Aluminum 2.5 Valve Cover
Yes. The non renix 2.5L motors generally had an aluminum valve cover. When you find one, buy a Fel-Pro Permadry gasket for a '98 Dakota 2.5. No more cork leaks. That said, I suspect the valve cover from a 2.5 Dakota should be aluminium and should work on the Jeep, but I do not know for sure.
My '86 2.5L sports an aluminum valve cover from a '93 XJ and the Permadry gasket for a Dakota. No leaks :)
All the AMC/Jeep 2.5L valve covers will fit one another regardless of the year.  The Dakota used the AMC 2.5L (not to be confused with the 2.5L Chrysler K-series engine that was used also).  But, keep in mind that if you're going from the plastic VC to the aluminum one, you need to use the longer bolts that are found with the aluminum VC otherwise you won't be able to bolt it down.  I found that out that hard way, but luckily I held on to them from the junkyard.
I look thanks, mine just cracked and the whole 2.5 is starting to tick me off.
YUP ...i heard that pain well ..i found a 94 xj aluminum one 3 years ago in the bone yard for 20 bucks ! yes they are out there ,seek and you will find one ! its worth it !!
What year dakota did you get the gasket from? I have an aluminium vc no gasket... the vc is from 94 yj and the only gaskets I can find are cork...
Do you remember what size bolts for the aluminum cover are? I'm switching from plastic and new cover did not come with bolts...
  • 1 year later...
Hi all
   just thought i would throw some things out there.  I have a 86 V6 and a 87, 2.5, 4 cylinder  and i have replaced both engines with re-manufactured from Gearhead's Engines,  when the 2.5 was replace I got a cover from Auto Zone for $60.00, it is a special order but it is aluminum and works well with a good gasket ( Not Cork). Also there is a company in England that has redesigned performance carbs that has been work awesome for power and mileage in my naturally aspirated V6.  I will try to hunt down the name, its been a while since I ordered it.
Just some info.
Cheers
  • 2 years later...
15 minutes ago, saveevryjp1998 said:
So autozone has got a 3rd felpro vs50502r on its way. It now appears after checking and rechecking pics and crossreferencing to no end that there may be a production packaging error. If the 3rd one comes back the same I will order the mahl version which is more yet and takes longer to get. The last one we tried was opened and returned already.
This is your problem.
  • 3 years later...
