JeepFanactic Posted May 9, 2014 Share Posted May 9, 2014 I have a 87 MJ 4.0 5 spd that is a base model. My jeep only has the one mechanical fan. Is this normal for MJ's with no AC to not have the electric fan. I don't think the PO took the electric fan out because the Jeep look unmolested when I got it. I have seen write ups for adding an override switch but I need the entire electric setup. I'm not really good when it comes to electrical stuff so I would need a system that's fairly easy to install. Thanks Link to comment Share on other sites More sharing options...
danbyrambler Posted May 10, 2014 Share Posted May 10, 2014 You're wanting to add an electric fan, correct? Not hard at all - Been covered here on CC many times - - Gonna need a new/used fan & means to control it, like a toggle switch or a temp switch & relay or all three - A pic of your T stat housing will help with getting advice/opinions going - What kind of budget? Does your radiator have a fitting for a temp switch? Won't take long & It's easy - - I've done to both of my MJs - DonH has a slick set up - Mine is pretty much the same - - Anyway, easy enough - $ amount/scrounging ability/intended use info needed - - - Good ideas in DIY - Dual fan mod :wrench: Link to comment Share on other sites More sharing options...
Comanche County Posted May 10, 2014 Share Posted May 10, 2014 If the MJ didn't come with AC or the tow package, it wouldn't have the electric fan. There's a couple of options for controlling the on/off of an electric fan. Like danby said,,,The easiest would be to find a 97+ efan and use a deraile or other aftermarket temp controller to turn it on and off. Or you could just wire it up through a relay and a toggle switch to turn it on manually. Link to comment Share on other sites More sharing options...
91Pioneer Posted May 10, 2014 Share Posted May 10, 2014 Comanche Country, my 88 4.0 does not have A/C but it has the electric fan (smaller one in addition to main engine driven one). Does that mean it has a tow package? JeepFanatic, do you have a photo of your fan setup? I'm curious now, I had thought all 4.0s had the smaller electric one. Link to comment Share on other sites More sharing options...
Comanche County Posted May 10, 2014 Share Posted May 10, 2014 do you have a rear d44 or receiver hitch or door mounted rear view mirrors? Sorry, my laptop doesn't have a capital d.....stupid thing... Link to comment Share on other sites More sharing options...
Comanche County Posted May 10, 2014 Share Posted May 10, 2014 Or 5 leaf rear springs? The tow package is one and the same as the metric ton or big ton package IIRC...unless you had a dealer installed hitch. Link to comment Share on other sites More sharing options...
91Pioneer Posted May 10, 2014 Share Posted May 10, 2014 Door mounted mirrors, no hitch, just bumper ball. 3 leafs in the pack. No metric ton emblem but it's a short box anyway. Link to comment Share on other sites More sharing options...
randomguy310 Posted May 12, 2014 Share Posted May 12, 2014 I woud think they all came with the elct fan, if not it would have a shroud of some kind to cover where the elct fan should be to duct the air to the mech fan.. just my opinion Link to comment Share on other sites More sharing options...
HOrnbrod Posted May 12, 2014 Share Posted May 12, 2014 As Comanche County said "If the MJ didn't come with AC or the tow package, it wouldn't have the electric fan." Perhaps a better word to use would be "shouldn't" have the fan. Nothing is written in stone in Jeep; there were undocumented dealership options available. But for sure, there were no "shrouds of some kind" available for a XJ/MJ missing the puller electric fan. Link to comment Share on other sites More sharing options...
Eagle Posted May 12, 2014 Share Posted May 12, 2014 On 5/12/2014 at 2:41 AM, randomguy310 said: I woud think they all came with the elct fan, if not it would have a shroud of some kind to cover where the elct fan should be to duct the air to the mech fan.. just my opinion They only came with the auxiliary fan if they had a/c, heavy-duty cooling, and/or a tow package. There is no "shroud" for the auxiliary fan ... it was part of the fan assembly, which just drops into place. It looks like this: Link to comment Share on other sites More sharing options...
randomguy310 Posted May 16, 2014 Share Posted May 16, 2014 I am not sure I buy that ... it would not run cool with out a shroud of some kind ducting the air out the mech fan , look at most cars and you will see the air is always ducted out to the fan Link to comment Share on other sites More sharing options...
randomguy310 Posted May 16, 2014 Share Posted May 16, 2014 look at a caravan radiator.. has one elct fan but it shroud covers the whole radiator... not just open Link to comment Share on other sites More sharing options...
HOrnbrod Posted May 16, 2014 Share Posted May 16, 2014 The XJ/MJ fans are not "just open", they are shrouded puller fans. Viewed from the back of the radiator Link to comment Share on other sites More sharing options...
ftpiercecracker1 Posted May 17, 2014 Share Posted May 17, 2014 On 5/16/2014 at 10:43 PM, randomguy310 said: I am not sure I buy that ... it would not run cool with out a shroud of some kind ducting the air out the mech fan , look at most cars and you will see the air is always ducted out to the fan Dude, Eagle has forgotten more about MJs than you or I will probably ever know. Your doubt is understandable and you would be 100% correct IF we were talking about mech fans, but we arent. Like previously stated E fans have the "shroud" premolded into the body of the assembly. Word to the wise, moderators know their sh*t. :thumbsup: FPC. Link to comment Share on other sites More sharing options...
randomguy310 Posted May 17, 2014 Share Posted May 17, 2014 since when is it wrong to have an opinion about something? you know nothing about who I am or what I know or what I do.. I know exactly what the topic is.. I can read and write and fairly smart.. but I guess its wrong to have an opinion and disagree with someone.. I said nothing wrong for you to be a complete tool.. so keep it to yourself... and if you know anything you will know even with a mech fan you need a shroud.. all I was saying I doubt that Cherokee or mj came without a elect fan.. Link to comment Share on other sites More sharing options...
Oddmodman Posted May 18, 2014 Share Posted May 18, 2014 Did they really come with shrouds with the mech fans? I have 2 MJs and just sold an XJ and none had shrouds. Is that a common thing to rip out then? Link to comment Share on other sites More sharing options...
91Pioneer Posted May 18, 2014 Share Posted May 18, 2014 My truck has a shroud on the mech fan. Link to comment Share on other sites More sharing options...
HOrnbrod Posted May 18, 2014 Share Posted May 18, 2014 On 5/18/2014 at 12:16 AM, Oddmodman said: Did they really come with shrouds with the mech fans? I have 2 MJs and just sold an XJ and none had shrouds. Is that a common thing to rip out then? They all came with shrouds originally. But with age they tended to crack up from vibes and a lot of owners just ripped it out instead of replacing it. Guess they can't afford the $25 it costs from the dealer. Link to comment Share on other sites More sharing options...
Oddmodman Posted May 18, 2014 Share Posted May 18, 2014 Heat isn't hardly a factor here in Alaska, but I find that curious that all the 4.0s I've seen haven't had shrouds. :dunno: Link to comment Share on other sites More sharing options...
sloride Posted May 18, 2014 Share Posted May 18, 2014 Mine came new with the afore mentioned shrouds. One's cracked and barely hanging on with zip ties but its there. Link to comment Share on other sites More sharing options...
nitroxsteve Posted May 19, 2014 Share Posted May 19, 2014 I lost the original fan shroud due to bad motor mounts. Pick one from jy for $3. Link to comment Share on other sites More sharing options...
JeepFanactic Posted May 26, 2014 Author Share Posted May 26, 2014 Went to JY today and picked up a electric fan. Does anyone know which wires from the wiring harness plug into the fan. I have plug with a black wire and a red wire with white stripe. I also have a plug with a yellow wire and grey wire. I know one go to the fan and the other goes to the temperature switch. Just need to know which one goes where? Link to comment Share on other sites More sharing options...
Eagle Posted May 26, 2014 Share Posted May 26, 2014 On 5/16/2014 at 10:43 PM, randomguy310 said: I am not sure I buy that ... it would not run cool with out a shroud of some kind ducting the air out the mech fan , look at most cars and you will see the air is always ducted out to the fan Buy it or not ... facts are facts. We are not talking about "most cars," we are talking about Renix-era Jeep Comanches. If the truck did not come with an auxiliary fan, there is no auxiliary shroud. The photo I posted is a photo of the Renix-era Jeep XJ/MJ auxiliary fan. Link to comment Share on other sites More sharing options...
Eagle Posted May 26, 2014 Share Posted May 26, 2014 On 5/17/2014 at 11:46 PM, randomguy310 said: since when is it wrong to have an opinion about something? you know nothing about who I am or what I know or what I do.. I know exactly what the topic is.. I can read and write and fairly smart.. but I guess its wrong to have an opinion and disagree with someone.. Opinions are perfectly acceptable ... when the subject of discussion is a matter of opinion. In this particular case, it is NOT a matter of opinion. The Jeep XJs and MJs simply did NOT have a full-width shroud when equipped with only the primary, mechanical fan. This is not a matter of opinion; this is the fact and it doesn't matter what your opinion is nor what other vehicles may or may not have for shrouds. There is a separate shroud for the mechanical fan, that covers the right (passenger) side of the radiator. If the auxiliary electric fan is installed, its shroud is part of the fan -- just like the photo I posted. (The other photo of the two fans with curved blades shows the newer style aux fans. The photo I posted shows the Renix-era style) People come to this site for information on how to fix their heaps. Opinions are fine when everyone is guessing what the cause of a problem might be. However, when you make statements as fact that are factually incorrect, that doesn't help anyone and it can result in the member wasting time, effort and money. Link to comment Share on other sites More sharing options...
randomguy310 Posted May 28, 2014 Share Posted May 28, 2014 k... Link to comment Share on other sites More sharing options...
