Old man with MJ Posted November 11, 2014 Share Posted November 11, 2014 My original 1988 model cracked and is leaking, is that available new from Mopar? Also leaking out front of radiator,haven't pinpointed it yet though! Thanks Link to comment Share on other sites More sharing options...
MJRemi Posted November 11, 2014 Share Posted November 11, 2014 Try ebay or teamcherokee. You may want to upgrade to the open system installed in the latter year cherokees. There's plenty of project how-to's in CC and NAXJA. Link to comment Share on other sites More sharing options...
91Pioneer Posted November 11, 2014 Share Posted November 11, 2014 You can buy the Mopar one but the Dorman one is better IMHO, see http://www.amazon.com/gp/product/B000E300OY/ One of the reviews (not mine): "The OEM tank has been a pain for as long as I've owned this Cherokee. I think I've replaced it four times prior to this one. So far, no splits, cracks or leaks. It's nice to find third party parts that are as good or better than OEM." If I was you, I'd replace the parts rather than do the open swap. A properly functioning closed system is just fine, I never had a problem other than the leaking bottle on my 88. The replacement bottle is $22.53 on Amazon, cheap. Also, Stant 10244 cap is an upgrade http://www.amazon.com/gp/product/B000C7YQ2O/ Link to comment Share on other sites More sharing options...
velco Posted November 11, 2014 Share Posted November 11, 2014 The original french surge bottle (Lyon, France) lasted 20 years, then I replaced it with a Dorman bottle copy of the original; it only lasted 5 years...chinese junk but cheap. Finally broke down and bought a Mac's Radiator aluminum surge tank... pricey but probably the best thing out there. This tank will probably outlast the jeep and me. http://macsradiatorshop.com/surge-overflow-tanks/replacment-jeep-radiator-fill-tanks-366.html Link to comment Share on other sites More sharing options...
cruiser54 Posted November 12, 2014 Share Posted November 12, 2014 Napa and the rest have the bottles. Ditch the cap that comes with it and get a 703-1396 cap from Napa. Link to comment Share on other sites More sharing options...
willi2ds Posted November 19, 2014 Share Posted November 19, 2014 I've had great luck with the Dodge Intrepid bottles that I've put in a few Cherokees and going on 5 years in my Comanche. You stay with the same style system but now with a metal cap and all for under $20. Quite a few write ups out there. Link to comment Share on other sites More sharing options...
danbyrambler Posted November 19, 2014 Share Posted November 19, 2014 site: comancheclub.com Dodge Intrepid With pics: http://comancheclub.com/topic/37314-1987-coolant-reservoir-tank-question/ :wrench: Link to comment Share on other sites More sharing options...
hollywood2311 Posted November 20, 2014 Share Posted November 20, 2014 I think I need to do the Intrepid bottle swap. My 89 MJ blew the coolant bottle up on the way home yesterday. I tried to put the cap back on, but when I screwed it tight, it would release and I never could get it to stay on. I had to drive half a mile at a time on the way home, and let it sit for 10 minutes at each stop. Thank God it was only 25*F out yesterday. Almost flipped it on its side trying to get off of the road once. Only problem is: I checked the dipstick once I got home, and it looked kinda crappy on the end, and I just did an oil change less than 200 miles ago. Time to check the head gasket methinks. I might just put a bunch of new parts on it while I've got the damn thing apart. Might splurge for a new thermostat, water pump and hoses. Link to comment Share on other sites More sharing options...
tugalo Posted November 26, 2014 Share Posted November 26, 2014 The Dodge Intrepid swap is cheap, easy, and will last forever. Pretty sure there are other Mopar bottles that will fit, just have to remove the original bottle mounting bracket and install the Intrepid bottle with 2 screws into the firewall shelf at the original location. Link to comment Share on other sites More sharing options...
hollywood2311 Posted November 30, 2014 Share Posted November 30, 2014 I bought the Intrepid bottle last week from OReilly's, they actually had one in stock. I looked at getting a used one, but prices were crazy high for used parts. I put a bunch of water/coolant into the existing bottle today, and let the engine idle for a bit. Started it several times to get the water to leave the reservoir and actually go into the system. No water came out of the system at idle. I thought it might have been something loose that allowed the coolant out, but it appears it was only the bottle that failed. I might replace the thermostat too to eliminate that as a failure point. Link to comment Share on other sites More sharing options...
A-man930 Posted November 30, 2014 Share Posted November 30, 2014 I've had poor luck with aftermarket surge tanks in general. I got an OEM tank, cap, and thermostat and the cooling system works like, well, OEM! Lol Link to comment Share on other sites More sharing options...
hollywood2311 Posted November 30, 2014 Share Posted November 30, 2014 OK, I just filled the existing bottle and let the truck idle for a bit. No leakage, but I have white smoke out the exhaust, and a small amount of smoke coming from the valve cover during idle. Head gasket? Link to comment Share on other sites More sharing options...
A-man930 Posted December 1, 2014 Share Posted December 1, 2014 OK, I just filled the existing bottle and let the truck idle for a bit. No leakage, but I have white smoke out the exhaust, and a small amount of smoke coming from the valve cover during idle. Head gasket?Or a cracked head or both. Link to comment Share on other sites More sharing options...
hollywood2311 Posted January 19, 2015 Share Posted January 19, 2015 The Dodge Intrepid swap is cheap, easy, and will last forever. Pretty sure there are other Mopar bottles that will fit, just have to remove the original bottle mounting bracket and install the Intrepid bottle with 2 screws into the firewall shelf at the original location. I finally got around to doing this yesterday. Pretty easy swap. The hardest part was getting the old hoses off of everything. They were stuck, even when I took the hose clamps off. I bought some new lower hose, and got a coupling for the upper hose. Do I need to do anything with that small upper barb? It's got a tiny copper insert in it, and it might be an opening of 1/16 of an inch on the inner diameter. Link to comment Share on other sites More sharing options...
tugalo Posted January 21, 2015 Share Posted January 21, 2015 i believe thats an overflow to relieve the pressure if you overfill the bottle, just put on a short piece of hose to take the water out of the engine bay. Link to comment Share on other sites More sharing options...
