Location
Post Falls, ID
Interests
Jeeps hunting fishing shooting reloading electronics photography ham radio leather work wood working architecture
Contact Methods
Yahoo
kg7rq
Stacks's Achievements
Comanche Aficionado (4/11)
Why buy one when you can build/modify your shifter or a spare one in about an hour? I did that on my AX15 in my TJ. I used a 1" steel spacer between the trans and shifter and cut the ball off the stock shifter and added 1" to it's length. Easy welding job even for me who isn't even a novice welder yet. It's been running in my TJ for15 years now. You can change the ratio percentage by changing how much length you add and using a spacer of the same length. ;)
http://www.rockauto.com/RSS/vehiclefeeds.php?carcode=1181821&m=wc&l=en&html=true
You guys live in the wrong place when it comes to having windshields replaced. Just had mine replaced in my MJ about 2 weeks ago. Cost me $170 for a Cherokee windshield and trim/gasket and he did it in my garage to boot. No more CHROME trim!!!!!!!!!!!!!!!!!!!!!!!!!!!! :banana:
Help with engine removal, manual transmission
Stacks replied to teamsmith's topic in MJ Tech: Modification and Repairs
The shield fits between the block and the flywheel so yes those two bolts have to come out too. -
Ball joint.......what is this?
Stacks replied to Jeep Driver's topic in MJ Tech: Modification and Repairs
That is what I replaced to correct the camber issue on my MJ. It was far cheaper than an offset ball joint, $25 vs $75. The one I got was steel not brass though and the one I removed was steel. Takes a semi special socket to remove and lots of horse power in my case. -
I did not say not to upgrade from a D35. I put a D44 in my MJ wheel the wheel bearings went out on the 35. Cheaper to put the 44 in than replace the bearings. It comes down to we will just have agree to disagree. I apologize to Kenny K. I should have made my initial post here as a new topic.
OK... I am going to create some hate and discontent here!!!! I am sick and tired of people bashing the D35 that is in our MJ's. I ran the D35 on my TJ, locked both ends with 33's and 4.10's for 14 years. NEVER broke a thing on the D35 in 120,000 miles. I took it to Moab twice. I've run mud, rocks, woods roads and no problems. If you drive a rig with a D35 like a white man and realize it does have limitations it will live just fine. The limitations I've come to realize on the D35 is max gears and tires are 4.10's and 33's. You put 35's on it and or go to 4.56's or higher you are definitely asking for trouble. The other limitation is NEVER let the wheels begin to hop. You can break a D35 with 3.07's if you let it hop. The reputation of a D35 being weak is less caused by the D35 than it is drivers trying to make it do what it was never intended to do by driving like an idiot!! Nuf said.
Check my build thread, first page and scroll down to first pic labeled after lift then up on pic to see a before pic. Hope that helps. http://comancheclub.com/topic/33955-89-mj-work-truckdd-to-dd-and-4-wheeling-whenever/
A couple very noob questions
Stacks replied to Blue88Comanche's topic in MJ Tech: Modification and Repairs
Welcome to the club! :laughin: -
'89 MJ-Work truck/DD to DD and 4 wheeling whenever!
Stacks replied to Stacks's topic in Member Projects: Your Comanches
Long overdue on an update... my apologies. I have about 3000 miles on the new motor. Still fussing with timing and advance curve a bit. Broke down and bought a wide band A/F ratio gauge. I have all my 'extra' gauges mounted but they need to be cleaned up some before I can bring myself to show them to you guys. It was very much function over form initially! lol Yes... I'll admit I'm a gauge freak. I've added 6 more gauges besides the factory ones. Several are duplicates but monitor from different locations on the engine. I've added a vacuum gauge, A/F gauge, mechanical oil pressure gauge, mechanical engine temp gauge, mechanical trans temp gauge, and a volt meter that reads straight from the battery. I've got the scoop blocked off for the winter to keep snow out of the engine compartment. Just used black duct tape but will figure something out that is more permanent for the purpose. Also plan on re-doing the bolts that hold the scoop on. Want to run them up from the bottom and use brass acorn nuts on the top just for cosmetics. The rust issues in the floor boards are fixed. Just looked for pix but I guess I didn't take any. One of the next projects is to build a console cuz the Hurst shifter that came with the trans sits quite far back, the rear of it's housing cover is between the front edge of the MJ bucket seats. I need to re-do the front axle mechanical disco. I prefer using it cuz I like to use 2 Lo for putting along on woods roads. Been looking for rear fender well liners but may just sand blast them and use under coating or Herculiner or some such. Still contemplating going to 3.73's. My peak torque is now a bit higher than before and I do have some 31x10.50's I could put on it later. Actually the mags and tires off my TJ. :) Working on ideas for skid plates for engine/trans/Tcase. Looking at adding more diamond plate below the front bumper to help protect the steering stuff etc. Most of this is warmer weather stuff. Yeah... I know... I've become a wuss when it comes to working in an icy cold garage unless it's absolutely necessary!!! lol There's also the issue of all my other hobbies. Been fussing with my little 7x10 mini lathe, reloading ammo for the coming gopher season, playing with the ATVs and working on the mechanical drawings of the stuff I've built for the MJ etc. And... working on the design of my version of a Gerstner wood machinist's tool box. Whew... being retired sure can keep a body a little busy!! lol Hope everyone has a great spring!!! Larry -
PFCLeist is correct. You are tuning the antennas length. SWR is a ratio of transmitted power vs reflected power. The power is reflected from the antenna back towards the radio because the impedance of the antenna and the radio output circuits don't match. The procedure isn't difficult but does require as SWR meter. It's far easier to explain by talking with someone. PM me and I can walk you thru the procedure and the why's and why not's of what needs to be done. I'm a ham, first licensed in 1978. Larry
Why get so complicated? Use a bike shifter or brake cable actuator or use a relay controlled solenoid and just open the throttle with it to the rpm you want. I used the solenoid set up on my TJ for using the on board welder and the bike cable set up to bump the idle up when using the on board air on the MJ. Simple s good. -
Raster graphics, gif, jpg, bmp, etc can be converted to vector graphics via many programs. I have used one called Inkscape. It's a free download and conversion is as simple as opening a jpg image file and re-saving it as a vector graphic file such as .svg which seems to be a common vector format. I've tried saving to a .dxf format with relatively poor results for some reason. Might be worth a try.
