offroader461 Posted July 23, 2007 Share Posted July 23, 2007 Well here are some pics of my new project I'm doing along side my MJ: My MJ chilling in the background :chillin: Specs: 4.0L, AW4, NP231J, D30/35 (3.55's)...2"BB...mostly stock w/ power options :D Mods to come: 4" complete suspension lift 32" BFG from the MJ (its getting longarms and 33" MTR's) flowmaster exhaust (similar to the MJ's) new intake 5.0 injectors open cooling system conversion 97 p/s setup ZJ steering Light rack off the MJ (custom roll bar being made) Protofab front/rear bumpers and sliders Gimme some feedback on it...Thx guys.. Link to comment Share on other sites More sharing options...
RiCeMaN Posted July 23, 2007 Share Posted July 23, 2007 Nice XJ looks clean. will make a great project :) Link to comment Share on other sites More sharing options...
Pete M Posted July 23, 2007 Share Posted July 23, 2007 Quote 97 p/s setup I've not heard of this one. :hmm: Is it an upgrade? Link to comment Share on other sites More sharing options...
offroader461 Posted July 23, 2007 Author Share Posted July 23, 2007 i did it on my MJ when my 87 pump and box were leaking bad...i got the whole setup with only 52K on it for cheap...its the last year b4 they changed all the bracketry..it bolts in and you can get it cheap w/ low mileage..not so much an upgrade but alot better than having to buy new pump, lines, gear box etc...already have an entire setup from another 97 that only had 33K when it was rolled :D Link to comment Share on other sites More sharing options...
offroader461 Posted August 5, 2007 Author Share Posted August 5, 2007 some progress so far: Installed: -rear 2"pro-comp AAL and ES3000 (custom BPE made also) -ditched rear sway bar -99XJ sunvisors -new cd player -new dash bezel -new air box/filter assembly -replaced MAP sensor -replaced motor mounts -resealed valve cover, oil filter adapter rings and rear main still need to do: -V8 ZJ springs up front (level it out) -put on RS5000 in front -change tierod and drag link to ZJ style -change cooling system -change alternator (went out today :headpop: ) -change p/s pump and gearbox ill post up some new pics in the next couple days Link to comment Share on other sites More sharing options...
bhorocks Posted August 5, 2007 Share Posted August 5, 2007 i saw that one on craigslist. looked like a nice but. what you talk him down to? Link to comment Share on other sites More sharing options...
offroader461 Posted August 5, 2007 Author Share Posted August 5, 2007 there is two with the same sticker on the back window...i got mine for my beat up dodge 4x4...it was falling apart on me so: he offered the jeep and cash and he got my truck :D better deal on my part i believe Here it is today: i pulled the valve cover to re-seal it and decided to paint it...i pulled the thermostat and some nasty @$$ brownish-green coolant came out so now i plan on doing the water pump and my open cooling system conversion along with a coolant flush on top... :D Link to comment Share on other sites More sharing options...
offroader461 Posted August 11, 2007 Author Share Posted August 11, 2007 recent developments :D -got the new aluminum 3row radiator installed -water pump installed -water diverter valve plumbed and ready -thermostat done -overflow installed -installed front RS5000's -p/s pump done -installed front light bar -belts and coolant done -trans line fixed Whats left: -put ZJ coils in pics up later tonight GO WHEELING OF COURSE :beerhead: Link to comment Share on other sites More sharing options...
offroader461 Posted August 18, 2007 Author Share Posted August 18, 2007 here are some updated pics: Light bar installed (i know its small but hey its was FREE :D ) Shots of engine: Before :oops: After installing new p/s pump and cooling system :chillin: New heater valve and overflow bottle New poly urethane motor mounts More to come Link to comment Share on other sites More sharing options...
camjeep3 Posted August 18, 2007 Share Posted August 18, 2007 did you get that my off ebay? Link to comment Share on other sites More sharing options...
offroader461 Posted August 19, 2007 Author Share Posted August 19, 2007 the mounts...no a buddy had them in his MJ and switched back to rubber so i got them for FREE :D Link to comment Share on other sites More sharing options...
rockhardzj Posted August 19, 2007 Share Posted August 19, 2007 I've got a 97+ hatch and tails if you want to do a full 97+ exterior swap... Link to comment Share on other sites More sharing options...
offroader461 Posted August 22, 2007 Author Share Posted August 22, 2007 Well i got my new "shoes" for the XJ today...a little close for comfort so here's the question...I'm running a 2" AAL and plan on a 1" shackle to help clear the back but the front has the following: ZJ coils, 1.75 spacer, .75 spacer and factory isolator...is that enought to clear...i plan on removing both front and rear flairs...lemme know Rims: 15x8 w/ 3.75" b/s Link to comment Share on other sites More sharing options...
offroader461 Posted August 24, 2007 Author Share Posted August 24, 2007 here it is sitting on the new tires b4 the ZJ coils....Late last night i installed the ZJ coils last night and extended bumpstops...need to trim a little and install my new swaybar and bushing/endlinks here's a breakdown of my build and prices so far: Parts bought w/ $500 from the guy: -Pro-comp AAL and ES3000 for rear -Water pump -thermostat -radiator -hoses and coolant -p/s pump -XJ visors -ZJ coils Parts bought w/$150 from Grizzy rims: -4 Rockcrawler 297series rims -2000XJ swaybar and endlinks (1" longer) Freebies: :D -4 32"11.50 R15 Kumho M/T -2 RS5000 front shocks (2mnths old) -Front light bar -Dash bezel -seatbelt ends -rear shackles (not installed..havent decided) -40 series flowmaster and new tailpipe Overall i have spent nothing out of my pocket to build her so far :cheers: More to come............... :popcorn: Link to comment Share on other sites More sharing options...
a1awind Posted August 24, 2007 Share Posted August 24, 2007 what is an "open cooling system"? Link to comment Share on other sites More sharing options...
offroader461 Posted August 24, 2007 Author Share Posted August 24, 2007 pre 92 jeeps used a closed cooling system...no radiator cap....they use a pressure bottle that keeps pressure in the system... an open system uses a radiator cap to keep pressure in the system...much better over the plastic pressure cap in my opinion Link to comment Share on other sites More sharing options...
DirtyComanche Posted August 24, 2007 Share Posted August 24, 2007 The plastic bottle and cap do just fine if they are in servicable condition. Typically they aren't though. Link to comment Share on other sites More sharing options...
offroader461 Posted August 24, 2007 Author Share Posted August 24, 2007 yea my original in the MJ blew the cap apart....TWICE...put in the new cap and bottle from Chrysler...and pow that was toast...now its a overflow tank.... :D The XJ i figured that i might as well do it now b4 it strands me in an inconvenient spot Link to comment Share on other sites More sharing options...
offroader461 Posted September 1, 2007 Author Share Posted September 1, 2007 Update: Finally took it on a road trip and it performed very well, things to do next.... -Trim front fender and add my new TJ flairs -Add A-piller pod and Trans Temp guage -change trans fluid -add HD trans cooler -totally clean up interior -add exterior lighting Link to comment Share on other sites More sharing options...
JeepcoMJ Posted September 1, 2007 Share Posted September 1, 2007 :D keep up the good work! Link to comment Share on other sites More sharing options...
offroader461 Posted September 4, 2007 Author Share Posted September 4, 2007 here it is after the TJ flair install: And the shot as she sits today: Link to comment Share on other sites More sharing options...
offroader461 Posted September 10, 2007 Author Share Posted September 10, 2007 Got my Gibson muffler installed yesterday...ill post up a pic and a soundclip of it for everyone to hear and see :D Link to comment Share on other sites More sharing options...
1999MJ Posted September 11, 2007 Share Posted September 11, 2007 for some reason those TJ flares don't look right on there. Link to comment Share on other sites More sharing options...
offroader461 Posted September 11, 2007 Author Share Posted September 11, 2007 they didnt look right to me at first but they grew on me...i still have to get the marker light in and do some more touchup but they look better in person than those pics show Link to comment Share on other sites More sharing options...
offroader461 Posted January 19, 2008 Author Share Posted January 19, 2008 Well thx to a fellow MJ'r i now have the last remaning pieces to lift my XJ up more: RE 3.5" superflex complet rear spring pack(THX BHOROCKS) RE extended sway bar links(ALSO THX BHOROCKS) RC 3" springs Daystar 1.75 spacer MJ rear shackles Pro-comp LCA RS9000's with BPE's Hopefully in the next 2 weeks i will have this lifted also...ill get pics of it up soon!! Link to comment Share on other sites More sharing options...
