Jeep Driver Posted May 28, 2015 Posted May 28, 2015 I've done the searches. Anyone have a definitive conclusion on the best fitting, correct fitting, flares? Any pics? Thank you.
Jeep Driver Posted May 28, 2015 Author Posted May 28, 2015 I've guessing these are the Bushwackers? This is the direction I want to go......any experiences? and I take it fenders get trimmed?
Incommando Posted May 28, 2015 Posted May 28, 2015 I don't think the bushwhackers require trimming but I am not sure
dunnc1991 Posted May 28, 2015 Posted May 28, 2015 I'm pretty sure you can trim with the bushwackers, but it's not needed to run them
buckwheat Posted May 29, 2015 Posted May 29, 2015 Personally I don't like the way Bushwackers look. I'll be interested to see other options and how they work with Comanche body lines. Sorry I have nothing constructive to add except my excitement for more pictures and options.
Lee21490 Posted May 29, 2015 Posted May 29, 2015 I have the bushwhackers on my truck, I really like them. You actually have to trim quite a bit off to fit them properly, It's pretty easy to do though. If you have a shortbed, they bolt right on. However if you have a long bed, You either have to offset the rear left flare, Or cut the bottom corner off your fuel door. I went with the latter.
daking Posted May 29, 2015 Posted May 29, 2015 napier fender flares on the XJ Bush wacker on the MJ Image Not Found Image Not Found
jpdriver1 Posted May 29, 2015 Posted May 29, 2015 side question === anyone which winch bumper is on the mj?
mikekaz1 Posted May 29, 2015 Posted May 29, 2015 The TJ ones look pretty good actually. I always hated when they did TJ fronts on MJs. But the rears at all corners looks good
Blue88Comanche Posted May 29, 2015 Posted May 29, 2015 4 rear TJ flares. Cheap. mmando/2015-05/88469C97-5D61-45F8-81B0-10B2E0059943_zpsiwxhfrgw.jpg a bit off topic but how are you liking that Rusty's bumper?
Megadan Posted May 29, 2015 Posted May 29, 2015 I've heard very good things about the Napier flares. They make the style above (similar to bushwackers) and they also make a flat style flare that I think looks decent.
