93 grand 5.2 to 4.0 swap?????
jayzauto
K guys I got a 93 grand with a 5.2 and the Quadro Trac aw4 tranny. Will a 4.0 out of an MJ bolt up and how much modifications are involed?
An AW4 was never bolted behind a 5.2L V8.
Besides that, you can't go from a V8 to the L6 unless you swap the wire harnesses, ECU, fuel lines, etc. etc.  Not worth the hassle, even if you had a donor ZJ to pull from.
