Bad Gas Mileage
Okay guys I've recently been noticing that I've really got bad gas mileage. I had 160 miles on the trip when I added 15 gallons to it yesterday. I think I fixed the rough idle, need to get some vacuum line bushings though. I shift at 2300 rpms (to high? To low?) I'm running 30x9.50 mud tires on stock gears, could this result in anything? Ive got idle adjusted to about 800 rpms. Ive got new muffler with no cat on stock pipes. But a small exhaust leak hole (waiting till I repipe to 2.5" before I fix that) and Ive still got my bad rms leak. 4.0/ba10/4x4 with 224k miles. Please give me every little thing that could be causing this because I can't afford the gas. Should I readjust the TPS?
  • Replies 90
Not from what I could tell. I had to tape up the connection to the MAP sensor because it was so rotted. The only other bad one I can find is the oil return line (I think?) Does anyone have a diagram of the complete vacuum line harness? I think I may actually be missing a line from the air box...
A bad or failing oxygen sensor results in poor fuel mileage because the engine is always running rich. Same thing can happen if you run a cold (or no) thermostat, or if the coolant sensor (the one on the side of the block, that sends data to the ECU) is bad.
So i should do what? Adjust the tps again? And what rpm should I? And how do I change the oxygen sensor? This all explains alot. Where can I get the new map sensor connection? Its not the line I taped, just the rotten end at the MAP sensor.
Thanks.
nd, you're shifting at way too low an RPM,
No he's not. It's a Renix, not an HO. I have always shifted at 2200 RPM. My '88 XJ (287,000 miles) still gets 20 MPG, and the '88 MJ (125,000 miles) gets 18 to 19 MPG.
MAP line taped?  Not good.
X2 on this.  Vacuum lines are MUCH cheaper than gas.  Get the proper, or at least SOUND vacuum tubing.  One whole solid piece, not repaired...replaced.  You can even get a MAP sensor at the junkyard for a song.You should be getting at least 250 miles on a tank IMHO.
I see tons of sketchy and missing vacuum configurations in the junkyards.  Buy the correct harnesses where you need to, and the rest of the vac lines can be just bulk line...like 75 cents or $1 a foot.  Taped up and/or spliced lines are invitations for leaks, ergo poor performance...and bad mpg.
Geez. I've only shifted at higher RPMs since these were new in 1987 and never had mileage issues. HO stands for Highly Overrated anyway. That's lugging it.
Thanks.
I want to know how YOU adjusted the idle.
Is there like a package I can buy that has all the vacuum lines? Like a harness or something?
I listed the part numbers of the three main vac lines you need, search any auto parts site. They are very simple to install. The last one would be the MAP line, do what has been posted, buy bulk vac line and replace it.
This is what the 003 & 004 parts look like:
And on the engine:
89 with a BA10 transmission? I thought they were AX-15 after 88. Maybe an early 89?
Correct. The change to the AX-15 was a mid-year change in the 1989 model run. Around the same time was when the C101 firewall wiring harness connector went away.
Shifting at 2200 RPM is lugging it? Not hardly. With the automatic and stock tires, 2200 RPM is about 68 MPH in overdrive. I don't think comes anywhere near ANY definition of "lugging it."
Uncalled for ignoramus maximus statement that does nothing to answer the OP's question.
Point being that HO or Renix, short shifting at low RPMs does not guarantee better mileage figures.
I simply adjusted it by screwing that allen wrench screw off the TB. I'm guessing now that that was a bad idea and shall do everything according to what you recommend. And thank you for the pictures. How many lines come off the air intake box? And the BA10 was in them till about mid 89. Mine was made in febuary. Hence the ba10
