comanche1989 Posted February 11, 2013 Share Posted February 11, 2013 Hello Everyone. I'm in the process of rebuilding the engine from my 1989 Manche with the 4.0. I'm almost complete, all I have to do is reinstall the oil pump and throw the oil pan back on. But I've run into an issue. When I removed the oil pump there was a thin paper gasket where the pump mates to the block. It was torn so I threw it away. I can't find the new gasket for the life of me. Anybody know where I can purchase one, or if its even necessary? I went to all the auto parts store in my town and none have any, even in their computer database. Any help would be appreciated. :bowdown: Link to comment Share on other sites More sharing options...
jimoshel Posted February 11, 2013 Share Posted February 11, 2013 I grew up making needed gaskets out of card board. Now that I'm older and got more sense I use the knot hole in the fence,,,ah,,I mean i use RTV. Make sure both surfaces are clean. Apply a very narrow bead around the the outer edge. Link to comment Share on other sites More sharing options...
comanche1989 Posted February 12, 2013 Author Share Posted February 12, 2013 I grew up making needed gaskets out of card board. Now that I'm older and got more sense I use the knot hole in the fence,,,ah,,I mean i use RTV. Make sure both surfaces are clean. Apply a very narrow bead around the the outer edge. I guess I didn't think about rtv. Thank you! Link to comment Share on other sites More sharing options...
SW86 Posted February 12, 2013 Share Posted February 12, 2013 ive used this roll of gasket material my dad gave me. he probably got it from an auto parts store id imagine. works good and you can make all sorts of gaskets out of it Link to comment Share on other sites More sharing options...
Biotex Posted February 12, 2013 Share Posted February 12, 2013 I wouldn't use RTV on my engine. If one tiny spec breaks loose, it can lodge inside an oil gallery and block flow. If you decide this is the only way, then please use the thinnest film you can. Link to comment Share on other sites More sharing options...
Keyav8r Posted February 12, 2013 Share Posted February 12, 2013 If the two surfaces - oil pump and block - are flat (no bumps or nicks) and clean you may not need a gasket. If you think you need something, paint on a coat of high tack gasket shellac. Link to comment Share on other sites More sharing options...
Biotex Posted February 12, 2013 Share Posted February 12, 2013 If the two surfaces - oil pump and block - are flat (no bumps or nicks) and clean you may not need a gasket. If you think you need something, paint on a coat of high tack gasket shellac. Sometimes gaskets weren't used from the factory. I've torn down several engines, mostly Fords that didn't have any. Edit: I just looked in my factory parts book for my TJ, and there is a part number listed for that gasket. 12 J3172332 1 ER0 GASKET, Oil Pump Maybe it would be worth a call to the dealer. Link to comment Share on other sites More sharing options...
HOrnbrod Posted February 12, 2013 Share Posted February 12, 2013 :agree: When I rebuilt my Austrian Rotax motorcycle 500cc engine last year, the cylinder head bolted to the jug with no gasket or sealant, according to the Rotax manual. I had never seen this before, so called a guy out in Cali who does nothing but built up Rotax thumpers for dirt track racing, and he confirmed it. The machined surfaces were so true they didn't need a gasket even with all that compression. These lightweight built engines go for upwards of $4K/ea and can put out over 80 HP. :eek: Not mine though, it's about half that to keep it streetable. Link to comment Share on other sites More sharing options...
Akula69 Posted February 12, 2013 Share Posted February 12, 2013 Autozone (or Autism Zone, as Don calls them), sells gasket material by the sheet. They have both real cork and a paper/edpm mix. I use the paper one with good success. Link to comment Share on other sites More sharing options...
cruiser54 Posted February 12, 2013 Share Posted February 12, 2013 PM me your address and I'll send you one. Link to comment Share on other sites More sharing options...
gogmorgo Posted February 12, 2013 Share Posted February 12, 2013 These lightweight built engines go for upwards of $4K/ea and can put out over 80 HP. :eek: Not mine though, it's about half that. Are you surprised at that much? My FSAE team runs pretty well stock Honda 600cc engines which put out almost that much breathing through a 20mm restrictor. Unrestricted, they run at 115-120, I think. Link to comment Share on other sites More sharing options...
HOrnbrod Posted February 12, 2013 Share Posted February 12, 2013 Are you surprised at that much? My FSAE team runs pretty well stock Honda 600cc engines which put out almost that much breathing through a 20mm restrictor. Unrestricted, they run at 115-120, I think. I guess you are clueless regarding single cylinder dirt track........ Link to comment Share on other sites More sharing options...
gogmorgo Posted February 12, 2013 Share Posted February 12, 2013 I guess you are clueless regarding single cylinder dirt track........ Mm, missed out on the single cylinder. My bad. Yeah, I am pretty clueless... Link to comment Share on other sites More sharing options...
HOrnbrod Posted February 12, 2013 Share Posted February 12, 2013 Mm, missed out on the single cylinder. My bad. Yeah, I am pretty clueless... That's okay, most folks are. That's about the max HP a 500cc limit thumper can put out. The built Honda and Yamaha singles come close but don't last long. Nothing to me sounds as sexy as a built Rotax 4-stroke thumper screaming at full RPM. They sound like nothing else. Link to comment Share on other sites More sharing options...
gogmorgo Posted February 12, 2013 Share Posted February 12, 2013 There are a few other FSAE teams running singles, and while they don't make quite as much power, the weight savings from the lighter engine and less steel in the shorter more compact chassis (usually about 100 lbs or so lighter altogether) mostly make up for it. Our team still runs the four-bangers though, because they're supposedly easier to come by. It's not really my department, though. I'm mostly just involved with the drivetrain after the transmission sprocket. But sorry for the :hijack: Link to comment Share on other sites More sharing options...
comanche1989 Posted February 12, 2013 Author Share Posted February 12, 2013 Thanks for the replys all, I ended up making a templet and cutting one out of some material I had laying around. Hopefully the mj will be on the road soon! Link to comment Share on other sites More sharing options...
