jayzauto Posted December 23, 2015 Share Posted December 23, 2015 How hard would it be to swap a gm 2.8 outta a Comanche and put in a fuel injected 4.0 Link to comment Share on other sites More sharing options...
HOrnbrod Posted December 23, 2015 Share Posted December 23, 2015 Pretty hard. http://comancheclub.com/topic/39492-the-truly-custom-86-mj-custom/ Link to comment Share on other sites More sharing options...
gogmorgo Posted December 23, 2015 Share Posted December 23, 2015 It's been done. Google should pull up a few write-ups. It's the same as doing it in an XJ. The firewall and radiator supports will need modification. Link to comment Share on other sites More sharing options...
HOrnbrod Posted December 23, 2015 Share Posted December 23, 2015 Google? What's that? :shake: Link to comment Share on other sites More sharing options...
Pete M Posted December 23, 2015 Share Posted December 23, 2015 an easier swap is the 3.4 from a camaro/firebird. it reuses all your exhaust/accessories/radiator/etc but is a superior engine inside (better quality parts, better oiling passages, better everything). plus the fuel injection system is pretty much stand-alone and can be swapped into the MJ fairly easily. :thumbsup: Link to comment Share on other sites More sharing options...
Doc. Posted December 23, 2015 Share Posted December 23, 2015 an easier swap is the 3.4 from a camaro/firebird. it reuses all your exhaust/accessories/radiator/etc but is a superior engine inside (better quality parts, better oiling passages, better everything). plus the fuel injection system is pretty much stand-alone and can be swapped into the MJ fairly easily. :thumbsup: But does it have more power than a 2.8? Wait, what am I thinking, pretty much everything does. Link to comment Share on other sites More sharing options...
onlyinajeep726 Posted December 24, 2015 Share Posted December 24, 2015 Pretty hard. http://comancheclub.com/topic/39492-the-truly-custom-86-mj-custom/ Woo-hoo! Someone referenced my build! :rock on: Okay, my ten seconds of fame is over. :roll: :nuts: Link to comment Share on other sites More sharing options...
Pete M Posted December 24, 2015 Share Posted December 24, 2015 there's certainly more poser to be had, especially if you bring over the EFI. :D just don't reuse the stock MJ carb if possible. that thing just plain sucks. Link to comment Share on other sites More sharing options...
HOrnbrod Posted December 24, 2015 Share Posted December 24, 2015 Pretty hard. http://comancheclub.com/topic/39492-the-truly-custom-86-mj-custom/ Woo-hoo! Someone referenced my build! :rock on: Okay, my ten seconds of fame is over. :roll: :nuts: And a fine build it is. :cheers: Link to comment Share on other sites More sharing options...
Crash Posted December 24, 2015 Share Posted December 24, 2015 Then you will tell yourself.. "Could have had a V8"! Link to comment Share on other sites More sharing options...
Pete M Posted December 24, 2015 Share Posted December 24, 2015 Then you will tell yourself.. "Could have had a V8"! along with a completely new everything else inside and under the truck. :D Link to comment Share on other sites More sharing options...
onlyinajeep726 Posted December 25, 2015 Share Posted December 25, 2015 Pretty hard. http://comancheclub.com/topic/39492-the-truly-custom-86-mj-custom/ Woo-hoo! Someone referenced my build! :rock on: Okay, my ten seconds of fame is over. :roll: :nuts: And a fine build it is. :cheers: Thanks, Don! :D Link to comment Share on other sites More sharing options...
A-man930 Posted December 26, 2015 Share Posted December 26, 2015 +1 on the 3.4 swap. The truck variant of the 2.8 is pretty well the exception to an otherwise excellent engine series. An Fbody 3.4 should be cheap and easy to find and would be sooooo much easier than a 4.0. Plus if you're feeling froggy you could grab the aluminum heads off a later GrandAm and pick up some nice gains. Link to comment Share on other sites More sharing options...
johnj92131 Posted December 26, 2015 Share Posted December 26, 2015 +1 on the 3.4 swap. The truck variant of the 2.8 is pretty well the exception to an otherwise excellent engine series. An Fbody 3.4 should be cheap and easy to find and would be sooooo much easier than a 4.0. Plus if you're feeling froggy you could grab the aluminum heads off a later GrandAm and pick up some nice gains. Yes, lots of cool high tech upgrades from the factory on later versions of that 3.4 family. The 4.0 basically stopped with the introduction in 1991 of the High Output 4.0 Link to comment Share on other sites More sharing options...
