Need to make light brighter using a relay, help plz
I had problems for a long time with my reverse lights and I finally found out the problem. Reverse light switch. Fixed it. But I cut my drivers side rev. light socket  because i had a rats nest of wiring from last owner and i lost that socket... I had a CATapiler light in my tool box and i wired it up to the reverse light wiring and it works. Except its really dim.
I made my headlights brighter by upgrading the harness and they are 3x brighter then stock wiring. I know it uses a relay to have 12v to the lamp but I am a noob with relays if its not in a premade harness.. can someone explain to me how i can do the same thing to my CAT lamp please?
JCR rear bumper, and fog lamp tag lights.
Running a "big halogen" lamp @ 55W minimum, probably more, over maybe 30' of puny factory 18 AWG wiring plus the extra you have added on through multiple splices is a real bad idea. The factory backup lights were small 1156 bulbs and the factory wiring was gauged to barely run those at minimum specs. In order to use a relay on that halogen light you have, you will need to run a 10-12 AWG minimum fused new wire from the up front battery to power the load side of the relay to your new halogen lamp. Not practical. I'd stick a low amp but bright LED cube on it before you smoke the factory backup light circuit rather than run that halogen with a new relay..
Agreed. And there is certainly the possibility that it's a 24-volt light.
I'm going to be scrapping a couple of XJs this Spring. I can easily cut out a back-up light socket for you -- I don't have any plans to save the chassis wiring harnesses.
Id probably pick up $60 Autozone led cubes if i can't get this lamp brighter.
Would a led cube wire up to that positive negative wiring? I never delt with led yet.
Thankyou for offering sockets but I'm about to have 3 addresses with 2 months. It would be this summer before I can receive anything in mail. I may still have the socket, I have alot of junk in my tool boxes to sort threw.
I agree, except for the "not practical" part.
Here's what I'd do:
-verify that it is indeed a 12v lamp by hooking it straight up to the battery to see if its performance perks up; if it doesn't then its likely a 24v lamp.
-run your new, fused 12ga power wire to terminal 30 of your relay
-using another section of that nice new wire, connect terminal 87 to one side of the lamp
-ground the other side of the lamp (a good ground)
-tap into your factory backup light circuit and run it into terminal 86
-feed terminal 85 to ground
Locate your relay near your backup light switch and make sure your connections are water tight.
Should work like a charm with no additional stress on your poor backup light switch  :thumbsup:
you can get decent LED "work" lights from walmart for $15 and swap it out with the CAT light in under 10min.
ooooor spend $10 on a auto store relay,$5 on spade terminals and $10 on wiring and then an hour to wire it properly for your current light
