8.25...maybe 8.8
I want to replace the D35 under my 89 MJ with somthing stronger. I've looked around for an XJ or MJ Dana 44...but people want a mint for them. So...I'm probably going to go with a 29 spline 8.25 or a ford 8.8. The 8.25 is easier, but the 8.8 is stronger. I'm probably going to run 33"s. Does anyone have any advice?
Either axle is a good choice. Although most all of the 8.25s you'll see will be 3.55 and al are drums. 4.10s and 3.73s are common in the Explorers and 95+ will have disks. If you go 8.8, be sure to get the calipers with the axle. The core charge on them is $30-40 per side.
I'm swapping to an 8.25 out of a 98 XJ. I just need to find out more about the leaf perches width and location differences between an XJ and MJ.
An XJ is 43.5" centre-centre, give or take a bit (they're metric.) And they are SOA.
A MJ is 42" centre-centre and SUA.
didnt the dakota's come with disc brake's all the way around. :hmm: I'm suspecting that they did but could be wrong also. And at lease there are a bunch out there to choose from Between chrysler & ford.
Is there any 8.25's out there with discs on them to upgrade in the future?
I'd like to go with discs, but drums will do the job for a while...
AFAIK, yes, but all are the 5x5 bolt pattern.
A guy could try using crown vic brake parts. They're easy to get and seem to bolt up to random things most of the time...
8.8 swap is not difficult, you just need the mopar spring perches and the spicer flange adapter for the pinion.
brakes are awesome, I can lock up all 4 when I please.
8.8 get's my vote, simply because of the disc brakes.
some 1" wheel spacers takes care of the width issue.
no dakota have always been drum brakes except the R/T
:cheers: in 03 this option was available for all models not just the R/T model here is the link http://consumerguideauto.howstuffworks.com/2003-dodge-dakota.htm just for future references. just wondering now if any one has done this swap :dunno:. a good play by play :wrench: would cool and keeping it in the family :brows:
I have a ton of crown vic's to my avail. I think my buddy has some parts laying around too.
Dakotas don't use a 5 on 4-1/2" lug bolt battern, though. Not a good choice.
Well, wouldn't you still use the stock shafts if at all possible?
Also, I am willing to bet that you could do the caliper bracket, and caliper, and then do so research and find rotors that would be the correct fitment.
Orrrr you could just go buy an Explorer rear axle and have disks and strength and the right bolt pattern and without any hunting around for matching parts. :dunno:
:teehee:
Would you feel safer in your sexuality if it wasn't pink in color? :roll: I didn't make the dang thing. Get someone to change the color and I'll upload it, just for you. :teehee: :cheers:
But back to the topic at hand, the Exploder axles are all over the place. Just go find one. Or email me and I'll sell you one and ship it to your door. :thumbsup:
It ain't the pink thing, its the ghey hand thing. No guy covers his mouth when he laughs, not that I know of at least, but I'm not from Michigan. Oh, and I got lot's of sploder's at the JY. Just get the keys for the front end loader, toss the forks under it, lift it, cut mounts, and toss on the trailer, put sploder back on the ground.
  • 3 weeks later...
Old Chrysler 8.75- Correct width, correct bolt pattern, and can carry up to a 502 gear ratio. I like mine. Oh yeah a drop out third member also.
good luck finding one of those.
the muscle car guys have stripped them all in my area.
