87Chief Posted January 19, 2018 Posted January 19, 2018 My 88 renix motor needs a rebuild badly and I don't have funds for the machine shop right now and I found a 92 HO motor from a cherokee..  He has the harness and ecm. Could I just drop this in or should I swap my renix sensors and stuff to the HO motor and run it that way?  Thanks for the advice.  Sent from my SM-G930V using Tapatalk  Â
omega_rugal Posted January 19, 2018 Posted January 19, 2018 In your case it`s easier to swap ererything in, engine, ecu, harness, dash...
MeanLemons Posted January 20, 2018 Posted January 20, 2018 Ha no. It’s easier just to use everything renix.Â
Marine1Texas Posted January 20, 2018 Posted January 20, 2018 All you need to do is put the ho motor in with all your renix stuff attached. Use you intake, dizzy, and sensors.
cruiser54 Posted January 20, 2018 Posted January 20, 2018 Here's a link for you. Tried and proven. Â http://cruiser54.com/?p=100
cruiser54 Posted January 20, 2018 Posted January 20, 2018 14 hours ago, omega_rugal said: In your case it`s easier to swap ererything in, engine, ecu, harness, dash... Absolutely not true.Â
87Chief Posted January 20, 2018 Author Posted January 20, 2018 Awesome. Thanks for the info cruiser!Sent from my SM-G930V using Tapatalk
omega_rugal Posted January 20, 2018 Posted January 20, 2018 2 hours ago, cruiser54 said: Absolutely not true.  just saying...
cruiser54 Posted January 21, 2018 Posted January 21, 2018 21 hours ago, omega_rugal said:  just saying... Yep. Just saying something that isn't true.........and possibly sending an unsuspecting person on a wild goose chase. Pretty irresponsible to do that if you ask me. It's always been my impression that we're supposed to help and guide people here on CC. Not mislead them. Â
omega_rugal Posted January 21, 2018 Posted January 21, 2018 Misleading? he says he has everything from the donor, he can either swap the whole thing as it is and call it a day, mixing Renix and Mopar stuff is not as straight forward...
HOrnbrod Posted January 21, 2018 Posted January 21, 2018 OP, have you heard the 92 HO motor run? Do you know How many miles are on it?
87Chief Posted January 21, 2018 Author Posted January 21, 2018 Have not heard it run but he said 140k miles.. Sent from my SM-G930V using Tapatalk
HOrnbrod Posted January 21, 2018 Posted January 21, 2018 Unless the seller is a trusted friend or a local shop/yard with a good rep, w/o a solid guarantee I'd pass. But that just me. Guaranteed used Jeep 4.0's are not that difficult to find.
87Chief Posted January 21, 2018 Author Posted January 21, 2018 Ok thanks for the info. I'll try car-part.com and try to find a good renix one.Sent from my SM-G930V using Tapatalk
HOrnbrod Posted January 21, 2018 Posted January 21, 2018 A good HO engine would be fine too. I just don't want to see you go through a whole lot of work and $$ and get burned.Â
Kyleinreallife Posted January 22, 2018 Posted January 22, 2018 Misleading? he says he has everything from the donor, he can either swap the whole thing as it is and call it a day, mixing Renix and Mopar stuff is not as straight forward... Considering that crusier's wealth of knowledge has helped me solve every issue I've had....I would continue to take his word for it. ....just sayin 87' XJ Wagoneer I-6 AW4 NP242
omega_rugal Posted January 22, 2018 Posted January 22, 2018 1 hour ago, Kyleinreallife said: Considering that crusier's wealth of knowledge has helped me solve every issue I've had....I would continue to take his word for it. ....just sayin  I respect Cruser`s knowledge, i`m sorry my advise is nto as good as his...
Kickin’Chicken Posted January 22, 2018 Posted January 22, 2018 OP's sig says he has the 2.5 4 cylinder. If so, how would he be able to keep his renix system and convert to the new block?
87Chief Posted January 22, 2018 Author Posted January 22, 2018 I have ecu and wiring from donor 88 4.0..  I just figured it would be easier to stay renix then do HO.  I would only have to do underhood harness instead of interior with 2.5 to 4.0 swap correct?  Sent from my SM-G930V using Tapatalk    Â
87Chief Posted January 22, 2018 Author Posted January 22, 2018 oh it`s ANOTHER truck... ?I'm using the wiring and ecm from a renix 88 mj into my 2.5 mj. I don't get your comment... the 4.0 out of the 88 needs rebuilt but I don't have the funds right now to spend $1300 for that. So I was asking if I could use an HO in its place..Sent from my SM-G930V using Tapatalk
omega_rugal Posted January 22, 2018 Posted January 22, 2018 you didn`t say you had 2 don.. oh forget it...
cruiser54 Posted January 22, 2018 Posted January 22, 2018 On 1/21/2018 at 2:16 PM, omega_rugal said: Misleading? he says he has everything from the donor, he can either swap the whole thing as it is and call it a day, mixing Renix and Mopar stuff is not as straight forward... It's easy. I have comprehensive instructions.Â
omega_rugal Posted January 22, 2018 Posted January 22, 2018 1 hour ago, cruiser54 said: It's easy. I have comprehensive instructions.  you are an expert on the subject and have the neccesary tools for the job, the OP may not...
