Any WK2 Opinions?
Automan2164
It sad to say, but the old XJ is finally starting to show its age. My '97 Country has treated me kindly over the past few years, but it's time to poop or get off the pot. I don't have many vehicles in my radar, but the WK2 is one of them. I miss my old ZJ, with the room and features. I know a WK would get me a lot of nice features, but then I would have the old V6 as an option, and I really don't like the way they look. The WK2 has the Pentastar in the lineup, as well as just being a (IMHO) a damn good looking vehicle.
I am going to shoot for a price range with 20K being the top end. I know in doing this I am going to end up with something with higher miles, but that really doesn't concern me much. Auto trader says 20K price range is doable, but I want to ask my friends here if they have any opinions on it. I would like to find a Limited or an Overland, because if I am going to have a car payment, it's going to be loaded. I've found some overlands with 100K right around 20K.
I guess my only questions really come down to drivetrain and reliability. I hear great things about the 3.6, and a couple have popped up with the 5.7. Both seem to have similar mileage, so I'm not terrified of that. I would be leaning towards the 3.6 just due to the rumor mill. Are the transmissions better than the Chrysler transmissions of yesteryear? Any other big problems or things to look out for?
Thanks in advance,
Rob
From my experience, the Pentastar 3.6 is a great engine. We had a 2012 JK, the first year for the 3.6, and now have a 2015 JK. Some of the 2012 and early 2013 engines had a valve/head problem especially on the left side that was covered under warranty, but we put 50K on the 2012 with no problems. Our daughter in the USAF drives it now, and it's still problem-free. The 6-speed auto is great and it's fun slap-sticking through the gears when accelerating or decelerating. Mileage is decent (19-21), but not great with the boxy JK.
I'm ASSuming the WK2 drive train is the same as the JK's. One thing that really makes a very noticeable difference is gear ratio. Both the 2012 and 2015 have 18" tires. The gear ratio on the 2012 with auto was the standard 3.21 and it was kind of doggy off the line. I ordered the 2015 with 3.73's, and the lower ratio made a huge difference when accelerating. Mileage remained about the same for both. So if you have a choice, get the numerically higher gear ratio if possible especially if your tires are or will be larger than stock. You'll like it more.  :thumbsup:
I have a '14 WK2. It has the 8sp Auto so I can't comment personally on the 5sp auto in 11-13 era but I am thrilled with mine so far (19k trouble free miles). I'm not aware of any big issues with the 3.6 and 5sp. I'm sure you know it has a shared platform as the Merc ML (which I think is a good thing) and it drives with an air of refinement that I think fits the upmarket pedigree. I probably wouldn't get the air suspension that is offered in the Overland if you can help it; probably more trouble with higher miles and expensive to fix.
The earlier WK2's had quite a few recalls and TSB isues, the vast majority are nuisance really, just a minor few safety related. I'd buy your used one from a Jeep/Dodge/Chrysler dealer, get with a trustworthy tech/service writer who will print out all the recals nd TSB's, bring those to the negotiation and as a condition of the sale, insist that ALL get addressed before delivery.
Our '12 SRT8 has been in the shop more than any of our new vehicles prior. Some were SRT8 specific (rear magnetic shock defective, front LED shorting out/flickering, roof rack delete strip breaking at mounting screws) but here's a list of the recall/TSB stuff we've had addressed:
Recall- sun visor vanity mirror wire short/fire hazard
Recall- fuel pump wiring harness short/fire hazard
Recall- Brake master cylinder push rod corrosion issue
TSB's:
-squeaking sun roof track/assembly (replaced entire assembly)
-front bumper fascia coming un-snapped around headlights/fenders (lengthy procedure to improve snap tabs)
-water leak around rear wiper assembly (replaced rubber seal)
-loose splash pans and skid plates (tightened fasteners)
Warranty:
-carbon fiber/wood dash trim coming loose and warping (replaced 2 sections of carbon fiber dash trim)
-horn hard to press/honk at steering wheel (replaced airbag assembly -better but not by much)
-batteries in tire pressure monitors low volt. (All replaced)
I think that's all of it.....
Wife hit a dog with it so the front bumper cover and lower grill trim had to be replaced....I had to print out the bumper/fascia TSB to give to the dealer body shop.
Mechanically, it's been the most reliable vehicle we've owned (knock on wood....lol) it's never been towed.
Thanks all for the great input. Sounds like a solid vehicle, like something I would want to pick up. I found one at another local Municipality up for auction. It's a 2011 Laredo with the 3.6 and 113K. They sold another admin unit WK2 last month with new tires and a noted power steering leak for $13,000 after buyer premiums, so that gives me hope. While I would love one loaded to the gills, if I could get into one cheap, feel it out, and go from there, it works for me. I had some friends here and elsewhere look it up for me, and it's current on recalls. Those checks also surfaced some other stuff, like options and gear ratio (3.06. Hopefully different in a WK2 Don!) It's a pretty basic model, but may be a cheap entry into the segment. I've been trying to find out how to add factory things I would want, like touchscreen or remote start after the fact.
I also work in the public sector, so I was going to give the listing agency a call an inquire about service schedules and records for increased peace of mind. I'll ask for any info I can, some are tighter than others with records.
See how the dice roll!
Rob :cheers:
Are you dead set on a Jeep?
Cause with a $20k budget, there are sooooo many great truck and SUV options out there.
Kinda. I was sort of liking the Ridgeline RTL also. Everyone has that friend in the group of friends that is the "Jeep Guy". I'm that guy. I feel like I'd be giving up my torch a bit if I pulled up in a Honda.
Rob
I've carried a solitary Jeep torch for the last 15 years.
However,
I am looking forward to trading our '06 WK in on a Toyota for my wife. Will either be a Land Cruiser, 4Runner or Highlander. I know it's not a WK2, but FCA is one in the same when it comes to recalls...
My father in law bought a new WK2 a few years back. He loves the vehicle, but constantly talks about how often it is at the dealer.
Welp. Had an interesting day. Decided to go down to the dealer and try a couple on for size. I wanted to find one that had about the same options as the auction one (basically none). I found a white '12 that had 33K on it. Options were right, so I went in to talk about driving it. We talked price, they wanted $28K for that one and change. He told me he had another '12, closer to my range (Told him $20K). It was a local trade, Laredo with 85K and just about every option. We took it out and I liked it a lot. Salesman was kinda dry, maybe more dry than I would like.
When we came back he pulled out the history. Bought new from that dealer, and serviced there all the way up to the last oil change. One owner. Has leather, navigation/dvd, subwoofer, heated seats, panaramic sunroof (the all glass one), keyless proximity fobs, towing package, automatic climate control... Pretty much all the good stuff. I got to thinking about that auction car, and how much I was going to have to spend on adding the things it didn't have... More miles, and this one being optioned like it is.The price was ok. They wouldn't budge much on the $21750 they had it listed for, but I beat them up a bit in financing and warranty. Threatened to walk a few times. All in all, ended up taking it home.
I appreciate the input fellas! Hopefully this one lives up to the hype!
1898258_915425175161637_4156776820284531
Rob :cheers:
I don't know that as of yet. I need to have an insider run the VIN. We were definitely last hour-ing it tonight. Signed the papers shortly after closing time on the 31st day of the month. Service dept was closed, and the salesman played naive when I asked about the Chrysler history. The Autocheck showed all dealer maintenance with them and the oil change reminder on the window backed it up.
I just wish it still had the original sticker with it! How hard is it to just fold it up and put it with the owners manuals!? People annoy me with vehicles.
Rob
I have to say it isn't "quick" by any means, but I would definitely call it adequate. Driving home from mom's house I averaged 23 MPG also. Even behind someone who couldn't pick a speed. The Uconnect is nice, and displays track info off streaming bluetooth, so that's very nice also. Impressed so far. I want to spend more time tomorrow in the daylight giving it the once over.
Rob
Found a back door for options lookup. Looks like the 3.09 stayed. The vitals:
Equipment Listing
VIN 1C4RJFAGXCC150722
Vehicle Description 2012 JEEP GRAND CHEROKEE LAREDO 4X4 SPORT UTILITY 4-DR
Monotone Paint
700 Amp Maintenance Free Battery
Rain Brake Support
Ready Alert Braking
Electronic Stability Control
Hill Start Assist
Four Wheel Traction Control
Trailer Sway Damping
Anti-Lock 4-Wheel Disc Brakes
Active Head Restraints
Rear 60/40 Folding Seat
Child Seat Upper Tether Anchorages
Supplemental Side Air Bags
Child Seat Anchor System-LATCH Ready
Advanced Multistage Front Air Bags
Center Rear 3-Point Seat Belt
Supplemental Frt Seat Side Air Bags
Floor Carpet
Cargo Tie Down Loops
Cargo Trim Panel w/Storage Net
Luxury Front/Rear Floor Mats w/Logo
Passenger Assist Handles
Base Door Trim Panel
STANDARD EQUIPMENT
Full Length Floor Console
Overhead Console
Illuminated Cupholders
Quadra-Trac I ® 4WD System
195MM Front Axle
3.09 Rear Axle Ratio
195MM Rear Axle
Conventional Differential Frt Axle
Conventional Differential Rear Axle
Acoustic Laminated Front Door Glass
Tinted Windshield Glass
Front Door Tinted Glass
Deep Tint Sunscreen Glass
Flipper Liftgate Glass
Rear Window Defroster
Sun Visors w/Illum Vanity Mirrors
Power Heated Mirrors, Fold-Away
Sentry Key Theft Deterrent System
Hood Insulation
Premium Insulation Group
140 MPH Primary Speedometer
Var Intermittent Windshield Wipers
Rear Window Wiper/Washer
Dual Note Electric Horns
Auxiliary 12-Volt Rear Power Outlet
12V Auxiliary Power Outlet
Power Accessory Delay
Air Filtering
Power Locks
Pwr Front Windows, 1-Touch,Up & Down
Illuminated Entry
Vehicle Information Center
Glove Box Lamp
Front & Rear Interior LED Lamps
Interior Removable/Rechargeable Lamp
Halogen Headlamps
Automatic Headlamps
Fog Lamps
Enhanced Accident Response System
Bright Grille
Chrome Bodyside Molding
Sill Molding
Body Color Fascias
Bright Day Light Opening Moldings
Body Color Door Handles
Bright License Plate Brow
Jeep Badge
4X4 Badge
Integrated Liftgate Rear Spoiler
Laredo Badge
24.6 Gallon Fuel Tank
Speed Control
Standard Duty Engine Cooling
Brilliant Black Crystal Pearl Coat
Removable Short Mast Antenna
Power Rack and Pinion Steering
Leather Wrapped Steering Wheel
Normal Duty Suspension
Tilt/Telescope Steering Column
Compact Spare Tire
Non Adjustable Pedals
Power Locking Fuel Filler Door
English/USA Language
Protective Coating and Remover
Headliner Parts Module
Seat Parts Module
Instrument Panel Parts Module
Door Parts Module
Front End Parts Module
Front Suspension Parts Module
Rear Suspension Parts Module
Tire & Wheel Parts Module
Front Suspension Damper Parts Module
Rear Suspension Damper Parts Module
Build To U.S. Mkt. Specifications
GVW Rating - 6500#
U.S. Dealer Retail
Zone 51-Chicago
Four Wheel Drive (4WD)/(4X4)
Left Hand Drive (LHD)
2012 Vehicle Specifications
WK/6042 Vehicle Family
Price Class H
Vehicle Order Tracking
U.S. Specifications Label
Illinois Ship to State Code
Carb. Code 03
Smog Code 06
Illinois Sold to State Code
Prem Leather Trimmed Bucket Seats
Black
Laredo E Group
180 Amp Alternator
Supp. Side Curtain Frt/Rr Air Bags
Cargo Compartment Cover
Leather Wrapped Shift Knob
All Automatic Transmissions
5-Speed Auto W5A580 Transmission
3.6L V6 24V VVT Engine
RR View Auto Dim Mirror w/Microphone
Dual-Pane Panoramic Sunroof
Remote Proximity Keyless Entry
Remote Keyless Entry
Keyless Enter-N-Go
Air Cond ATC w/Dual Zone Control
Premium Instrument Cluster w/Tach
115V Auxiliary Power Outlet
Garmin Navigation System
Heated Front Seats
Pwr Driver/Pass 4-Way Lumbar Adjust
Power 8-Way Driver/Passenger Seats
Body Color Exterior Mirrors
Security Alarm
Front License Plate Bracket
OPTIONAL EQUIPMENT
Bright Side Roof Rails
50 State Emissions
Engine Oil Cooler
Exterior Mirrors w/Heating Element
9 Amplified Speakers w/Subwoofer
Steering Wheel Mounted Audio Ctrls
506 Watt Amplifier
6.5" Touchscreen Display
Radio 430N
SIRIUS Satellite Radio
SiriusXM Travel Link
Uconnect Voice Command w/Bluetooth
Audio Jack Input for Mobile Devices
Remote USB Port
P265/60R18 BSW AS On/Off Rd Tires
Michelin Brand Tires
Compact Spare Wheel
All Aluminum Wheels
18X8.0 Aluminum Wheels
ParkSense Rear Park Assist System
ParkView™ Rear Back-up Camera
Remote Start System
Tip Start
Universal Garage Door Opener
Tire Pressure Monitoring Display
Flex Fuel Vehicle
40GB Hard Drive w/28GB Available
Electro-Hydraulic Power Steering
For More Info, Call 888-539-7474
1-Yr. SiriusXM Radio Service
1-Yr. SiriusXM Travel Link Service
7.5 Additional Gallons of Gas
Spring - Left Front
Spring - Left Rear
Spring - Right Front
Spring - Right Rear
Customer Preferred Package 2TX
Customer Preferred Package 26X
Distribution Services Tracking
7
11/01/15
Ah well, the good thing is that with the 18" tires and the standard 3.09 axle you'll never know the difference unless you get another later with higher numerical gears to compare it to. It'll be fine. I was kind of satisfied with my similarly equipped tall geared 2012 JK. Seemed like a dog, my MJ blew it away off the line. So I got on the JK forums and did my reading. That's why I ordered the 2015 with 3.73's.
Does it have the towing package?
Thanks everyone for the comments. The UConnect is cool. Love the navigation and the 9 speaker stereo with the sub. Just enough to really make the sound quality better. Crazy though... The PO nor the dealer wiped it clean. I was driving home from the dealer and noticed a "House" icon pop up on the nav screen. Curiosity got the best of me so I punched it in. 5 minutes away, so I drove by. Big u-shaped ranch with 3 car garage on 2 acres in an affluent neighborhood. The rest of the "Recent destinations" are O'hare and Midway airport terminals in Chicago, places 250 miles away in WI... Those 85K miles were highway. The nav even shows the max reached speed (102) and the average moving speed (45). Tells me it did a lot of highway driving if the average was as high as 45 MPH. Crazy... Because I have the guys first name (from his voice naming the first phone entry), his home address, frequent stops which are most likely friends and family... All from a vehicle.
Got under it and did some inspecting today. Found everything in great shape, and brand new brakes and rotors on all 4 corners. The pads are still shiny black with Mopar PN's clearly visible. Yesterday I had the dealer repair a rock chip the GF found on the windshield Sunday, and picked up my slush mats today. The more and more I look at this thing, the more and more stupid clean it is. I couldn't find a door ding on it, only found a small dent in the above the passenger door, and a little rock chip by the Jeep emblem on the hood. Plans are to get a set of splash guards and roof rails and call it a job for now.
Other thing I realized was I never got you guys better pics!
12141757_916940328343455_737311388015017
12193569_916940498343438_419428106607158
12193754_916940548343433_188427574566308
12187732_916940565010098_475504451924191
11168456_916940581676763_527473617635421
12196199_916940595010095_751308460739534
12208550_916940611676760_917701121502019
12111974_916940631676758_703665565080646
12065928_916940648343423_173555909140703
12208695_916940668343421_182523276653861
12191480_916942458343242_319601593004626
12196340_916942468343241_609776631905150
12190088_916942501676571_806094877213798
Rob
