Hello have problem I change the motor. when it come to the throttle body cables are two. I can find the 26 or 27 inch throttle  body cable on line. but the second one I can't find. Would like to know what its call. Is it a acceleration throttle body cable . If anybody can help thanks.
Thanks for the help. Its a 1989 jeep Comanche with a 4.0 motor and new ax15 transmission. It has two cables. I found the first cable 26 or 27 inch one that go's to the gas pedal. But the second one go's to the top of the throttle body clip. Then to the throttle body bracket that its clip in . then cable go's to the lower side clip kick down. Any help will be appreciate thank!!!
bee110
Hi, I have 1989 Comanche with a ax15 5-speed transmission. The throttle body has two cable. I do find the 26or27 inch throttle cable to the gas pedal. The second cable is for the kick
down for the throttle body. dose any body know the part number or the name of the second cable thanks for the help. bee110
If you have an AX15 5spd manual transmission ... there is no kick down cable, the kick down cable is only used with the AW4 automatic transmission.
Only one thread is needed for this.
What engine?
