krustyballer16 Posted June 24, 2018 Share Posted June 24, 2018 I may order a set at some point in time when I do the cage Only got 2 Sets left! Lol Sent from my SM-G892A using Tapatalk Link to comment Share on other sites More sharing options...
Swampy Posted June 26, 2018 Author Share Posted June 26, 2018 On 6/24/2018 at 7:26 AM, krustyballer16 said: Only got 2 Sets left! Lol Sent from my SM-G892A using Tapatalk Dang you won't have any more? Link to comment Share on other sites More sharing options...
DirtyComanche Posted June 26, 2018 Share Posted June 26, 2018 Curious if anyone has a picture of the actual Corbeau brackets? I have a pair of Corbeau seats. Link to comment Share on other sites More sharing options...
krustyballer16 Posted June 26, 2018 Share Posted June 26, 2018 Dang you won't have any more? Not for a while. I have to order them in sets of 10 or 20. So enough people will have to want them again in a few months or whenever. Sent from my SM-G892A using Tapatalk Link to comment Share on other sites More sharing options...
Dixie Posted August 17, 2018 Share Posted August 17, 2018 So MJ brackets with XJ seats, right? Can’t put XJ brackets in on an MJ without modifications? Can I put bucket seats on bench brackets? Link to comment Share on other sites More sharing options...
Pete M Posted August 17, 2018 Share Posted August 17, 2018 the brackets that touch the floor are different between the MJ and XJ because the floorpans are different. yes, MJ bench floor brackets are the same as MJ bucket floor brackets. Link to comment Share on other sites More sharing options...
krustyballer16 Posted August 17, 2018 Share Posted August 17, 2018 the brackets that touch the floor are different between the MJ and XJ because the floorpans are different. yes, MJ bench floor brackets are the same as MJ bucket floor brackets. Exactly. Sent from my SM-G892A using Tapatalk Link to comment Share on other sites More sharing options...
Dixie Posted August 25, 2018 Share Posted August 25, 2018 Would anyone happen to know the difference in the dimensions of the MJ and XJ seat brackets? I have some XJ seat tracks and was wondering if it’s even worth to make the adjustments to have them fit in my ‘88 MJ Link to comment Share on other sites More sharing options...
krustyballer16 Posted August 25, 2018 Share Posted August 25, 2018 Xj and mj Seats are the same seats. Only difference is the floor they mount to.....Sent from my SM-G892A using Tapatalk Link to comment Share on other sites More sharing options...
DesertRat1991 Posted August 26, 2018 Share Posted August 26, 2018 On 8/17/2018 at 7:58 AM, Pete M said: the brackets that touch the floor are different between the MJ and XJ because the floorpans are different. yes, MJ bench floor brackets are the same as MJ bucket floor brackets. 16 hours ago, krustyballer16 said: Xj and mj Seats are the same seats. Only difference is the floor they mount to..... Sent from my SM-G892A using Tapatalk So if MJ bench and bucket floor brackets are the same, and MJ/XJ seats are the same -- then MJ bench floor brackets will readily accept XJ bucket seats? Then I guess I'm sorta confused as to why so many MJ owners are in the market for new floor brackets? Is there an advantage to the new production brackets that I'm missing? Link to comment Share on other sites More sharing options...
krustyballer16 Posted August 26, 2018 Share Posted August 26, 2018 XJ buckets are everywhere. Whether they're 2 door or 4 door buckets. So people want to replace the mj bench. Since mj buckets are harder to find, they use xj Seats and need mj brackets to fit the floor. And also because these trucks are 30 years old and most of th brackets are rusted away. Sent from my SM-G892A using Tapatalk Link to comment Share on other sites More sharing options...
Dixie Posted August 26, 2018 Share Posted August 26, 2018 I meant I have XJ tracks, sorry... I’m sure that sounded stupid and confusing Link to comment Share on other sites More sharing options...
krustyballer16 Posted August 26, 2018 Share Posted August 26, 2018 If they're pre1996 seats, put them on MJ brackets and put in MJSent from my SM-G892A using Tapatalk Link to comment Share on other sites More sharing options...
Dixie Posted August 26, 2018 Share Posted August 26, 2018 34 minutes ago, krustyballer16 said: If they're pre1996 seats, put them on MJ brackets and put in MJ Sent from my SM-G892A using Tapatalk Awesome, thank you! I’ll go return the XJ tracks since I won’t have any use for them Link to comment Share on other sites More sharing options...
Swampy Posted September 25, 2018 Author Share Posted September 25, 2018 To revive an old thread. Are there any people running seats that didn't come from the factory. No mj/xj/wj/zj buckets. Does anyone have a "racing seat"? PRP, corebu, mastercraft, or any generic ones Link to comment Share on other sites More sharing options...
gogmorgo Posted September 25, 2018 Share Posted September 25, 2018 Do you actually say it "Corbu"? I've only seen it written, but Corbeau is pretty clearly "core-BOH" to me. I don't have any experience with manufactured racing seats but I have participated in making one out of carbon fibre. We used dense foam to carve out a fairly comfortable seat shape, made a negative out of plaster to form a mold, then laid up the carbon fibre over the mold. I want to say we went about ten layers of 2x2 twill weave, with aluminum brackets poked through a few extra reinforcement layers where we needed to bolt it down. It came out lightweight, and rigid enough to support you but pliable enough to conform a bit for a touch more comfort. Link to comment Share on other sites More sharing options...
88whitemanche Posted September 27, 2018 Share Posted September 27, 2018 These are commonly used https://www.quadratec.com/products/24226_X0X0_PG.htm And a write up https://www.naxja.org/forum/showthread.php?t=946575 Link to comment Share on other sites More sharing options...
Swampy Posted September 30, 2018 Author Share Posted September 30, 2018 On 9/27/2018 at 6:28 PM, 88whitemanche said: These are commonly used https://www.quadratec.com/products/24226_X0X0_PG.htm And a write up https://www.naxja.org/forum/showthread.php?t=946575 Seems doable just those seats are expensive Link to comment Share on other sites More sharing options...
DirtyComanche Posted September 30, 2018 Share Posted September 30, 2018 1 minute ago, Swampy said: Seems doable just those seats are expensive Anything worth sitting in will be, if you're buying new. Link to comment Share on other sites More sharing options...
