Wiggilez Posted March 26, 2014 Share Posted March 26, 2014 Hello, I've been wondering where you guys have been finding your replacement floor pans, as I haven't been able to find any in the sore around where I live? Link to comment Share on other sites More sharing options...
HughMann Posted March 26, 2014 Share Posted March 26, 2014 same as front floor pans for an xj cherokee iirc. Link to comment Share on other sites More sharing options...
yxmj Posted March 26, 2014 Share Posted March 26, 2014 Here is a cheap set http://www.amazon.com/1984-96-Cherokee-Wagoneer-Comanche-Front/dp/B004GAX2G4 Ebay and other suppliers have them as well. Are yours so far gone that welding in patches is not even an option? Link to comment Share on other sites More sharing options...
gogmorgo Posted March 26, 2014 Share Posted March 26, 2014 XJ/MJ floor pans aren't the same. The front of them is close, but the section under the seat isn't. Replacement floor pans are available online. You might want to do a search on here, though, as some members have had issues with fit. Here's a decent starting point. Link to comment Share on other sites More sharing options...
Wiggilez Posted March 26, 2014 Author Share Posted March 26, 2014 Here is a cheap set http://www.amazon.com/1984-96-Cherokee-Wagoneer-Comanche-Front/dp/B004GAX2G4 Ebay and other suppliers have them as well. Are yours so far gone that welding in patches is not even an option? sorta, in between the "frame" bit and the door is bad, there wasn't much there, but in-between the "frame" and the tranny hump is still good. and I did try to weld in some pieces but 1 doesn't really look that nice, and 2 It did not function overly well as patch. that was for the driver side. The passenger is all still there including paint. and Gogmorgo thanks for the heads up about the differences. Link to comment Share on other sites More sharing options...
87Warrior Posted March 26, 2014 Share Posted March 26, 2014 Do NOT buy the Classic 2 Current/C2C floor pans. They have very little metal up the tunnel and fit like a square in a round hole. They also have no formed edges and seem to be built using a basic brake. That said, you will never find an MJ specific floor pan. Yes, some vendors advertise their pans for an MJ, but if you cross reference the parts numbers, they are the same for an XJ. A quality XJ front floor pan will fit pretty well, yet will have the issues as you approach the seat mounting area. Link to comment Share on other sites More sharing options...
Wiggilez Posted March 29, 2014 Author Share Posted March 29, 2014 most of my rust is closer to the pedal, So hopefully it should fit ok. Also still haven't decide which I want to use yet. Link to comment Share on other sites More sharing options...
87MJTIM Posted March 29, 2014 Share Posted March 29, 2014 I purchased from Z&M http://stores.zmjeeps.com/ I did not do the body work, but the shop that did the work did not say anything bad. I also purchased a bed side panel from them. They're in OH, USA. I don't know the shipping cost to the Great White North. Link to comment Share on other sites More sharing options...
Wiggilez Posted March 29, 2014 Author Share Posted March 29, 2014 seeing as I'll be installing them myself I think I should be able to splerge a little on the shipping :P Th only other thing stopping my is the damn weather, we just got another dump of snow :fs1: and I don't like working outside if it not nice out. Link to comment Share on other sites More sharing options...
