Any ideas where this is coming from?!
it has to be from somewhere under the hood just curious to see if anyone else has had this problem or knows where its from. this is the passenger side, this isnt from the AC the jeeps hasnt been run in two days but its been fairly stormy here. Thank you to everyone in advance.
Not to be funny, is it water or anti-freeze? Did this happen while it was raining or you were washing the truck?  Are the heater hoses connected correctly and tight. Possible hose issues (split in hose, hose clamp not tight, etc..)
Ive had this same result with  my 2wd when it rains hard......not sure where it comes from, ive sealed below the blower motor and part of the cowl, only happens after continuous hard rain so I'm not too worried with it.
a guy that i bought a tailgate off had this same problem and said it was very common and he had 5 comanches at his house and he had piece of sheet metal welded somewhere right above the blower motor or something and from what i saw it just made the water run down and out instead of into the cabin
Solved was coming from the bottom side of the blower in the engine bay. Had some leafs pilled up there i don't know how i never noticed. cleared it out and added just a couple daps of silicone and just a dab where the leak was coming into the cab. checked it during a hard rain fall the other day and she was dry!  :thumbsup:
