Crash Posted October 21, 2015 Author Share Posted October 21, 2015 Got my RK adjustable UCA's today. These things look very beefy. https://drive.google.com/file/d/0B5GWNl5w3W72T0lPLTFONFhoSmxZR3FXeDRXOFFxZFdwbUJB/view?usp=sharing Think that I will run the custom square tube lowers as it for meow, along with these. And maybe pick up some ruffstuff square tube inserts and some joints to go with them. Link to comment Share on other sites More sharing options...
Crash Posted October 26, 2015 Author Share Posted October 26, 2015 Got the front of my MJ lifted this weekend. https://drive.google.com/file/d/1EmWWNkzXVFpPVsvhyHtrt83s1H9XU1m8Ag/view?usp=sharing https://drive.google.com/file/d/1sIMZOejpCC5o1q6RyPBXzD6JV09U-CiJXQ/view?usp=sharing https://drive.google.com/file/d/1-e8jy-z8mNeKPrRJkE37x_ck-Pm_FDrCNw/view?usp=sharing RE XJ coils (PN unknown), that have been cut down some. Synergy Suspension track bar mount and brace/Unknown adjustable TB with FK heim/Synergy mis spacers. RK adjustable UCA/Stock LCA for meow. My old IM4x4Fab tie rod JKUR Shocks/homebrew BPE's Straightened out the hard brake line for more travel. Will be install some SS braided lines when they arrive. I initially kept the stock tie rod, but it it ended up being in bad shape. Had the craziest DW I have ever personally experienced. Every time I would come back home and check toe after a test drive it was off. I made sure that the adjusters were tight, but I should have just gone with my instinct to swap my HD tie rod to begin with. Anyways, after it is all said and done, it drives good now. Just like on my XJ, the front end feels more solid with the aftermarket TB mount/brace. The coil are on the stiffer side too, which is fine by me. Link to comment Share on other sites More sharing options...
88whitemanche Posted October 26, 2015 Share Posted October 26, 2015 Looking good man! Link to comment Share on other sites More sharing options...
Crash Posted November 1, 2015 Author Share Posted November 1, 2015 Thanks! Looking good man! Got some "free to me" longer shackles installed on my MJ. Thanks to the help of my friend Zac, and I gave him my stock MJ shackles. Once again, I didn't measure but figure a quick search or if someone knows what "stock-ish" height is supposed to be from hub to flare. Anyways, there is a noticeable difference. https://goo.gl/photos/NqYRHh6u3cvQRX7n7 https://goo.gl/photos/xUuyzfPb2MUKgc6j6 Link to comment Share on other sites More sharing options...
Crash Posted November 7, 2015 Author Share Posted November 7, 2015 Got my Chinexican HL harness installed today. I must say, that it looks good for the price of about 15$ via ebay. Not a great pic, but a pic of it on my floor. https://drive.google.com/file/d/1OAFy0QQzml1hEHNmQNwXrGQlaQMU95osnQ/view?usp=sharing I like that it uses standard style relays. We will see how long these cheap ones work before they fail. But I have a small drawer-full of relays. Link to comment Share on other sites More sharing options...
Crash Posted November 12, 2015 Author Share Posted November 12, 2015 Picked up (2) pair of LED cubes from amazon. Aside from dropping in price since I first heard about them, the seller (Prime ship and fullfilled by Amazon) had a 3$ discount for buying 2 or more sets together. https://goo.gl/photos/P59ssg7YD7KN1igW8 That is just one set, but they feel good. I picked up a set of spots and a set of floods. My back-up lights do not function, probably a NSS issue or whatever, but figured some extra light out back is not a bad thing. One light would work fine in the rear. But I think I will run (1) of each type front and rear. Depending on how well these work, I may purchase another pair/set or something like it, to run as "work lights" of sorts in the bed area. I have some LED strip lights that I want to setup under the rails of the bed for potential bed lighting. For "low-light" visibility for load/unload and camping. Link to comment Share on other sites More sharing options...
Crash Posted November 15, 2015 Author Share Posted November 15, 2015 Purchased an ext slave AX15 setup. Has clutch, new MC/slave cyl, flywheel pedals, etc. Will be picking up next weekend. Hopefully will have the 4WD swap done sometime next month. Also, installed the lights in the front. They are nice, white and bright. Need more wire to run lights to the back. Link to comment Share on other sites More sharing options...
Crash Posted November 29, 2015 Author Share Posted November 29, 2015 Placed an order for a DBO, Stubby recovery bumper w/ Receiver add-on. He has sales going for BF, and I had a gift cert I got at a Naxja event last year. So, figured it was a good time to use it. Hopefully that will arrive and be installed by around Xmas time. Link to comment Share on other sites More sharing options...
Crash Posted December 5, 2015 Author Share Posted December 5, 2015 Ordered these H4 conversion housings, along with some Hella 100/80 bulbs. http://smile.amazon.com/gp/product/B006WCOG5A?psc=1&redirect=true&ref_=oh_aui_detailpage_o00_s00 I figured I would give them a shot for the price, I figure if they suck I can return them to amazon. Also, ordered a set of the RE 9900 CAD-brackets from a seller on Amazon for LESS than the RC kit! Hopefuly I will be riding in better comfort soon. Link to comment Share on other sites More sharing options...
Crash Posted December 10, 2015 Author Share Posted December 10, 2015 I received the items mentioned in above post already! Super stoked about that. So, hopefully, project time this weekend. I could probably do the headlight swap after work, but it's DARK when I get home currently. So, I will wait until I have daylight and time to sort things out if there is a glitch. I want to do LCA and CAD bracket swap first though. Overall I like how it steers and no bumpsteer, but better ride with proper-ish control arm angles is what I want. Link to comment Share on other sites More sharing options...
Crash Posted January 15, 2016 Author Share Posted January 15, 2016 Not too much to update. On my days off it has been raining, and was spending most of my off time with family. My sister and her husband left for Japan again last week.Received my DBO stubby recovery bumper just after new years. My friend is going to paint it for me. I want to upgrade the steering box spacer at the same time I install the bumper.Hopefully in the next couple weeks I will install my adjustable LCA's and CAD brackets.Also, still need to install my new H4 housings/bulbs, and "reverse lights" Link to comment Share on other sites More sharing options...
Crash Posted January 17, 2016 Author Share Posted January 17, 2016 No pictures yet. But I got my RE CAD brackets/ adjustable lowers installed yesterday. The arm angle looks good. The lowers have a bend in them, but doesn't hang too low. Not planning on rock crawling anyways. Should work well in the sand. I'm guessing that I will be looking for better shocks soon. Link to comment Share on other sites More sharing options...
Crash Posted February 7, 2016 Author Share Posted February 7, 2016 Installed my DBO stubby bumper w/ receiver, and Nates4x4 steering box brace. https://goo.gl/photos/Hhkt6NjA5w7pt4iz8 https://goo.gl/photos/hVWVjxC6xLtW22D57 What a difference it makes, running an aftermarket brace vs the stock POS when it comes to bolting the box back up. Link to comment Share on other sites More sharing options...
Crash Posted October 29, 2016 Author Share Posted October 29, 2016 Not much to update. I enjoy DD'ing my MJ. Still 2WD, since trans went out in my XJ. Priorities.. Anyways my gf and some friend enjoy pumpkin carving. Didn't know what to create so I found this template online. I just looked at the pic and winged it. Link to comment Share on other sites More sharing options...
dustyinthedirt Posted October 29, 2016 Share Posted October 29, 2016 Thats a sweet pumpkin!!! Link to comment Share on other sites More sharing options...
Crash Posted December 7, 2016 Author Share Posted December 7, 2016 Picked up this 01 5.3 vortec for a very good price. Looking at trans options. I'd like to keep my MJ as a manual trans truck. There's a couple of 4l60e's in the back of the shop. If I can't find a manual trans for a reasonable price, I will probably do this swap in my XJ. Link to comment Share on other sites More sharing options...
desbennett004 Posted December 9, 2016 Share Posted December 9, 2016 Picked up this 01 5.3 vortec for a very good price. Looking at trans options. I'd like to keep my MJ as a manual trans truck. There's a couple of 4l60e's in the back of the shop. If I can't find a manual trans for a reasonable price, I will probably do this swap in my XJ. You can get an adapter for the AX15. Supposedly it can handle a mild V8 build. Sent from my SM-N900W8 using Tapatalk Link to comment Share on other sites More sharing options...
Crash Posted December 9, 2016 Author Share Posted December 9, 2016 I understand that. But I don't have a 4wd AX15. So it would be that + the 400$ adapter. Link to comment Share on other sites More sharing options...
ggcnash Posted December 9, 2016 Share Posted December 9, 2016 Yea and I wouldn't trust an ax15 behind a stock gen3+ sbc, maybe a gen1 or 2 bone stock and even then I would be nervous. Sent from my SAMSUNG-SM-G890A using Tapatalk Link to comment Share on other sites More sharing options...
Crash Posted January 31, 2017 Author Share Posted January 31, 2017 Update: Bought a 4WD AX-15, should be sometime next week. Installed H4 housings and hella 80/100 bulbs. Re-installed my led cube "fog lights", found a stock apparatus with fog switch so I wired them to that. Buying a matching pair of tires to replace the worn ones I have up front. I currently work (6) 10's per week, but hoping to have my WJ D30 prepped to install in the next couple of weeks. Thinking about purchasing the IM4x4 chromoly WJ steering. Link to comment Share on other sites More sharing options...
Crash Posted February 24, 2017 Author Share Posted February 24, 2017 My new $ 500 DD, Shelby Should help aide in the conversion process and saving coin on fuel and manitenance. Link to comment Share on other sites More sharing options...
Crash Posted March 17, 2017 Author Share Posted March 17, 2017 Picked up 2 sets of these from the memeber at CF that cruiser recommended. I'll probably toss a set in my XJ first and see how they work in comparison to the 703's I have the Ford 5.0 injectors in my MJ currently which do well. I average 18.5 mpg in my daily commute when driving my MJ. I get 29 in my hooptie. Link to comment Share on other sites More sharing options...
Crash Posted April 8, 2017 Author Share Posted April 8, 2017 New apparatus to use to make stuff. Link to comment Share on other sites More sharing options...
Crash Posted November 14, 2017 Author Share Posted November 14, 2017 Got my WJ D30 swapped in this last weekend. Mostly plug n pray. Draglink and track bar need to be addressed. Sway bar link at axle end, if it applies. Link to comment Share on other sites More sharing options...
Crash Posted July 2, 2020 Author Share Posted July 2, 2020 Not much has happened with the MJ, til more recent. Have a lot of things going on in life. Been dding her sinc e my dd is down. Last week, I installed Scarfab hitch. Saturday should be paint. Still 2wd, and some quirks to work out.Going to be spraying primer with a gun, and then rattle can "Khaki camo". Also, going to adjust the door latches so they close correctly. That is all for now. Link to comment Share on other sites More sharing options...
