Rockfrog Posted April 28, 2014 Share Posted April 28, 2014 Hi all, 'nother dumb question I haven't been able answer yet ... ... since I have the 2000 XJ front clip going onto the MJ soon ($100 for fenders header assembly and harness was to good to pass) ... I did not get the flares though ... I was figuring to re use the stock 1988 front flares ... will they fit? On another note ... good possibility I may end up with the whole XJ shortly. Link to comment Share on other sites More sharing options...
HOrnbrod Posted April 28, 2014 Share Posted April 28, 2014 I've never seen the old flares used with the new clip, but that doesn't mean it can't be done. I do know the old bumper can be used - looks good too. . Link to comment Share on other sites More sharing options...
relyt120 Posted April 28, 2014 Share Posted April 28, 2014 Should work, you will have to cut the though since the old flares are longer i the front. Use the old style brackets. Link to comment Share on other sites More sharing options...
MuddFoot Posted April 28, 2014 Share Posted April 28, 2014 or napier v2 flares look good too Link to comment Share on other sites More sharing options...
Rockfrog Posted April 28, 2014 Author Share Posted April 28, 2014 Have napiers on my XJ ... longer is not a problem ... I plan to keepnthe MJ 2wd amd roll on 31s with a 3.55 8.25 in the rear. Just the 00 update as I prefer that front end. If I end up with the whole XJ ... and don't wind up divorced ... I may swap the interior as well at some point. Thanks for the replies. Link to comment Share on other sites More sharing options...
Strokermjcomanche Posted April 28, 2014 Share Posted April 28, 2014 I've put the older style flares on the new fenders . The holes line up but you do have to cut the flares where it meets the bumper extension . Image Not Found Image Not Found Link to comment Share on other sites More sharing options...
ggcnash Posted April 29, 2014 Share Posted April 29, 2014 I would like to do this same thing. I have the fenders, and header just need to find time to do it. My plan is to keep old bumper also, I've always liked the new grill and header but just can't bring myself to like that big plastic looking bumper. Oh well to each his own Link to comment Share on other sites More sharing options...
Rockfrog Posted April 29, 2014 Author Share Posted April 29, 2014 Nope not doing the new bumper either ... going with a front receiver I currrently have on the XJ and a more utilitarian bumper. Link to comment Share on other sites More sharing options...
jamba Posted April 29, 2014 Share Posted April 29, 2014 After a small crash i had to fix nose of my mj. I ended up to put in facelift nose and shortened bumber from 86 parisienne. I stil have to cut flares and fenders a bit to make it look decent... Link to comment Share on other sites More sharing options...
92tanMJ Posted April 30, 2014 Share Posted April 30, 2014 I've put the older style flares on the new fenders . The holes line up but you do have to cut the flares where it meets the bumper extension . Image Not Found Image Not Found Looks good man! And btw I'm a little south of Dayton :waving: Link to comment Share on other sites More sharing options...
