Comanche Fun-Runner: LS3, Long Travel IFS, AX-15, D44/9’’
2 minutes ago, Eagle_SX4 said:
Great job on the truss. If that axle doesn't have a drain plug I would suggest adding one while you have it all torn apart.
Not a bad idea, I haven’t honestly checked for one. Ill have to take a look next time I’m out there.
Tolerances were a little tight on the hubs themselves so they are getting massaged a little more. BUT! I got the spacers and wheels back. And the test fit went great. Once the hubs are fixed up it should all go together perfect and be a driver this weekend hopefully.
Hopefully the statements about being lug, and hub centric are making sense now that they have come to fruition.
Looking good! That was a lot of down time for some spacers :laugh:
It definitely was, but when a buddy says he’ll do it for free I can’t complain too much lol. Would have been probably a grand in labor and materials had I have to pay.
Okay, so update time.
The Hubs and adapters needed a little work to get installed. The machine fit of the adapters were too tight of a tolerance for the hubs as-is. The hubs were either a little crusty or a little out of round and needed a kiss on the lathe to get back to perfectly round. But now everything fits together with a nice “clunk” and is solid. The wheels fit the adapters and hubs perfectly.
I had to trim down the rear axle lug studs to fit behind the wheel mount face, as the wheels don’t have the pockets machined that some wheels come with.
I still need to finish bleeding the rear brake bypass line, but it stops for now, pretty smoothly I will say.
The rear axle width makes it look not so awkward as it used to with the stock width Dana 44. First and second gear are completely useless, anymore than 1/4 throttle it just blows the tires off.
18 hours ago, ghetdjc320 said:
Sounds great! Are you still running an ax15 with that setup?
Sure am, doesn’t mind the 35’s at all, especially with the correct gearing now. I could definitely tell the drivetrain was under more more stress with 3.07 gears, seems like the 4.88 gears really woke it up.
Well, life has been crazy the last few weeks. I spent some time getting the old front suspensions and steering out from under the Jeep. It is a hovercraft again.
Over the course of summer I will be getting the new front suspension & steering designed & installed.
6 hours ago, TurboedMJ said:
Just saw your build thread over on the Silverado forums, didn't notice it was you till I read "project Jeep Comanche Prerunner" and did a double take. The truck looks great!
 Ha! Sure is a small world here on the World Wide Web lol. I appreciate it! That build thread kind of gives some back story on the Comanche’s drivetrain too
So, had to pull the engine on my daily driver as it had a rocker arm come apart, and leaked from every orifice so killed a few birds at once. Got the freshened up LS3 in that. See the Denali’s build thread in my signature if you are interested in seeing that.
Anyways, back to the Comanche.
As it lies, the front end is floating. I am going to order up some bushings and ball joints so I can get the beam crossmember designed and made. More details to come, just want to get this post to update and show the current state of things.
Separate from the TTB swap, I will likely be doing 97+ windows (if not 97+ complete doors), also removing the front Fiberglass flares and going back to factory steel with more “crawler” style steel flares.
Just now, 89 MJ said:
Why the switch to different flares in the front?
A couple reasons,
first, the new front WMS will be 65’’ instead of the previous 69’’
Second, it will now be on narrow 4x4 trails and not wide open desert, so more robust fenders will be needed. Going to go with Rusty’s new High clearance flares.
Admittedly not mush of the factory fender sheet metal will be used, but is it just enough to mount those flares.
Got started on the new front end. Have to figure out the wheel centerline, to begin fabricating the front crossmember. Lots of things to do one after another.
Been racking my brain the past few days redoing the crossmember design, for the third time lol. Each time I do it I feel there are better ways to do certain things.
I also ordered up the pivot bushings, ball joints, and wheel bearings so I can start double checking dimensions before sending the crossmember files out to be cut.
The crossmember is mostly entirely boxed and internally braces. It is bolt-in, but that is mostly only for locating as it will be final welded in once everything is kosher.
