Pete M Posted January 15, 2006 Share Posted January 15, 2006 Â :D Jeep on! --Pete Link to comment Share on other sites More sharing options...
pingpong Posted January 15, 2006 Share Posted January 15, 2006 AWWW... thats so cute. :D What did you name him :wink: Link to comment Share on other sites More sharing options...
rjontzen Posted January 15, 2006 Share Posted January 15, 2006 Congratulations........ :D Â what are the specs??? Link to comment Share on other sites More sharing options...
Pete M Posted January 15, 2006 Author Share Posted January 15, 2006 1990 4x4, 206k mile 4.0L, AX-15, shortbed, all the factory "armor", new gas tank, plenty of issues. Drivers seat is broken, window doesn't crank all the way down and then you have to help it back up, no headliner, hood pull broken, all the usual oil leaks, all the usual half-assed rust repairs, very little floor left on drivers side, 4wd shifter linkage doesn't work well (hopefully due to the flex in what's left of the floor), shocks are toast, wiper bushings are toast and the intermittant settings don't work at all, hole in clutch line, it appears that the previous clutch master cylinder leaked on the fuse box, brake lights come on with the headlights, part-time light has a mind of its own, uh, I think that's all I've found so far. I think I did pretty good for $300. :D He's going to be sitting for a while until I can save up some cash and fix the clutch line, but eventually I'm looking for a new daily driver out of this. Someday I'm thinking that I will swap in my Dana 44 with 3.55s, add a matching XJ front from the junkyard, then a 3" lift and some 31s. The 235/65s are just too small for me, but I want to do gears first. Jeep on! --Pete  P.S. It looks even cuter when you see it next to my 88. :D  Link to comment Share on other sites More sharing options...
89Tonto Posted January 15, 2006 Share Posted January 15, 2006 Well, if you look at it a different way- the 88 could be momma MJ nursing it's baby. :roll: Nice find! Link to comment Share on other sites More sharing options...
comanchedude Posted January 16, 2006 Share Posted January 16, 2006 Pete  If you decide you want to sell that roll bar I see there in the bed of that baby make sure you let me know :D Link to comment Share on other sites More sharing options...
Pete M Posted January 16, 2006 Author Share Posted January 16, 2006 Funny you should mention that. You've got mail! Jeep on! --Pete Link to comment Share on other sites More sharing options...
87manche Posted January 16, 2006 Share Posted January 16, 2006 so that's the Toledo truck eh? glad to see you got it home in one piece. Good luck getting the cltch hose. It took two tries and a week for my NAPA to get it in. I think I have the box in the garage. If I find it I'l post the P/N for the ax-15 hose. Link to comment Share on other sites More sharing options...
Pete M Posted January 16, 2006 Author Share Posted January 16, 2006 It's still to be proven that the t-case isn't trashed, and if it's bad, I may just replace the trans/t-case as a unit and if I do that it'll be with an external slave. Or maybe I can go with an np-242 instead. Hmmm.... Or more likely I'll just pull the trans off and fix whatever's leaking. But there's no fun in dreaming about *that*. :D Jeep on! --Pete Link to comment Share on other sites More sharing options...
87manche Posted January 16, 2006 Share Posted January 16, 2006 yeah, I may start looking for a 242... the more I read about full time 4WD the more I want it. Link to comment Share on other sites More sharing options...
DirtyComanche Posted January 16, 2006 Share Posted January 16, 2006 Why bother with the 242? I guess if you see a lot of street. Link to comment Share on other sites More sharing options...
87manche Posted January 16, 2006 Share Posted January 16, 2006 my MJ is currently more of a DD than a trail rig. So it would be nice. Last night I was especialy wanting it, with mixed dry asphalt and icy patches. Link to comment Share on other sites More sharing options...
Pete M Posted January 16, 2006 Author Share Posted January 16, 2006 Same here. This will be my daily driver and the 242 is a fine choice for that. Jeep on! --Pete Link to comment Share on other sites More sharing options...
pingpong Posted January 16, 2006 Share Posted January 16, 2006 I have a 242 and an AW4 I will let go cheap :D Or you can just buy the 242, and let me have your 231. Â Â Â Patrick Link to comment Share on other sites More sharing options...
whowey Posted January 17, 2006 Share Posted January 17, 2006 I really miss my 242, in our lovely midwestern weather. The 249 in my ZJ is close but I don't like the VC. Link to comment Share on other sites More sharing options...
DirtyComanche Posted January 17, 2006 Share Posted January 17, 2006 I just use my 231 when things get ugly. Which is about 6 months of the year. Otherwise I only need 2wd anyways... Â Â I guess it'd be nice, but I don't need things complicated. Link to comment Share on other sites More sharing options...
Pete M Posted January 17, 2006 Author Share Posted January 17, 2006 Today I spent all of $50 and got a complete dual exhaust (not a true dual though, post-muffler), a complete drivers door (it's toast, but I need the crank mechanism and glass and it was easier to just cut the door off), a great tilt steering column, a spare computer, 2 taillights, and a bunch of other odds and ends. :D I also found a j-yard selling an external slave AX-15 for $200 which isn't really all that much more than fixing the leaky internal slave on my 200k+ trans. Same yard has a couple 242s also. It's a bit of a drive from my house though, so we'll see. My new MJ is a little bit closer to becoming a daily driver. :D Jeep on! --Pete  P.S. ComancheDude, check your messages!! Link to comment Share on other sites More sharing options...
87manche Posted January 17, 2006 Share Posted January 17, 2006 is this yard north or south of you, sounds like they have a whole lot of jeep stuff. I promise I won't snake that trans from you. Link to comment Share on other sites More sharing options...
Pete M Posted January 18, 2006 Author Share Posted January 18, 2006 No big secrets here. I used car-part.com Jeep on! --Pete Link to comment Share on other sites More sharing options...
rebeljeeper01 Posted February 1, 2006 Share Posted February 1, 2006 just catching up from my move nice truck pete! Link to comment Share on other sites More sharing options...
c0mt3k Posted February 17, 2006 Share Posted February 17, 2006 hmmm i wonder is that rollbar up for grabs? i would really liek to have it... Â oh yeah and for anyone interested i jsut found this on ebay: Â http://cgi.ebay.com/ebaymotors/NOS-Jeep ... 3084QQrdZ1 Link to comment Share on other sites More sharing options...
Pete M Posted February 18, 2006 Author Share Posted February 18, 2006 The rollbar's fate is now up in the air. I'm having difficulty removing it without hurting it and it's rustier than I originally thought. Jeep on! --Pete Link to comment Share on other sites More sharing options...
Oizarod115 Posted February 24, 2006 Share Posted February 24, 2006 hey pete.. this is totally off topic, but... do you still have the origional BA10 in your 88? how did (or does) it hold up... the one in my 89 has bout 173k on it but seems fairly good, i was wondering just HOW bad they really are. Link to comment Share on other sites More sharing options...
Pete M Posted February 24, 2006 Author Share Posted February 24, 2006 My 2wd Peugeot self-desrtucted at the 183k mile mark. Blew a hole out the side on the freeway, draining the gear oil in a hurry and causing the gears to emit an ear-shattering whine. Still got me home though (can't say that about ANY automatic). 30 miles or so and for the last 5 I was stuck in 3rd. Then she sat in my driveway for 2 years before the 4wd conversion began. Keep the fluid level up and be easy to it and it *should* be ok. Add big tires or a heavy right foot into the mix, and you might want to start researching the AX-15 swap. :D car-part.com and your local pick-n-pull 'yards are your friends. Jeep on! --Pete Link to comment Share on other sites More sharing options...
whowey Posted February 24, 2006 Share Posted February 24, 2006 hey pete.. this is totally off topic, but... do you still have the origional BA10 in your 88? how did (or does) it hold up... the one in my 89 has bout 173k on it but seems fairly good, i was wondering just HOW bad they really are. Â Mine made it 140k, Now I have 260k on the odometer. I'm thinking I'd better start saving my pennies. Link to comment Share on other sites More sharing options...
