  • 3 weeks later...
  • 2 years later...
So I am back. Things took a different route since I started this thread. the build specs are as follows.
started as a 1990 2WD, 4.0, auto Comanche
I did a full 1999 Cherokee conversion, front clip and dash.
5.3/4L60/231 drivetrain
JK Dana 44 axles
Clayton long arm
frame stiffeners from front to back
Spring over in the rear with a bastard leaf pack
I think 4.5" coil springs in the front with Acos spacers to level it
JCR front and rear bumpers with Warn winch in the front.
Just painted HE4 base/clear.
Still lots more to do.
On ‎12‎/‎9‎/‎2017 at 11:24 AM, johnj92131 said:
What is behind the door just ahead of the right side tail light?  Another gas tank?
When I bought this MJ, that corner was wrinkled. So my idea is that I cut the bad sheet metal out, and installed another gas door, which is going to be an air and power outlet area.
On ‎12‎/‎20‎/‎2017 at 6:46 AM, Kickin’Chicken said:
Where’d you get that bumper? That and the grill look awesome!
Course it ALL looks awesome but those really stick out.
I belive it is an early JCR front bumper, and I add the win
  • 8 months later...
JK Dana 44 axles
Clayton long arm
Just needs some eye balls in windshield and it would look like a 4x4 Lightning McQueen.
On ‎9‎/‎3‎/‎2018 at 11:42 AM, RedDemon90 said:
what did you paint the engine bay with?
I bought some spray cans from an autobody paint supply. I can't remember the brand, but it was a two part, where you had to break a divider in the can to mix the paint and hardener. It was close to $50 a can....
