88 pioneer 4x4 long bed with 350 chevy, SM465 truck transmission motor swap
Hi my name is Richard and I am from Ohio and this is my 1988 Comanche
1505176_723380241108608_9160371594725133
It started 10 years ago with the truck that did not run I purchased from a friend for $100 and had towed to my house.  My brother gave me the chevy 350 motor and SM465 from his old CJ-7.10896313_717854264994539_798295698887569
10869900_717855028327796_625477811954613
Advance adapter motor mounts
10856449_717296658383633_497524124475072
10714356_718894411557191_744570190239393
10986863_744001125713186_348842244436075
10869867_718894398223859_500622797690314
10906243_717854994994466_727697141070573
10888598_717296638383635_517082522560388
DIY beadlocks
10888378_716561565123809_444705918280447
10873497_716152885164677_750861636953976
10835320_716152891831343_535169579357140
10887088_716152708498028_792566858105555
10368807_716152701831362_638850092085797
1501175_716152691831363_4746068806521440
10834949_716152635164702_139678995779161
10857394_707312232715409_443415617273730
I did a drawing in Solidworks for a new 304 stainless steel tailgate latch.
10861085_763849260395039_509974020704414
Autometer gauges
10891771_716561558457143_62125377952075710888792_716561551790477_850134203685617
10688217_672095119570454_693265339797778
This is my fuel tank sending unit.  I removed the fuel pump and made a pick-up tube with a fuel strainer I purchased.  I used a 1/8" pipe tap and plugged the old return line.  Fuel float works with a new auto meter fuel gauge.
10658974_667391843374115_786767715667554
Holley spreadbore 650 CFM 4 barrel with mechanical secondaries that I rebuilt with new floats
1487947_663245127122120_4333813908183233
10897863_723889751057657_901514210575896
New holley floats part number 116-3 nitrophl on right
10929046_723889744390991_326414318938978
Allstar Performance power steering pump with Detroit Speed Inc. pump mount
906384_663245133788786_77475530062762085
10805700_707241406055825_286743117392635
906269_572410916205542_34946015249466633
10603997_744001122379853_259974826763315
10931692_744001139046518_514090088576760
Painless Performance fuse block, MSD 6AL ignition, mechanical fuel pump and Holley spreadbore 650 CFM 4 barrel with mechanical secondaries that I rebuilt with new floats, Mallory cartridge style fuel filter,  3/8 inch fuel line, new 22 gallon tank, Elelbrock aluminum intake manifold, AA headers made for the conversion, Flowmaster diamond plate off-road muffler,  AA motor mounts, Novak radiator, Allstar Performance power steering pump.  Lakewood bellhousing, SM465 truck transmission,  AA t-case adapter, Mcleod throw out bearing, NP231 with slip yoke eliminator, Detroit Speed Inc. shifter knob, Autometer gauges.   33 x 12.5 x 15 BFG mudterrain on stock wheels modified with DIY beadlocks, Superlift 3" lift with longer lower control arms and shocks from Tyres International.  Optima battery on DirtBound Offroad steel tray, DirtOld Man Emu steering stabilizer, OMC Offroad steering box brace, drop pitman arm, ZJ tie rod conversion, Canton Custom Clutch driveshafts.  Single electric pusher fan mounted on front of radiator wired to a switch on the dash that I only use driving at 70 mph highway because I have a mechanical fan
  • 9 months later...
12141133_883720748407889_773774913667180The alternator belt has excessive wear so I got a new lower bracket mount from summit number SME-2000.  The upper mount I sand blasted and had zinc plated for $10 by Nicks plating and they had it done next day.  I also have a Wangler Power Products 140 amp alternator I will rebuild later.
12087857_883720941741203_132639976266082
Nice man your engine bay looks clean!  :thumbsup:  And I had a couple of questions on how you did the auto meter gauges, since I'm planning to do the same thing on my truck, do you have a write up, or more pics about it?
To install the Auto meter gauges remove the instrument cluster and disconnect the speedometer cable and the two electrical connectors.  I cut off the plastic corners of the instrument cluster from the back.  I then sheared a piece of aluminum sheet and hole sawed it to fit the auto meter gauges.  I added the Auto meter fuel gauge after I took the pictures below.
12191538_894168474029783_393756874444714
  • 1 year later...
  • 1 year later...
