velco
1 Follower
    SK
velco's Achievements
Comanche Fan
Comanche Fan (3/11)
  1. No AC, coil is split loom unless your referring to something else.
  2. I run mine about 1.25 inches (32mm) with a sealed overflow. Coolant at that point is above all plumbing.
  3. Need to see pictures to determine if its fixable or considered totaled off. That low mileage would be considered a keeper if the damage was not too bad.
  4. That would be for a SWB about 28.5
  5. 102.56 with the idler is the proper length.
  6. You can run the Mac's tank as a closed system, just plug the overflow.
  7. Found the answer: Harder to adjust. Tested to fit factory Cherokee XJ AW4, AX15 NV3500, NP231, and NP242 combos. Has been used on BA10 transfer cases, but can be harder to adjust.
  8. Seems like nobody mentions the BA 10/5, not even the instructions. Does anyone know if it works?
  9. Right goes to the EGR valve.
  10. Rear MJ shocks are different than XJ.
  11. I am replacing a 10/5 rear mount original with a crown replacement and noticed that the original has a center pin that appears to be welded or pressed in. The crown has the holes but no pin. Is that pin important and how to remove it if I need to transfer it to the new part. New part installed fits and works like a charm. Old mounts rubber was very spongy causing a bit of drive train flutter.
  12. Mine is Blue...engine compartment behind the drivers headlight beside the hood spring.
  13. Didn't they come standard on the Eliminator. I have ROLs on my 88 and they work well.
  14. Or you can plug the overflow and keep running a closed system. I am using a 16-lb cap.
  15. The 231 drain plug is 12mm/12point. This is according to my transfer case.
