out also. One spot that actually isn't all rusty! The spots are just the backing from the headliner. Sounds pad installed. Used Noico sound pad and roller. It seems very nice and sticky! Heat mat also from Noico. Both were from Amazon. Only did sound mat on the back wall of the cab. Used spray on bed liner on the headliner. It was already partially spray painted and the cloth was gone. It's now not flaking off but a new one is definitely on the list of to do some day. Just took the truck for a drive and the noise reduction was definitely noticable. Link to comment Share on other sites More sharing options...
JMO413 Posted July 13, 2019 Author Share Posted July 13, 2019 Ordered some new trim retainers for my back panel. Mopar still had them and they are kinda pricey. I kept looking and found a cheaper option still from Chrysler. The white ones are $2 each. The black ones are what the parts catalog shows. They are identical to each other except color. I also replaced the front turn signal housings. The old ones were cracked and had over spray on them. Hard to tell in the pictures but it looks much better! Link to comment Share on other sites More sharing options...
WahooSteeler Posted July 13, 2019 Share Posted July 13, 2019 fyi, Lowes has a pretty good selection of "automotive fasteners" in the section that has screws, washers, etc in those pull out drawers. Plastic "push pins" like these and metal clip screw fasteners etc. Link to comment Share on other sites More sharing options...
JMO413 Posted July 13, 2019 Author Share Posted July 13, 2019 37 minutes ago, WahooSteeler said: fyi, Lowes has a pretty good selection of "automotive fasteners" in the section that has screws, washers, etc in those pull out drawers. Plastic "push pins" like these and metal clip screw fasteners etc. So does Menards. These are really skinny where the Christmas tree meets the button head. They are definitely speciality fasteners. Link to comment Share on other sites More sharing options...
