shelbyluvv Posted February 22, 2016 Share Posted February 22, 2016 On 2/22/2016 at 2:56 PM, Doc. said: If there is no reason for the stabilizer other than to band aid a problem, why did the factory put it on there? To bandaid a problem Link to comment Share on other sites More sharing options...
shelbyluvv Posted February 22, 2016 Share Posted February 22, 2016 Here is a good read on the purpose of a steering stabilizer http://txtire.com/blog/view/steering-stabilizers-the-truth Link to comment Share on other sites More sharing options...
ParadiseMJ Posted February 24, 2016 Share Posted February 24, 2016 On 2/19/2016 at 8:13 PM, Gene said: I had the factory alloy wheels, and had trouble getting them balanced well, local shops did not like adhesive weights. So I switched to junkyard steel rims, remounted the old tires, and had them balanced. Death wobble gone and has not come back in 20 years! Gene I did blame the fact that the wheels (the factory aluminum spokes) don't have a place for weights on the front of the wheel. The guy that finally balanced them did use stick on weights...like 3 small ones. I since got some steelies, not a problem anymore. I think the tire balance and worn...even slightly can cause a good shimmy at 55-60 that tends to go away at 65-70, depending on the road... Link to comment Share on other sites More sharing options...
Kalal92 Posted April 5, 2016 Author Share Posted April 5, 2016 Could the lower and upper control arm bushing's contribute to that death wobble if they are somewhat corroded? Link to comment Share on other sites More sharing options...
Kalal92 Posted April 5, 2016 Author Share Posted April 5, 2016 https://vimeo.com/161568908 Link to comment Share on other sites More sharing options...
gogmorgo Posted April 5, 2016 Share Posted April 5, 2016 Can rubber bushings corrode? Link to comment Share on other sites More sharing options...
HOrnbrod Posted April 5, 2016 Share Posted April 5, 2016 On 4/5/2016 at 2:47 AM, gogmorgo said: Can rubber bushings corrode? Only in Canada. :rotfl2: Link to comment Share on other sites More sharing options...
91Pioneer Posted April 5, 2016 Share Posted April 5, 2016 On 4/5/2016 at 2:53 AM, hornbrod said: On 4/5/2016 at 2:47 AM, gogmorgo said: Can rubber bushings corrode? Only in Canada. :rotfl2: It's funny 'cause it's true :thumbsup: :Canadaflag: Link to comment Share on other sites More sharing options...
DirtyComanche Posted April 5, 2016 Share Posted April 5, 2016 On 4/5/2016 at 2:47 AM, gogmorgo said: Can rubber bushings corrode? Depends how far you stretch the word corrosion. They are oxidizing just sitting on the workbench. Either way they certainly can deteriorate. Link to comment Share on other sites More sharing options...
Kalal92 Posted April 5, 2016 Author Share Posted April 5, 2016 On 4/5/2016 at 3:55 AM, DirtyComanche said: On 4/5/2016 at 2:47 AM, gogmorgo said: Can rubber bushings corrode?Depends how far you stretch the word corrosion. They are oxidizing just sitting on the workbench. Either way they certainly can deteriorate. Deteriorate is a better way to describe it! Link to comment Share on other sites More sharing options...
Eagle Posted April 5, 2016 Share Posted April 5, 2016 On 4/5/2016 at 2:46 AM, Kalal92 said: https://vimeo.com/161568908 Video doesn't play for me. What's it supposed to show? Link to comment Share on other sites More sharing options...
Megadan Posted April 5, 2016 Share Posted April 5, 2016 The Video shows his death wobble, which is pretty bad.IMHO, I would replace the track bar as a starting point. They aren't too expensive and pretty easy to install. One way to check it is If you have a buddy that can help you, have him turn the wheel back and forth while you look at the upper and lower mount points for play. If it's the bottom bolt, you should see it move back and forth a little. Sometimes the mount hole ends up out of round and allows play even with it tightened down. Upper mount being a tie rod should be pretty obvious to see. Also check to make sure the track bar bracket mounted to the frame doesn't move at all. I discovered mine was ever so slightly loose and was causing a minor shake at highway speeds. I removed the bolts, thread locked them, and torqued back down, and no more shake. Link to comment Share on other sites More sharing options...
