DirtyComanche Posted April 27, 2018 Share Posted April 27, 2018 1 hour ago, omega_rugal said: 5 years? so you are just topping it off as it burns? Pretty much. I should order a filter for it so I don't have any excuses. Link to comment Share on other sites More sharing options...
87MJTIM Posted April 28, 2018 Share Posted April 28, 2018 5 hours ago, omega_rugal said: 5 years? so you are just topping it off as it burns? That's called "changing the oil from the top." I have an 8.1 L Chevy Suburban I do that to. Link to comment Share on other sites More sharing options...
DirtyComanche Posted April 28, 2018 Share Posted April 28, 2018 1 hour ago, 87MJTIM said: That's called "changing the oil from the top." I have an 8.1 L Chevy Suburban I do that to. My consumption is staggeringly low. It actually has a very tight engine in it. It was a GM crate engine somebody bought and wrapped the truck it was in around a pole shortly after. I really should change the oil because that's easier than changing the engine (again). Link to comment Share on other sites More sharing options...
HOrnbrod Posted April 28, 2018 Author Share Posted April 28, 2018 21 hours ago, johnj92131 said: Lots of endless debates all over the internet about oil. Here is what I "think" I now. 3) Modern oil is engineered to specific SAE Grades or performance standards. Zinc additives went away due to their ill effects on catalytic convertors Nope, not for some conventional diesel oils, at least so far. A high zinc ppm content is still available, particularly in Chevron Delo 400LE and Shell Rotella. Been using Delo since day one with the stroker for many years now because of the flat tappet higher lift cam I'm running, and because the guys at Hesco told me to. Would be a good choice for your new diesel MJ too John. Link to comment Share on other sites More sharing options...
johnj92131 Posted April 28, 2018 Share Posted April 28, 2018 Don, Good information about Chevron Delo 400LE and Shell Rotella! I still have quite a few gallons of VW diesel specific oil in the garage Both Delo and Rotella are great oils for gas or diesel. Instead of saying zinc additives went away, I should have said zinc content was greatly reduced. Link to comment Share on other sites More sharing options...
HOrnbrod Posted April 28, 2018 Author Share Posted April 28, 2018 7 hours ago, johnj92131 said: Instead of saying zinc additives went away, I should have said zinc content was greatly reduced. This is true. Progress strikes again... Link to comment Share on other sites More sharing options...
Vakarian Posted June 20, 2018 Share Posted June 20, 2018 Where do you find the adapter for the renix engine? Link to comment Share on other sites More sharing options...
coolwind57 Posted June 20, 2018 Share Posted June 20, 2018 7 minutes ago, Vakarian said: Where do you find the adapter for the renix engine? Got my Mopar 3/4"X16 nipple at the local Jeep dealership. You're gonna need a long and strong 22mm deep well socket to get that old sucker off. Link to comment Share on other sites More sharing options...
Vakarian Posted June 20, 2018 Share Posted June 20, 2018 10 minutes ago, coolwind57 said: Got my Mopar 3/4"X16 nipple at the local Jeep dealership. You're gonna need a long and strong 22mm deep well socket to get that old sucker off. Thank you immensely for the response and information coolwind57! Didn't realize they had different threads and made a mess. Link to comment Share on other sites More sharing options...
75sv1 Posted June 20, 2018 Share Posted June 20, 2018 Zinc content has been reduced for the newer Cats. Here's a link for some oil info: https://www.cherokeeforum.com/f2/rotella-worlds-first-ever-combined-hair-oil-foot-ointment-salad-dressing-188168/ I am running T6. I am planning to use a remote filter setup. Also, to add a cooler. Need to get to oil over 180F for at least 1/2 every week. Modern oils may not be as finicky. Link to comment Share on other sites More sharing options...
coolwind57 Posted June 20, 2018 Share Posted June 20, 2018 2 minutes ago, Vakarian said: Thank you immensely for the response and information coolwind57! Didn't realize they had different threads and made a mess. no problem. I have some pictures and a brief write-up on this topic at the forum MEMBERS PROJECTS: YOUR COMANCHES page under "Coolwind57's" It's on page 1 about half way down. Link to comment Share on other sites More sharing options...
Vakarian Posted June 20, 2018 Share Posted June 20, 2018 6 minutes ago, coolwind57 said: no problem. I have some pictures and a brief write-up on this topic at the forum MEMBERS PROJECTS: YOUR COMANCHES page under "Coolwind57's" It's on page 1 about half way down. Found it! Thank you again coolwind57. This will save me some money because I didn't realize that nipple was removable. Link to comment Share on other sites More sharing options...
Wounded_Fighter Posted June 20, 2018 Share Posted June 20, 2018 2 hours ago, coolwind57 said: Got my Mopar 3/4"X16 nipple at the local Jeep dealership. You're gonna need a long and strong 22mm deep well socket to get that old sucker off. Any chance you have a part number for that? Link to comment Share on other sites More sharing options...
HOrnbrod Posted June 20, 2018 Author Share Posted June 20, 2018 A 5-sec search for "nipple" yielded this: http://www.fourwheeler.com/how-to/5421/ Link to comment Share on other sites More sharing options...
coolwind57 Posted June 20, 2018 Share Posted June 20, 2018 HOrnbrod's link above is for a larger kit that allows horizontal mounting as well as the 3/4" X 16 adapter you're asking about. If you're wanting the nipple only, then try these guys: https://www.quadratec.com/products/51007_0020.htm Vakarian just told me that his local jeep dealer advised that the Mopar part is no longer available, although my dealer here in Southern Indiana sold me one last year. You may just need to call first before driving over. Mopar Part number is: 53007563AB Here's a Genuine Mopar on Ebay: https://www.ebay.com/itm/1991-2009-JEEP-DODGE-CHRYSLER-OIL-FILTER-ADAPTER-CONNECTOR-OEM-MOPAR-GENUINE/191946528853?fits=Model%3ACherokee&epid=1022063355&hash=item2cb0e79855:g:e4gAAOSw-itXsavY Link to comment Share on other sites More sharing options...
HOrnbrod Posted June 20, 2018 Author Share Posted June 20, 2018 If you read the link, the p/n for the nipple is there, 53007563.. https://www.moparpartsgiant.com/parts/dodge-connector-oil-filter~53007563.html Link to comment Share on other sites More sharing options...
Wounded_Fighter Posted June 21, 2018 Share Posted June 21, 2018 6 hours ago, coolwind57 said: You may just need to call first before driving over. Mopar Part number is: 53007563AB I drive by one literally daily in my commute, won't hurt me to turn in. They've gotten quite use to seeing me there with my dodge or my new MJ! Thanks for the info. HOrnbrod, thank your as well, I probably did skim past the part number reading everything here Link to comment Share on other sites More sharing options...
