eaglescout526 Posted December 25, 2019 Share Posted December 25, 2019 2 minutes ago, Fernando87mj said: Looks great! Need a shift boot bezel retainer or is the console broke? Link to comment Share on other sites More sharing options...
Fernando87mj Posted December 25, 2019 Author Share Posted December 25, 2019 My center console is broken but I got lucky and found a pristine one off a 87 xj , Just haven’t swapped it in yet Link to comment Share on other sites More sharing options...
eaglescout526 Posted December 25, 2019 Share Posted December 25, 2019 Nice score! Link to comment Share on other sites More sharing options...
SatiricalHen Posted December 25, 2019 Share Posted December 25, 2019 So jealous If you’re jealous of the clock I come across them all the time and could pull one and sell it to you or 88mjsally probably has a few. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
SatiricalHen Posted December 25, 2019 Share Posted December 25, 2019 Well I knew my fuse block wasn’t In the best shape. I’ve been putting this off since I bought the truck 2 years ago so I finally ordered some fuse pins. Taking apart the fuse block wasn’t to bad. This fuse connector was done for. This one is for the brake lights. I’m currently working little by little. It gets really hot here in Vegas pretty quickly and I work on it during dawn and sunset. ill keep updating this. I need to replace the other pins on the fuse block and I will update with the finished product I’ve seen these before, but where did you get them from? I don’t remember where they can be found. I have to twist my fuses to get decent contact. Also, how do those clip in? On my 99 Cherokee the stupid plastic tabs in the fuse box break if you look at them. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Drahcir495 Posted December 25, 2019 Share Posted December 25, 2019 49 minutes ago, SatiricalHen said: If you’re jealous of the clock I come across them all the time and could pull one and sell it to you or 88mjsally probably has a few. Sent from my iPhone using Tapatalk Thank you for the offer . I actually got a working one from another member on here! Link to comment Share on other sites More sharing options...
Fernando87mj Posted December 26, 2019 Author Share Posted December 26, 2019 5 hours ago, SatiricalHen said: I’ve seen these before, but where did you get them from? I don’t remember where they can be found. I have to twist my fuses to get decent contact. Also, how do those clip in? On my 99 Cherokee the stupid plastic tabs in the fuse box break if you look at them. Sent from my iPhone using Tapatalk https://m.delcity.net/ i just used a modified paper clip and pushed on the little wings on the terminal with the paper clip to get it out. Link to comment Share on other sites More sharing options...
Fernando87mj Posted December 28, 2019 Author Share Posted December 28, 2019 Well 3 days later and I found this crack on my new to me glove box lid Link to comment Share on other sites More sharing options...
Fernando87mj Posted February 3, 2020 Author Share Posted February 3, 2020 Finally got to installing some new shocks on the old girl. The old shocks and steering stabilizer were far gone , to the point where I could compress the piston on the shocks with a finger. New shocks installed. Link to comment Share on other sites More sharing options...
Fernando87mj Posted February 3, 2020 Author Share Posted February 3, 2020 I also replaced the front fender liners while I was at it Link to comment Share on other sites More sharing options...
Fernando87mj Posted February 3, 2020 Author Share Posted February 3, 2020 I got lucky and Found some turbines for my other Comanche. So this beauty got the leftover wheels. Really like the look. I also got to fixing the the temporary vacuum “connections” I had and actually ordered the whole vacuum harness. I also order the rear Pcv line and the grommet. The old grommet was plugged with 30 years worth of oil and wear. i wasn’t a fan of how high the pcv line was sitting at first but after a few miles it’s settled down and sits the same as the factory one did. Link to comment Share on other sites More sharing options...
MJCARENA Posted February 3, 2020 Share Posted February 3, 2020 Where did you get the fender liners from, and how well did they fit? I need to do mine. Thanks Link to comment Share on other sites More sharing options...
Fernando87mj Posted February 3, 2020 Author Share Posted February 3, 2020 3 hours ago, MJCARENA said: Where did you get the fender liners from, and how well did they fit? I need to do mine. Thanks I bought them off rockauto , the material is a bit flimsy but all the holes lined up perfectly on the passenger side , I can’t say the same for the drivers side , there seems to Be a bit of evidence of a past fender bender in this truck. Regardless I don’t think you would have a problem with having it line up Link to comment Share on other sites More sharing options...
Pete M Posted February 3, 2020 Share Posted February 3, 2020 3 hours ago, MJCARENA said: Where did you get the fender liners from, and how well did they fit? I need to do mine. Thanks front fender liners can be found in XJs up to 96. the later years have the same part but it's made of much better plastic than MJs. Link to comment Share on other sites More sharing options...
MJCARENA Posted February 3, 2020 Share Posted February 3, 2020 Thanks for the info. Link to comment Share on other sites More sharing options...
eaglescout526 Posted February 3, 2020 Share Posted February 3, 2020 Just now, MJCARENA said: Thanks for the info. Theres some Mopar pieces left if you want to go down that route. Link to comment Share on other sites More sharing options...
Fernando87mj Posted December 25, 2020 Author Share Posted December 25, 2020 Lots of updating to do. since last update I’ve.. -converted to open cooling system -replaced Speedo cable and speedometer head assembly -replaced trans fluid -replaced diff fluid -stared at it and fell more in love with it - got headliner and sunvisors reupholstered - replaced inner shift boot -added vent windows old and new boot , this made such a huge difference in interior noise despite the hate they get on here I really wanted vent windows and I have no regrets swapping them in. — converted to open cooling system , old radiator had already been leaking. Also wrapped and protected wiring , found passenger side horn wire was rubbed through and repaired it. spectra radiator had bung for renix fan switch. Link to comment Share on other sites More sharing options...
Fernando87mj Posted December 25, 2020 Author Share Posted December 25, 2020 got the Dana 35 lookin all pretty. No after pictures. Forgot to take after pic. Replaced and matched the mileage on new to me speedometer head. Old one was seized and was hard to turn. matching mileage wasn’t that hard , just takes a little patience. swapped in better leds while I was at it. :) took my time and tried to clean all the Dust out of the cluster. Think it came out looking pretty good. Link to comment Share on other sites More sharing options...
Fernando87mj Posted December 25, 2020 Author Share Posted December 25, 2020 Decided IT was time to do something about that old headliner. doggo supervising got the headliner back yesterday and it came out looking amazing. Also got the visors redone while I was at it. not putting the interior back together Just yet. Going to order new carpet for the old girl and get that redone while I’m at it. Also ordered new b pillar lights. Can’t wait to get this buttoned together. It’s going to look good. Link to comment Share on other sites More sharing options...
Fernando87mj Posted December 25, 2020 Author Share Posted December 25, 2020 Bonus Christmas mj yard art. Link to comment Share on other sites More sharing options...
Pete M Posted December 31, 2020 Share Posted December 31, 2020 dang, you've been busy! I used a similar design of LED in my cluster and ended up blacking out the top LEDs to cut down the brightness. Link to comment Share on other sites More sharing options...
Fernando87mj Posted January 1, 2021 Author Share Posted January 1, 2021 Thanks Pete , just ordered a carpet kit from stock interiors and Just finished installing my new b pillar lights. Looking forward to putting it together ! Link to comment Share on other sites More sharing options...
MiNi Beast Posted January 1, 2021 Share Posted January 1, 2021 did you use the jetta lights for b pilar? Link to comment Share on other sites More sharing options...
Fernando87mj Posted January 3, 2021 Author Share Posted January 3, 2021 On 12/31/2020 at 4:28 PM, MiNi Beast said: did you use the jetta lights for b pilar? No , I ended up using the Euramtec lights Link to comment Share on other sites More sharing options...
MiNi Beast Posted January 3, 2021 Share Posted January 3, 2021 53 minutes ago, Fernando87mj said: No , I ended up using the Euramtec lights these ones? http://www.euramtec.com/parts/c/c01/7180.html Link to comment Share on other sites More sharing options...
