Best complete lift kit
Hi guys. I'm new to the forum and this is my first project Jeep. Had a 97 Grand previously and picked up a 90 Comanche last fall. She needed lots of TLC but now I'm in the home stretch. I wanted to lift it 3". Not set on the height but I need to replace the suspension and had a free set of decent 30s to run on 17" steel wheels. Any suggestions? I've been looking all over and didn't want an AAL kit and want a quality ride. Any help is much appreciated!
  • Replies 52
I just went through this. MJ specific kits are hard to find but I researched 3" XJ kits from Zone, BDS, Rusty's, Rough Country, Rubicon Express, Skyjacker and Iron Rock Off Road.
I could not find a more complete kit for the money than the IRO XJ 3" Premium Lift Kit which included adjustable UCA/LCA, double shear track bar, shackles, and Bilstein shocks. If you call them, IRO will delete the XJ leafs from your order so you can source your own. Then they knocked another 10% off during their Memorial Day sale and I had to jump.
All the parts are here and they look great. Haven't had a chance to install yet.
I appreciate the feedback. It looks like piecing it together is the best option. I thought I found an OME kit but everyone is saying stay away from RRO. If I went with a 4" lift, what would be the complete part list? I want to do it right the first time.
I spent a lot of time researching this as well. The only complete kits for the MJ I could find were from Hell Creek and Rusty's Off road. I ultimately went with the Rusty's because it came with a few extra things for about the same price. Both are pricy but very well made. Just remember that XJ leaf springs are different and rear XJ parts net less than advertised lift. The front is exactly the same as the XJ so you get the same results as an XJ up front.
I'm leaning towards Rusty's since it seems to be the best for the money from what I'm reading. Luckily I was warned to stay far away from Rocky Road Outfitters. It looks like the only things missing here is a SYE? http://www.rustysoffroad.com/jeep-suspension/jeep-suspension-lift-kits/mj-comanche-86-93-jeep-suspension-lift-kits/rustys-mj-comanche-4-5-spring-pack-kit.html
Due to the long wheelbase of the MJ you won't need an SYE. Maybe a small tcase drop but that comes with this kit. This is the exact kit I got. I upgraded the shocks to the next tier tho and love them. It's a very well built kit. Below is some pictures of my kit with the upgraded shocks.
  • 4 weeks later...
Gonna post pictures when I'm done if I can figure how from my phone. Now that it is 90% complete, I'm seeing highway driving is different. A friend recommended switching gears in the Dana 35 rear. Any thoughts?
Use Tapatalk for posting pictures on mobile. As for regearing a Dana 35... It's a waste. It's a weak axle and as many will tell you, breaks just driving down the street. It will be cheaper to find a better axle to swap with the gearing you want. I myself swapped in a C8.25 from a 97 XJ. This is a cheap axle found everywhere and only requires welding on spring perches to stay spring under. Make sure you get a 95+ C8.25 as it has 29 splines and is comparable to the Dana 44 in strength. If you can get lucky, you can find a Dana 44 that came out of an MJ and swap that. (unlikely but I found one near me shortly after finishing my axle swap so you may get lucky). It sounds like a hard task swapping axles and welding new perches but this was my first time and it was easy and worked out great.
I also wanted to mention that the lift will effect highway driving because there is more surface area, which creates more wind resistance. The beefier axles and better gearing will help with bigger tires but won't do much, if anything for the wind resistance issue.
Okay thanks. Would 3.55 gears be optimal or should I keep looking for something else? Recommendations? This is my daily driver with 31s on it. Mostly highway miles with some light off road in planned.
I would pick up the 3.55 it's what I'm running and will be fine at highway speeds with 31s. You can find them with better gearing but it's unlikely. Most C8.25s I've run into are 3.08 so what you've got there is a good deal.
Well I went with Rusty's kit since it had most of the parts I needed. Just had to buy some sway bar end links and a pitman drop arm. Gonna be finishing it up this weekend.
you don't need or want the drop pitman (unless your track bar bracket includes a comparable drop).
Alright so if I am correct, my Comanche has 3.07 gears in a Dana 35 rear with 27 splines. A 96+ C8.25 3.73 with 29 splines will fit right in? I'm new to this so I'm trying to learn as I go. Sorry for any newbie questions.
it has the correctt width and bolt pattern.  you'll need to move the perches to the MJ's location.  the 8.25 can get a junkyard disk conversion too, so you might want to look into it before spending money on the drums.  :thumbsup:
$760 for Rusty's 4.5" kit, 60 for Rubicon Express extended sway bar end links and adapters, and another 80 for the pitman arm drop. About 900 so far and I would like different axles. Neverending project... As for S051, that's an obscure Halo reference only nerds who read the books would get.
