Lee21490 Posted January 4, 2014 Share Posted January 4, 2014 So recently my blower motor has decided to have a mind of its own, Half the time it works.. Half the time it doesnt. Last time i had the hood open, i closed it hard & the motor started working again. This time when it quit, I tapped it with a hammer.. And it started again. So I'm assuming that this is like a starter? Going to fail soon / needs to be replaced? Anyone got a guide how to replace it? 86 Comanche, With 95 dash/etc. Didnt really find any guides on google Link to comment Share on other sites More sharing options...
Mattwheels Posted January 4, 2014 Share Posted January 4, 2014 the blower motor should be exceptionally easy to access even with the dash. Just open the hood, on the passenger side theres 3 bolts that hold it in, its the round deal in the corner. Link to comment Share on other sites More sharing options...
onlyinajeep726 Posted January 4, 2014 Share Posted January 4, 2014 Yea, I have to replace mine too or just lube it up really good. Been squealing/whining in this colder weather. Link to comment Share on other sites More sharing options...
Lee21490 Posted January 4, 2014 Author Share Posted January 4, 2014 the blower motor should be exceptionally easy to access even with the dash. Just open the hood, on the passenger side theres 3 bolts that hold it in, its the round deal in the corner. Yea, Thats what it looked like to me, But you can never be too sure... Nothing is ever THAT simple :thumbsup: Now, New or junkyard. Decisions decisions. Link to comment Share on other sites More sharing options...
gogmorgo Posted January 4, 2014 Share Posted January 4, 2014 You can likely get one from a junk yard, but the new should last longer, be free of pathogens, and cost ~$30 at the chain parts stores. Link to comment Share on other sites More sharing options...
skidoo_j Posted January 4, 2014 Share Posted January 4, 2014 I got mine new from autozone for $25 and had to solder the plug on. A month later bought one for my brother from autozone and it already had the plug. Takes about 40 minutes if you are really careful and clean things in that area. Can be tricky to maneuver through the hoses near the purge tank. Ended up having to replace one on my brothers as we tweaked the rubber enough to initiate a small leak. Link to comment Share on other sites More sharing options...
Minuit Posted January 4, 2014 Share Posted January 4, 2014 Do the Autozone ones come with gaskets? Link to comment Share on other sites More sharing options...
jimoshel Posted January 4, 2014 Share Posted January 4, 2014 I once drilled a hole into the housing over the bearing and gave it a couple drops of oil. Never had a bit of trouble with it after that. Link to comment Share on other sites More sharing options...
Lee21490 Posted January 7, 2014 Author Share Posted January 7, 2014 I got mine new from autozone for $25 and had to solder the plug on. A month later bought one for my brother from autozone and it already had the plug. Takes about 40 minutes if you are really careful and clean things in that area. Can be tricky to maneuver through the hoses near the purge tank. Ended up having to replace one on my brothers as we tweaked the rubber enough to initiate a small leak. Ended up actually breaking a nipple off the windsheild washer resivoir.. Threw a whole gallon of rainx all over the brand new Blower motor! :thumbsup: Nothing a screw couldnt fix though~ Do the Autozone ones come with gaskets? Idk about the more expensive ($29~) One, But the $21 version does not. Assuming none of them do. My gasket was brand new looking though, Not sure if they ever really go out on it.. Link to comment Share on other sites More sharing options...
skidoo_j Posted January 7, 2014 Share Posted January 7, 2014 I got mine new from autozone for $25 and had to solder the plug on. A month later bought one for my brother from autozone and it already had the plug. Takes about 40 minutes if you are really careful and clean things in that area. Can be tricky to maneuver through the hoses near the purge tank. Ended up having to replace one on my brothers as we tweaked the rubber enough to initiate a small leak. Ended up actually breaking a nipple off the windsheild washer resivoir.. Threw a whole gallon of rainx all over the brand new Blower motor! :thumbsup: Nothing a screw couldnt fix though~ Are you talking about your coolant tank???? that is antifreeze not windshield washer reservoir. Link to comment Share on other sites More sharing options...
Lee21490 Posted January 7, 2014 Author Share Posted January 7, 2014 I got mine new from autozone for $25 and had to solder the plug on. A month later bought one for my brother from autozone and it already had the plug. Takes about 40 minutes if you are really careful and clean things in that area. Can be tricky to maneuver through the hoses near the purge tank. Ended up having to replace one on my brothers as we tweaked the rubber enough to initiate a small leak. Ended up actually breaking a nipple off the windsheild washer resivoir.. Threw a whole gallon of rainx all over the brand new Blower motor! :thumbsup: Nothing a screw couldnt fix though~ Are you talking about your coolant tank???? that is antifreeze not windshield washer reservoir. The coolant resivoir is more towards the front of my truck, The washer resivoir is straight on top of the blower motor. Has a 95 engine / works, I didnt do the swap. Link to comment Share on other sites More sharing options...
