Wesleypipesyo Posted June 9, 2015 Share Posted June 9, 2015 More like ... https://encrypted-tbn2.gstatic.com/images?q=tbn:ANd9GcR0vkVt03Tj7zxLTRwUjVLZYnPRyEQen4Fk9NGoXyn64E-yR6OrAg This guy used to show up where I worked all the time. It was disturbing. Link to comment Share on other sites More sharing options...
8valvehero Posted August 10, 2017 Share Posted August 10, 2017 Hey gang I know this thread is old and all, but I wanted to chime in and endorse this method. It's not a permanent fix- but it certainly restored functionality to my tired, sloppy parking brake. The kick panel was removed and I was able to swap the pawl spring out easily with a medium size needle nose. A magnet stick and paper towel (for blocking crevasses) were helpful. Access was easy in my '91. I don't recall my Renix MJ being as accommodating when I tackled it. At first I cut the factory spring to make it tighter. That kinda worked, but the pedal was still not holding 100% of the time. I bought a much firmer spring from the hardware store that seems to be holding solid (4 days in so far). I still need to rebuild this assembly, so I'm careful to pull the release handle when depressing the pedal so the teeth don't get buggered by the extra tension on the pawl. I like A-man930's rebuild method: http://comancheclub.com/topic/48483-parking-brake-pedal-refurb/ Keep Jeepin'! . :MJ 1: . Link to comment Share on other sites More sharing options...
Minuit Posted August 10, 2017 Share Posted August 10, 2017 I bought a few springs at Ace and did this a few months ago. Parking brake hasn't popped since. I can actually use it now! Link to comment Share on other sites More sharing options...
cruiser54 Posted August 10, 2017 Author Share Posted August 10, 2017 The spring is the key. Link to comment Share on other sites More sharing options...
johnj92131 Posted August 10, 2017 Share Posted August 10, 2017 Cruiser, I just discovered this thread. Unfortunately you pictures have been "affected" by PhotoBucket ransom demands. IF you have a new photo host - can you please fix the pictures in this thread? Thanks for documenting this fix. Link to comment Share on other sites More sharing options...
cruiser54 Posted August 10, 2017 Author Share Posted August 10, 2017 Link to comment Share on other sites More sharing options...
johnj92131 Posted August 10, 2017 Share Posted August 10, 2017 Thanks Cruiser! Link to comment Share on other sites More sharing options...
A-man930 Posted August 11, 2017 Share Posted August 11, 2017 I like A-man930's rebuild method: http://comancheclub.com/topic/48483-parking-brake-pedal-refurb/ It still works great after a year and a half with regular usage. If the teeth on the pawl are shot and/or the pedal is loose on its pivot then this is really your only choice. The spring replacement/upgrade is obviously easier if yours isn't too far gone yet. Link to comment Share on other sites More sharing options...
NickyV Posted October 6, 2025 Share Posted October 6, 2025 I also want to endorse this method! I had been getting prepared to do the full rebuild and then thought, why not try this first? It is working great! I’m a few weeks in now and I can park on steep hills again! I made a video for anyone else who wants to give this a try before completely rebuilding their brake assembly: https://www.tiktok.com/t/ZTMkB6s4A/ Link to comment Share on other sites More sharing options...
