Control arm drop bracket choices... RCX vs RCE vs RRO
I've never been thrilled with going this route in the first place but it looks to be the best choice right now ($$$) to get it riding safe/correct.
I've read up as much as I can stand; including threads like this one that are MJ specific:
http://comancheclub.com/topic/18066-lower-control-arm-drop-bracket/?hl=arm+drop
This is what I've come up with so far:
RRO (Rocky Road Outfitters):  Pros: Strong, one-piece, MJ specific design
                                                 Cons: LOTS of pretty crappy reviews on customer service and product quality/fitment.  Sounds like a real gamble.
RCX (Rough Country):  Pros: Cost, availability, reliable supplier/manufacturer, cost.
                                     Cons: Multipiece design, designed for XJ (have to remove MJ gussets,) puny bolt-on bracket brace.
RCE (Rubicon Express): Pros: Beefy bracket brace (extends to crossmember,) big collar/bushing on upper bracket (compared to RCX.)
                                        Cons: Don't really know much about the product! Haven't seen anyone use it on an MJ...
I'll be making a decision next week.  Any additional feedback is welcome, especially on the RCE kit!
The RE braces won't work unless you trim down the LCA mounts. I ran some Trailmaster drop brackets (identical to RE) with the RE braces on my XJ. Then I swapped the drop brackets over to my MJ without the braces. And never had any issues. Ran the Rubicon Trail, all over Moab, and local trails for five years with these brackets.
-The factory ones?
-So, no brace at all?  Just the drop brackets?
I built my own. mine are designed similar to the RRO brackets and made from 1/4" plate.
The RE and RC brackets are pretty similar, between the two I would buy the RC brackets and just make a brace for them that fits the MJ and extends back to the crossmember.
-The factory ones?
Yes, the factory ones that are discussed in the link you provided.
And yes, no brace, just the drop brackets. Of course, results may vary, but I had no problems.
Does TrailMaster still exist, and is their drop bracket kit still available? My '88 MJ had a TrailMaster lift with drop brackets when I bought it. I wheeled it like that for several years -- until I got tired of the lift and put it back to stock height. It was a good kit, plenty beefy. I passed it along to Frank the Dog in exchange for his help removing the lift.
Looks like TrailMaster is still in business. Their current lift kits don't seem to include drop brackets, so I sent a message to the sales department to ask if they are still available.
So the "extra" part that's welded onto the otherwise XJ-identical mount?  I've seen it called a brace or gusset... I think we're talking about the same thing... and by what I read using the RC braces will require them to be trimmed down as well.
I'm intrigued now; can I use the RE9900 kit (mount relocation parts alone,) use it brace-less for a time, and later design and build some braces that work with the factory MJ frame??
I'd love to NOT cut up my truck if I don't have to!
I just got the rro mounts in. I chose them because they are the only ones that are specifically for the mj. I haven't installed them yet but they look to be of solid quality. Came with all hardware and straight forward instructions. They are not one piece, there's the main drop bracket and a second brace for each side which is designed to bolt to the mj gusseting. They shipped a little slow, and when I emailed asking them for an update it took them a couple days to respond, but when they responded they told me exactly what was up and when to expect them, and they arrived the day they told me they would. Overall I would recommend them.
I have the RCE kit. It's really beefy and holds up great! The price is great too. Do you want some pictures of it?
The bracket itself should be one piece and the brace is seperate.
On the RC and RE the main bracket is two pieces then the brace is seperate.
They really don't need the braces on the comanche, XJ has a weaker mount area.
There's actually quite a few of us on here using the Rubicon Express drop brackets.
I've had mine on for a little over a year now i think, They have great customer service, Mine came with a missing "Boomerang" Bracket & they sent me a replacement next day air free of charge.
Can't think of any issues i've ran into with them.
Check the "Alexia" Link in my signature, It's a link to a build list including the RE Brackets & Multiple people that are using them.
http://imgur.com/06vrxMM,HFacCAs,je32vSa,uyUbk61,TwplSES
Here's some pics of Rubicon Express brackets on my truck. They're well used . :MJ 1: .
Also quite dirty :ack:
I have RC DBs on both of my trucks. I do NOT run braces on either of them. They have been fine for over 5 years on my 89.
I have done this too. They hold up well, don't shift, loosen, or in any way become unsafe. I've supported the truck from them with jackstands before and they didn't so much as scratch them. Braces are nice for that added security, but not needed.
The lower controls arms in this picture are backwards. DO NOT use this as a reference if you just so happen to be searching and find this image.
i used the Rubicon express dbs on my xj that i had 9in of lift i loved them. i had a set of rc dbs and they felt flimsy compared to the re ones. i ordered them from seriousoffroad.com and i paid less for the re ones compared to the rc ones. with my ironman andys control arms the re dbs it rode and drove better than my buddys xj with almost the same setup with rc long arms. only thing different on his was a dana 44 rear and i ran an 8.8..........
