NC Tom Posted May 3, 2017 Share Posted May 3, 2017 Hey, my 88 Renix era auto shift marker has suddenly stopped lining up with the correct letter. I saw a similar post from a while back on this, but it really didn't address my current issue. I'm wondering why it's off and how to fix it. Thanks Link to comment Share on other sites More sharing options...
schardein Posted May 3, 2017 Share Posted May 3, 2017 If you have the column shifter, the indicator is attached to a small wire with a clip on the end. The wire goes through the plastic gauge housing, and the clip attaches to the lower end of the steering column, where it passes through the dash on the way to the floor. The clip has probably slipped/moved a little. It's a very low tech setup, but it can be difficult to see and understand unless you've had the dash apart. It can also be difficult to adjust because it's hard to get your fingers in there. Link to comment Share on other sites More sharing options...
Dzimm Posted May 3, 2017 Share Posted May 3, 2017 As for the floor shifter, it has a little piece to slide and adjust it. Link to comment Share on other sites More sharing options...
NC Tom Posted May 3, 2017 Author Share Posted May 3, 2017 If you have the column shifter, the indicator is attached to a small wire with a clip on the end. The wire goes through the plastic gauge housing, and the clip attaches to the lower end of the steering column, where it passes through the dash on the way to the floor. The clip has probably slipped/moved a little. It's a very low tech setup, but it can be difficult to see and understand unless you've had the dash apart. It can also be difficult to adjust because it's hard to get your fingers in there. So lower section of dash should be off? Link to comment Share on other sites More sharing options...
NC Tom Posted May 3, 2017 Author Share Posted May 3, 2017 As for the floor shifter, it has a little piece to slide and adjust it. Thanks for chiming in. I have a column shift. Link to comment Share on other sites More sharing options...
Dzimm Posted May 3, 2017 Share Posted May 3, 2017 As for the floor shifter, it has a little piece to slide and adjust it.Thanks for chiming in. I have a column shift.No problem. Give it a month and someone will ask this about the floor shifter. Sent from my HTC6525LVW using Tapatalk Link to comment Share on other sites More sharing options...
schardein Posted May 4, 2017 Share Posted May 4, 2017 If you have the column shifter, the indicator is attached to a small wire with a clip on the end. The wire goes through the plastic gauge housing, and the clip attaches to the lower end of the steering column, where it passes through the dash on the way to the floor. The clip has probably slipped/moved a little. It's a very low tech setup, but it can be difficult to see and understand unless you've had the dash apart. It can also be difficult to adjust because it's hard to get your fingers in there. So lower section of dash should be off? When you shift, you'll notice the whole lower portion of the column moves with the shifter. This is the piece the clip attaches to, on it's lower edge. Best guess is it clips on between 2 o'clock and 3 o'clock as you are looking at it from the driver seat. I would pull the main dash panel off to get a good look. It might be possible to get at it from reaching up under the dash, not sure. Link to comment Share on other sites More sharing options...
schardein Posted May 4, 2017 Share Posted May 4, 2017 I did a quick google search for pictures but nothing. I'm sure someone here has pictures, even if it is only the indicator with wire and clip. Link to comment Share on other sites More sharing options...
HOrnbrod Posted May 4, 2017 Share Posted May 4, 2017 Since you have a Renix - the shift indicator and cable looks like the below. http://comancheclub.com/topic/48960-automatic-steering-column-shifter-indicator/ Link to comment Share on other sites More sharing options...
Airborne Janitor Posted May 4, 2017 Share Posted May 4, 2017 Here's some pics: You can see the cable attached to the needle. Cable and clip hanging under the gauge cluster This is where the clip attaches. Link to comment Share on other sites More sharing options...
NC Tom Posted May 4, 2017 Author Share Posted May 4, 2017 Awesome! :rock on: Thanks for all the replies! Should be able to fix this now! Link to comment Share on other sites More sharing options...
cruiser54 Posted May 8, 2017 Share Posted May 8, 2017 MUCH easier with the lower dash panel removed. Link to comment Share on other sites More sharing options...
Goose_XJ88 Posted June 30, 2017 Share Posted June 30, 2017 Thank you so much for the lower dash removal tip. It made it so much easier to get in there and attach it in the right place. Link to comment Share on other sites More sharing options...
NC Tom Posted June 30, 2017 Author Share Posted June 30, 2017 Thank you so much for the lower dash removal tip. It made it so much easier to get in there and attach it in the right place. Oh yeah. I got mine back-in-whack too. Thanks! Link to comment Share on other sites More sharing options...
