ARareBreed Posted May 16, 2016 Share Posted May 16, 2016 Just want to spread the word of Core Shifters of whom is selling a Hurst shifter setup for the AX15. It's advertised to reduce the throw by ~30%. I just got mine for $270. I know it's a bit much but it has awesome reviews, I cannot wait! I'll update the thread. Link to comment Share on other sites More sharing options...
Jackrabbit41 Posted May 17, 2016 Share Posted May 17, 2016 I've been wanting to try one of them. Seems like it'd be cool Link to comment Share on other sites More sharing options...
yellaheep Posted May 17, 2016 Share Posted May 17, 2016 I have one in my '91 Eliminator. Dunno how I'd lived without it. Amazing upgrade, worth the cabbage. :thumbsup: Another thread on Hurst / Core shifters exists here: http://comancheclub.com/topic/43862-core-short-throw-shifter/ Link to comment Share on other sites More sharing options...
xjrev10 Posted May 17, 2016 Share Posted May 17, 2016 I have one on my nv3550! Very nice piece and nice shifting too! Link to comment Share on other sites More sharing options...
Minuit Posted May 17, 2016 Share Posted May 17, 2016 If members of the notoriously cheap-@$$ ComancheClub are praising a $300 shifter, it must be good. Link to comment Share on other sites More sharing options...
Jackrabbit41 Posted May 17, 2016 Share Posted May 17, 2016 Are they easy to install? Do you have to pull the tranny? Link to comment Share on other sites More sharing options...
yellaheep Posted May 17, 2016 Share Posted May 17, 2016 Are they easy to install? Do you have to pull the tranny? You do not. Remove the center console if equipped, then the inner shift boot. Top loader design, 4 bolts holding the shifter base retainer to remove, go to neutral, pull old shifter out, clean gasket surfaces, apply new gasket material, install new shifter, bolt it down , re-install boots and console. Done! If members of the notoriously cheap-@$$ ComancheClub are praising a $300 shifter, it must be good. Yep. One of the top 10 best MJ mods for certain. Link to comment Share on other sites More sharing options...
FrankTheDog Posted May 17, 2016 Share Posted May 17, 2016 Just what I need, something to make bang shifting even easier. Lol Link to comment Share on other sites More sharing options...
Jackrabbit41 Posted May 17, 2016 Share Posted May 17, 2016 Sweet. I'll get one once I started workin again this summer Link to comment Share on other sites More sharing options...
Megadan Posted May 17, 2016 Share Posted May 17, 2016 Had one ever since I did my AX-15 swap a couple of years ago. They are worth the money. Link to comment Share on other sites More sharing options...
Jackrabbit41 Posted May 17, 2016 Share Posted May 17, 2016 Could someone link the hurst one? I can only find a B and M one Link to comment Share on other sites More sharing options...
Megadan Posted May 17, 2016 Share Posted May 17, 2016 Direct from the source. Cheapest price you will find.http://core-shifters.com/products/core-hurst-shifter-1989-1999-jeep-cherokee-comanche-6-cyl-w-ax15-5-speed Link to comment Share on other sites More sharing options...
Jackrabbit41 Posted May 17, 2016 Share Posted May 17, 2016 Direct from the source. Cheapest price you will find. http://core-shifters.com/products/core-hurst-shifter-1989-1999-jeep-cherokee-comanche-6-cyl-w-ax15-5-speed Thanks! Only problem is my ax15 needs a rebuild haha. Maybe I should spend the money on a new tranny instead of this but whatever Link to comment Share on other sites More sharing options...
acerocknroll Posted May 17, 2016 Share Posted May 17, 2016 I can confirm that this shifter does indeed own bones Link to comment Share on other sites More sharing options...
Jackrabbit41 Posted May 17, 2016 Share Posted May 17, 2016 I can confirm that this shifter does indeed own bones So dope Link to comment Share on other sites More sharing options...
Stacks Posted May 25, 2016 Share Posted May 25, 2016 Why buy one when you can build/modify your shifter or a spare one in about an hour? I did that on my AX15 in my TJ. I used a 1" steel spacer between the trans and shifter and cut the ball off the stock shifter and added 1" to it's length. Easy welding job even for me who isn't even a novice welder yet. It's been running in my TJ for15 years now. You can change the ratio percentage by changing how much length you add and using a spacer of the same length. ;) Link to comment Share on other sites More sharing options...
Megadan Posted May 25, 2016 Share Posted May 25, 2016 In my case, because I didn't have a shifter to start with, and the time spent trying to find one (manual Jeeps are a rare find around here) and then modding it wasn't worth as much as being able to order one. Link to comment Share on other sites More sharing options...
