Double Six Posted August 5, 2016 Posted August 5, 2016 What causes brand new fuel pumps to Quit working? is it the trash and rust that's in the tank? I had one put on 900 miles ago and it has quit already . Relay is working but pump isn't. Thanks for your help.drove it home tuned off ignition and it han't started since.Ran fine coming home. :???:
dustyinthedirt Posted August 5, 2016 Posted August 5, 2016 May sound like I'm being a @$$ but have you checked all your electrical connections?
gogmorgo Posted August 5, 2016 Posted August 5, 2016 If there is crud in the tank plugging it up, it would also be showing up in the filter. Pop it off and dump it out, just to see. Probably wouldn't hurt to change it either if it's been a while. Something that also happens sometimes is that the rubber hose in the tank is worn out, and the stress of pulling it off and onto the new pump can cause it to fail, so the pump will still run but just pump right back into the tank. What brand fuel pump did you get? Some of the parts-store brands have been known to be problematic.
cruiser54 Posted August 5, 2016 Posted August 5, 2016 Here's the problem: Nobody but Bosch makes a good pump. Airtex is the worst and they're now making the pumps for Carter. That PFP or whatever from O'Reilly is a huge piece of garbage.
Double Six Posted August 5, 2016 Author Posted August 5, 2016 I've changed the filter twice in that 900 miles .it wasn't completly stopped up but got a lot of rusty colored fuel out of it . I don't know what kind of pump it is.the shop where I bought it told me that was the second one he had put on it. you would think he would have pulled the tank and cleaned it out ,but I 'm sure he didn't do that .He was just trying to get it to run, so I could here it run before I bought it. He was selling it for someone else.
cruiser54 Posted August 5, 2016 Posted August 5, 2016 I've changed the filter twice in that 900 miles .it wasn't completly stopped up but got a lot of rusty colored fuel out of it . I don't know what kind of pump it is.the shop where I bought it told me that was the second one he had put on it. you would think he would have pulled the tank and cleaned it out ,but I 'm sure he didn't do that .He was just trying to get it to run, so I could here it run before I bought it. He was selling it for someone else. It's probably not the tank being dirty. The pump has a screen on it.
Double Six Posted August 6, 2016 Author Posted August 6, 2016 it's an 86 model with the 2.5 On the bracket that holds the 3 relays there is a metal relay that has two electrical conectors that go on the bottom. it is held on the bracket with a small bolt .it looks sort of like a starter solenoid .in the manual i don't see anything that looks like it .anybody know what it might be.
cruiser54 Posted August 6, 2016 Posted August 6, 2016 May sound like I'm being a @$$ but have you checked all your electrical connections? Not sounding like an @$$. Perfectly good suggestion.
Minuit Posted August 6, 2016 Posted August 6, 2016 Do you have a test light? Check for power at the fuel pump connector. Check the ground behind the left (I think it's the left anyway) tail light. That's where the fuel pump grounds. If you bought an Airtex brand pump there definitely is trash in your gas tank... the fuel pump. Those pumps tend to live short and very loud lives. Go with a Bosch, even if you have to do a little work to make it fit.
cruiser54 Posted August 6, 2016 Posted August 6, 2016 Do you have a test light? Check for power at the fuel pump connector. Check the ground behind the left (I think it's the left anyway) tail light. That's where the fuel pump grounds. If you bought an Airtex brand pump there definitely is trash in your gas tank... the fuel pump. Those pumps tend to live short and very loud lives. Go with a Bosch, even if you have to do a little work to make it fit. Excellent advice^^. The Bosch is different but has simple adapters with it to make it fit easily. As for the fuel pump ground, I would just perform the procedure in the link below no matter what. Every Comanche and Cherokee owner should do it. http://cruiser54.com/?p=249
HOrnbrod Posted August 7, 2016 Posted August 7, 2016 For the craptastic left tail lamp ground, I just ran an additional ground wire from the grounding screw behind the lamp down to a bumper bracket bolt.
Double Six Posted August 13, 2016 Author Posted August 13, 2016 Got the test light out ,climbed under truck pulled the fuel pump connector harness apart where it plugs in to another plug .I had power there.I checked the orange wire where it connects to the pump on the outside near the lines and had power there.So I am assuming the pump was one of the cheap ones that was not any good.I am ordering a Bosch from rock auto and will see if that was the problem.
