What rims and what center caps?
My truck came with these rims and I've always wanted center caps. Anyone have any idea what they are and what caps will work for me? Thanks y'all 4c51f93fd52bcb12ab9c3d85631d176e.png57102368332c7de1689ba20fe0acfa8c.png
Same rims in the different pics. Just different stages of my build
Could also be Pro-Comp soft 8's ....
The wheel should have a stamp on the inside with all the needed details.
Center caps come in all sorts of sizes and styles. A tire shop should be able the help sort it all out.
Sent from my SGH-I337M using Tapatalk
http://www.quadratec.com/category/Jeep+Steel+Wheels/136/
Could also be factory YJ wheels:
Might could get item 2, those Jeep Covers attach with a screw, just would need to carefully drill 5 holes per rim big enough for the mounting hardware. 1/4" ish screw?  I have a couple sets and likely won't use them because i like my Turbines better
12057453774_321b7eae2e_o.jpg1876352509063 by Blue88Comanche, on Flickr
you can kinda see the mounting holes in the picture below
12057063175_dcf8e8b04a_o.jpg1876141503788 by Blue88Comanche, on Flickr
