Ecu/Ecm
I went to the junkyard today to grab a ecu/ecm for my 87 Comanche, and in the yard was a 87 Comanche but when I pulled the ecu/ecm out someone had wrote on it "90 xj 4.0 cruise auto" will this still work in my 87? There's twp numbers on it one is S101140203 B and the other is 56006078
Something doesn't add up. ALL the ECUs in the factory parts manual for '87-'90 start with 5300, not 5600. None of them end with 6078.
for an '87, the manual tranny ECU should be 5300 5407 and for an automatic it should be 5300 5406
