Has anybody used XJ midsection stiffeners on an MJ?
The frames are only the same as far as the cab support under the door,beyond that the MJ frame starts growing taller and the XJ frame stays about the same.
Basically the stiffeners will only fit for the first foot or so.
Yeah, the MJ unibody rails under the cab are quite different than those under an XJ.  About the only place they're the same is from the front bumper mounts back to the lower control arm brackets.  From there, they differ alot.
Here's a Hornbrod lower midsection stiffener...........:D
Here's a Hornbrod lower midsection stiffener........... :D
Talk about a blow below the belt.....
