Geonovast Posted April 9, 2013 Posted April 9, 2013 Get a measurement on both sides of spring perch to backing plate. Looks like your axle is off center. What's the new axle from? Did you put the perches on it?
birdie5 Posted April 9, 2013 Author Posted April 9, 2013 Get a measurement on both sides of spring perch to backing plate. Looks like your axle is off center. What's the new axle from? Did you put the perches on it? Sorry, I have no idea what a perch is or what I am supposed to measure. Do you mean where did he get the rear end he put in? Have no idea. Should I try to get the old one back and have it rebuilt? That's what i wanted and he insited on putting a new (used) one in. Doesn't it look a little beat up - the old one looks better to me.
birdie5 Posted April 9, 2013 Author Posted April 9, 2013 what do you mean by "drags"? Like the break is on or something. I don't think the emergency brake is hooked up anymore either. And it's completely rusted where it connects to the wheel on both sides.
Geonovast Posted April 9, 2013 Posted April 9, 2013 I think we need a little more background, as I appear I was incorrect in assuming this was your truck. The brakes may very well be locking up if the new axle sat awhile or is misadjusted.
birdie5 Posted April 9, 2013 Author Posted April 9, 2013 I think we need a little more background, as I appear I was incorrect in assuming this was your truck. The brakes may very well be locking up if the new axle sat awhile or is misadjusted. It is my truck! Doesn't feel like it's locking up, it just drags, if that makes any sense.
92tanMJ Posted April 9, 2013 Posted April 9, 2013 I think you both are saying the same thing and mean that they're partially engaging. Which would make them 'drag'. My guess is your load sensing valve is not properly adjusted.
birdie5 Posted April 9, 2013 Author Posted April 9, 2013 I think you both are saying the same thing and mean that they're partially engaging. Which would make them 'drag'. My guess is your load sensing valve is not properly adjusted. Thanks. I am taking it back to them tomorrow. Does the appearance concern you? It looks all beat to hell. Will it hurt to drive it like this?
Eagle Posted April 9, 2013 Posted April 9, 2013 The load (height) sensing valve will not affect the brakes dragging. But the adjustment of the star wheel inside the drums will. And if the parking brake cable is rusted and can't release completely, that will also cause the brakes to drag.
HOrnbrod Posted April 9, 2013 Posted April 9, 2013 Load sensing valve can't cause drag. Jack it up by the pumpkin and try to rotate the wheels. They should turn freely with just a little drag on the brake shoes. The e-brake could be rusted nearly shut also. You can't tell anything by looking at it.
Eagle Posted April 9, 2013 Posted April 9, 2013 I think you both are saying the same thing and mean that they're partially engaging. Which would make them 'drag'. My guess is your load sensing valve is not properly adjusted. Thanks. I am taking it back to them tomorrow. Does the appearance concern you? It looks all beat to hell. It's a Dana 35 rear axle. You have a 1988 MJ. The last MJ was built in 1992 and it's now 2013, so the newest any used MJ axle could possibly be is 21 years old. The axle came from a junkyard -- seriously, what were you expecting? It doesn't look beat to hell -- it looks like it was lying in a junkyard for quite awhile, the paint got scraped, and where there's no paint it has started to rust. Wire brush it, spray it down with brake cleaner, and go crazy with gloss black Rustoleum. You had a shop do the install? The old axle is yours -- he should have given it to you, unless you specifically instructed him to throw it away.
birdie5 Posted April 10, 2013 Author Posted April 10, 2013 Thanks everyone. I went ahead and drove it tonight and a couple of times it rumbled, like when you hit those small speed bumps. I don't know, I'm taking it in and I'll see what happens. And I knew the rear end would be old that's why I wanted mine rebuilt. Hopefully he still has my old one and I can get it tomorrow.
comanchedude Posted April 10, 2013 Posted April 10, 2013 .??. Well I'm sure it would cost you 5 times more money to have a shop rebuild your axle . If you are hearing noise take it back have them check it. Could be several things. Other than that.looks fine I don't see any issues in the picture.
birdie5 Posted April 11, 2013 Author Posted April 11, 2013 .??. Well I'm sure it would cost you 5 times more money to have a shop rebuild your axle . If you are hearing noise take it back have them check it. Could be several things. Other than that.looks fine I don't see any issues in the picture. Actually the quote I got from another mechanic to rebuild it was $400 less but the guy that replaced it had already torn it apart. Went back today, the brake shoes needed adjusting and they fixed the emergency brake, it's better now, he said I need to drive if for a few hours. Refused to give me the old rear end though said he had to return it to the place he got the new one because of a "core charge"? Tried to tell me you always have to return the old part, never heard of that. He said if I wanted it I had to pay $250 for it.
Bornindesert Posted April 11, 2013 Posted April 11, 2013 .??. Well I'm sure it would cost you 5 times more money to have a shop rebuild your axle . If you are hearing noise take it back have them check it. Could be several things. Other than that.looks fine I don't see any issues in the picture. Actually the quote I got from another mechanic to rebuild it was $400 less but the guy that replaced it had already torn it apart. Went back today, the brake shoes needed adjusting and they fixed the emergency brake, it's better now, he said I need to drive if for a few hours. Refused to give me the old rear end though said he had to return it to the place he got the new one because of a "core charge"? Tried to tell me you always have to return the old part, never heard of that. He said if I wanted it I had to pay $250 for it. Sounds like your replacement axle came from a rebuilder rather than a JY. In that case, yeah it would be rational to believe he had to turn in a core axle. Question I have is, what did you get with your replacement axle? Hopefully new outer axle bearings and seals, and carrier bearings/pinion bearings and seal. If it's just a JY axle with freshened up brakes, seems odd. I've never heard of the JY wanting the old one back, but I guess it's possible. Something doesn't quite add up... But, at least you are back on track, problem solved!
JFAComanche6 Posted April 11, 2013 Posted April 11, 2013 Doesn't surprise me that theres a core charge, it's a rebuildable part. The JY's around me do cores on lots of parts like axles, A/C's, starters, alternators, engines, tranny's, etc.
Bornindesert Posted April 11, 2013 Posted April 11, 2013 Doesn't surprise me that theres a core charge, it's a rebuildable part. The JY's around me do cores on lots of parts like axles, A/C's, starters, alternators, engines, tranny's, etc. In the case where the JY does a core charge, do they provide axles that are rebuilt? Or do they re-sell the core to a rebuilder?
MJCARENA Posted April 11, 2013 Posted April 11, 2013 When I got the axle from the JY they only charged a $20 core charge. I think it was just for scrap weight.
Geonovast Posted April 11, 2013 Posted April 11, 2013 What kind of rebuilding wouldn't clean up the outside and paint it? Sounds like complete BS to me. There's no way a rebuilder is short on D35s, and they're not worth rebuilding anyway. You could easily score a D44 or 29 spline Chrysler 8.25 for less than $250.
Eagle Posted April 11, 2013 Posted April 11, 2013 I am accustomed to seeing core charges in parts stores for things that are commonly rebuilt and sold as such, like alternators and starters. Granted, I'm only 69 years old and I've only been playing gearhead since I was 14 (that's a mere 55 years), but I have never heard of a junkyard charging a core charge for something like a used axle. And the axle in that photo does NOT look like a rebuilt axle. A rebuilt would have at least had a thin coat of cheap black paint on it. I strongly suggest that you never go back to that shop for other work. He's a robber.
Zebvance Posted April 12, 2013 Posted April 12, 2013 I just picked up a 8.8 for my mj and I was on the search for a 4.10 31 spline one for a while I called at least 20 junk yards and I would say about half of them wanted a old axle in exhage or to pay upwards of a 100 core. I know it's crazy but junk yards are doing it now.
birdie5 Posted April 12, 2013 Author Posted April 12, 2013 I am accustomed to seeing core charges in parts stores for things that are commonly rebuilt and sold as such, like alternators and starters. Granted, I'm only 69 years old and I've only been playing gearhead since I was 14 (that's a mere 55 years), but I have never heard of a junkyard charging a core charge for something like a used axle. And the axle in that photo does NOT look like a rebuilt axle. A rebuilt would have at least had a thin coat of cheap black paint on it. I strongly suggest that you never go back to that shop for other work. He's a robber. Yeah, I think he's full of it. He told me that he had to put a new seal on it and then he tried to tell me there wasn't any rust on it?!?!?
mjeff87 Posted April 12, 2013 Posted April 12, 2013 and not to pick nits, but from that pic of the "new" axle, it doesn't look like your guy used new U-bolts on the leafpacks. I would strongly suggest you either ask him to replace with new, or do it yourself and eat the small cost involved. Reusing the old ones is bad ju ju.... Jeff
sinkrun Posted April 12, 2013 Posted April 12, 2013 If it was a rebuild he should have some sort of paperwork from the rebuilder I would demand to see it or where this rebuild shop is.
