Auto swap vs 4x4 swap
It would seem that I am going to have to be a touch less picky in trying to find a truck to buy.  So I will throw it this out there and see what sticks.
Which is easier/less involved?
Manual to auto swap
               or
2wd to 4wd swap.
The manual to auto swap seems to be a lot of wiring.  You need to replace the bulk of the wiring harness.  You need a new cross member.  A new transmission with bellhousing and other hard ware.  I have seen some people say that you need a new steering column.
What do you need for the 4x4 swap beside the tcase, front axle, drive shafts, and center console?
Thanks.
Jeff
I did a manual swap on my 90. Wiring wise, all you have to do is ground the NSS wiring. You can use the automatic computer with the manual. There is a transmission computer that plugs in, and is located on the lower dash panel on the passenger side. It can be pulled out completely. Then, you will have a white and a black plug on the firewall where the NSS and the transmission harness plug in to the main harness. You need to bridge 2 of the pins on the NSS harness. A simple butt connector will do. You won't have reverse lights if you go this route. They could be wired in easily. In fact, I believe the manuals have a harness that plugs in there that you can just plug and play, but don't quote me on that. The only cutting you have to do is the 3 holes for the slave cyl master. There are 3 dimples next to the brake booster. The top 2 holes line up with the bracket, then you have to get a hole saw and drill out a larger size hole. Also, the T case linkage is a little crooked if you don't drill a new hole for the linkage. It can be easily done.
You need:
transmission
transfer case (if you have a 21 spline aw4, AX15 is 23)
cross member (optional)
steering column (optional, the manual steering column has the push button lock)
drivelines (front and rear)
Shift boots (one screws to the floor and one goes in the column)
cover for the floor hump (The one for the manual is just a hole with a shift boot over it)
brake and clutch pedal
clutch
flywheel
slave cylinder and master w/bracket.
throwout bearing
A manual swap is a big job, but all plug and play.
You need:
transmission
clutch
flywheel
throwout bearing
He's asking about a manual to auto swap..
no matter what if you are starting with something not auto 4x4 you will need a transfer case and transmission from auto 4x4...so the real question is front axle swap or tb and wiring swap. I say go for an auto and swap in 4x4 to avoid having to mess with wiring . You can get the axle ready to go outside the vehicle and still drive it but the wiring and stuff takes you out if commission till its finished.
there is a thread in the DIY to convert from a BA-10/5, AX-15, or AW-4 to an AX-15, or AW4
I have no experience with 2.5Ls all I know is they came with AX-4 and AX-5 manual transmissions with 3.73 to 4.56 gearing.  I have no idea what auto trans they use.
2.5Ls came with AW4 auto trans 87 and after I believe (?).  But, as Ive done lots of researching for mine I find that 2.5ls autos don't seem very common. Mine is column shift, 2wd. and the rear is 4.56.
I'm gonna hijack this thread for a moment. I too have questions about swapping for 4wd.  would it be too much work to put 4wd on mine and be more worth it to just find another comanche with even the 4.0l and 4wd?  Not sure if a 2.5l auto 2wd swap to 2.5l auto 4wd will take a lot of work?  would a 4.0L AW4 4wd trans work? or is there minor differences in the AW4 for a 4.0 and 2.5?
You need a transmission to make the 2WD to 4WD swap, too, unless you think it's easier to tear apart your transmission and change the output shaft and tail cone for a transfer case input shaft and rear tranny housing set up to mate with the transfer case.
The AW4 has a separate TCU, so going from manual to automatic doesn't require RE-wiring anything in the truck. Just add the TCU wiring harness.
  • 2 months later...
I'm trying to follow you guys on this with my own donor swap, just a little lost. I have an 86 2.5 custom 4x4 and my donor is a 91 4.0L auto 2wd. If I'm understanding this right the t-case splines are different and I may need to swap the yoke on the driveshaft as well right? output shaft from the trans isn't the same spline from ax4 and the length differs from 4x4 to 2x4? In any case I will freeball the front differential until a t-case is available. I have ecu, clusters and a motor swap in front of me now, cart before the horse right. Plan on swapping everything back into the donor and give it to my 17yr old brother. So leave the t-case for him to find a front end in the future assuming he don't wreck it another club member guys! Any good tech advice on my swap?
You cannot use a 2wd trans in a 4wd truck.
Start with a truck that has the engine and transmission that you want. The 4wd swap is much easier/cheaper/less time consuming. As far as the transmission tunnel, when you lift up the carpet you will see a blanking plate with four screws, remove it and put the transfer case shifter in it's place. And 4wd AW4s are plentiful and cheap, I got two from CL for free and haven't been able to give them away.
I gave up on this idea. I am still looking for a truck with the right drive train. I hope to go look at a truck Friday. It is a little over 4 hours away. I will be unhappy if the people are lying about the condition of the truck. But it is pretty close to what I want.
