87MJTIM Posted June 8, 2020 Share Posted June 8, 2020 10 hours ago, shelbyluvv said: 4.0 swap is all the rage in CJs Link to comment Share on other sites More sharing options...
neohic Posted June 14, 2020 Author Share Posted June 14, 2020 The little CJ got another band aid today to push off serious thought into a drivetrain swap. Right now I’m leaning towards a 4.0 swap as I was way back when this thread started. My goal is still to turn my little CJ into a real driver... overdrive is a part of this equation. I still don’t have the wheelbase for an AX15 and still have a decent amount of room for a rear driveshaft. So much of the time I get into a dire situation and a good solution just presents itself. Fingers crossed that’s the case when the engine decides that enough is enough. Keep juggling changing everything when the time comes or just leaving well enough alone that got it here from 45 years ago. Anyhow... I digress. Pics for clicks. Link to comment Share on other sites More sharing options...
FrankTheDog Posted June 14, 2020 Share Posted June 14, 2020 How about a Buick V6 with a SM 420 and swapping out the 4.27’s for 3.73’s? 1st and 2nd will be lower than your T14’s first gear and with going to 3.73’s it would be like adding an overdrive. Plus with the 7-1 first gear it will still crawl. Link to comment Share on other sites More sharing options...
Pete M Posted June 14, 2020 Share Posted June 14, 2020 4 banger diesel? Link to comment Share on other sites More sharing options...
neohic Posted June 14, 2020 Author Share Posted June 14, 2020 36 minutes ago, FrankTheDog said: How about a Buick V6 with a SM 420 and swapping out the 4.27’s for 3.73’s? 1st and 2nd will be lower than your T14’s first gear and with going to 3.73’s it would be like adding an overdrive. Plus with the 7-1 first gear it will still crawl. Now there’s an interesting thought. To me this feels a bit like going backwards minus the 420 though. 1972 was the first year of AMC really taking the reins and added the inline six. At times I really wish my CJ was just a few years older that I’d show zero remorse about dropping in any GM V6. Replacing an AMC 258 with a Buick 225 just feels... wrong. Any opinions on the T5 transmission? I know they aren’t the most desirable but the majority of the driving this Jeep sees is pavement. I’d like to see this turn into a vehicle I can pick a direction and just go. If mild wheeling is in my way of the perfect campsite then so be it. Link to comment Share on other sites More sharing options...
FrankTheDog Posted June 14, 2020 Share Posted June 14, 2020 AMC didn’t have any problem dropping the GM 2.8 into the XJ and MJ. The odd fire V6 is a good compact engine that will give you room to put a 5 speed in and keep your driveshaft length decent. Link to comment Share on other sites More sharing options...
neohic Posted June 14, 2020 Author Share Posted June 14, 2020 4 hours ago, FrankTheDog said: AMC didn’t have any problem dropping the GM 2.8 into the XJ and MJ. Very true. Link to comment Share on other sites More sharing options...
derf Posted June 14, 2020 Share Posted June 14, 2020 I'd pick an AX15 over a T5. A 4.3 V6 would swap in easily. Push it forward a bit and you would have room. A 4.3/SM465/Atlas combo would be pretty sweet too. Adjust the axle gears for the highway but you'd still have plenty of crawl ratio. Link to comment Share on other sites More sharing options...
JustEmptyEveryPocket Posted June 14, 2020 Share Posted June 14, 2020 12 hours ago, Pete M said: 4 banger diesel? I'm with Pete here. Get yourself a BEW TDI and AX-15. Move the small engine forward a good bit to keep access to the tandem pump, which gives space for rear driveshaft. Diesel for torque + 1st gear + low range = crawling monster. High rpm range hp (thank you German engineering) + broad torque range + 5th gear = great pavement princess. Unique (-ish?) Great mpg compared to all other options I know of. Model your swap on THIS kit or do more of a build your own based on THIS kit. Link to comment Share on other sites More sharing options...
neohic Posted June 14, 2020 Author Share Posted June 14, 2020 7 hours ago, derf said: I'd pick an AX15 over a T5. As do I. The T5 was an option in the CJ7s and it’s the same dimensions of the T4. Part of me is hoping to just stumble across someone doing a full drivetrain swap and is looking to get rid of their 258/T5/Dana 300 combo. That’d be almost a bolt in deal. Guy us can wish anyhow. Link to comment Share on other sites More sharing options...
