comanche1989
Everything posted by comanche1989
  1. Hi All! After a long hiatus from the group, I have finally gotten my Comanche through highschool, college, early career, ect.. to a place in my life where I have the time, space, and resources needed to actually work on it (beyond keeping it limping along). Shop and Comanche pictures below: I am the worst at taking pictures however I wanted to share some data around the factory front lighting harness. While many people upgrade the headlight harness itself, that still leaves the old plug to the engine harness in place, which is always crusty. Prior to upgrading my headlight harness to the relay set up, I wanted to make sure I had a clean start up front. In order to access and pull the harness out, what I have found easiest is to pull the header. Note that the screws/ bolts/ nuts for the header and molding can be quite rusty. Would suggest soaking with penetrating oil. Pg. 1989-1990 in FSM When you remove this, the wiring harness if installed as is from the factory should come out with it. From here, remove all connections to the lights and remove the wiring harness from the header. Before removing any tape from the harness, I would suggest drawing the outline of the harness on a piece of cardboard so you can match the final shape with your new harness. Finally, to build the new harness, here are the parts I used, as well as shrink tubing, butt connectors, and solder: Item Manufacturer / Brand Part number / Type Full-size turn-signal socket Dorman 85898 Headlamp adapter sockets RED WOLF H4 / 9003 / HB2 female, 2-piece kit Side-marker socket and cable Crown Automotive J5455853 Main disconnect connector N/A 10-pin Deutsch-style connector 16 Gauge GXL Wire N/A Wire The way I built my new harness was simply one wire at a time, tracing, copying, and splicing into the new connectors. However, after making the new harness I also measured and mapped each section of wire. The attached excel spreadsheet shows the measurements, circuit key, as well as the manual references for the wiring diagram. Please note that I did not measure precisely, however the measurements should still work to build off of. 1989_Jeep_Comanche_Front_Lighting_Harness_With_Parts.xlsx Once built, I would suggest using 1/2 cloth wiring harness tape to bundle the wires, using the carboard pattern you made early to keep everything tidy. After that, install, and enjoy a new harness that should last another 36 years :) (Don't mind the crazy mess) I will continue to work through other wiring harnesses on the truck and share additional measurements with the group.
  2. If someone has more knowledge of the inner workings of distributors and why it happened, I would be interested to hear and learn about it!
  3. As far as I understand, it was a mechanical issue causing an electrical issue. The distributor was worn out, causing oscillations effecting both the Cam position sensor ( I know the Jeep can run with it unplugged) and the rotor. I believe once the engine reached a certain rpm, it created an almost death wobble effect, where it oscillated at that certain rpm range. Certainly a strange problem.
  4. An update just incase people have a similar problem and are searching the forum. My distributor itself was bad. Now that the distributor is replaced (as well as nearly every sensor and ignition component) the Comanche is running smooth as can be!
  5. I just went and bought a new MAP and installed it. No change at all in issues, still behaving the same.
  6. When I unplugged the TPS, it idled fine but when I pressed the gas it would stall.
  7. MAP vacuum source is the closest nipple on the H.O. Intake. I’m fairly certain the location is not an issue, as I have put 10,000 or so miles on the engine since I put it in. Should I go ahead and spring the money for a new MAP? I hate throwing parts at a problem. The voltage swings up as the butterfly is opened.
  8. EGR was deleted when I when to a H.O. motor. I have done most of the renix tips. I will however double check all wires. They are fairly new. How would I set .83 for a closed throttle position when I can not get the TPS to clock any more? Adjust the idle set screw? I will be buying a new MAP sensor come payday to swap in.
  9. Just took another look at my truck. Found about 2 ohms of resistance between back-probed TPS and negative battery terminal. Re-cleaned the dipstick ground thoroughly and that reduced resistance to the point where my cheap multimeter is not reading any. This brought my voltage on the TPS when adjusting up to .81 v. My voltage I need to be able to adjust to is .83v. Is that much of a difference negligible, or will it cause my issue? I can not clock the TPS any more. Line between manifold and MAP is in good condition. Is the MAP sensor responsible for fuel/air mixture along with the 02 sensor? If I remember correctly backfiring means that the mix is too lean.
  10. Catalytic converter was gutted by PO. H.O. throttle body. I will check MAP vacuum line in a few minutes. I will keep everyone updated.
  11. It is an 89 TPS with the HO throttle body. Adapted using the method in the link.
  12. Thanks for the replies. My TPS voltage from back-probing was 4.87. From what I understand this is within a reasonable limit. I have not adjusted the Idle Set Screw, however the butterfly opens and closes no problem. Is there a procedure for testing the MAP sensor? I don't recall seeing one. When it comes to the CPS, I have not had any issues when no start at all. However, I will test it when I have a chance. To me it seems like a fuel issue, due to the backfiring and popping I hear at the problem RPM range.
  13. Hi Everyone, Recently I have been having hesitation issues with my truck. It is a 1989 Pioneer with a rebuilt '93 HO motor swapped in. However, it is still using all renix sensors. My issues began about a month ago, after I accelerated quickly from a stoplight. When I slowed back down, I noticed that when slowly accelerating between 1500 and 2300 RPM my engine would hesitate and backfire. If I accelerated quickly, this was not an issue. I suspected that the TPS was having issues after reading online, so I cleaned the throttle body and tried to adjust the TPS. I could not rotate the sensor enough to get it to my required voltage, which was .83 volts. I then bought a new TPS and am still having the same issue of being unable to get it to the required voltage. I have also cleaned the dipstick ground and crimped new eyes on. Would this cause my rough slow acceleration? Why can I not clock the TPS enough to get to the required voltage? Also, I attempted to get on the highway the other day and the engine stalled out once I got to about 60 mph. If anyone has any ideas about what could be causing this issue, I would appreciate it. I am near wits end with this truck.
  14. http://www.northerntool.com/shop/tools/product_200626118_200626118?cm_mmc=Google-pla-_-Welding-_-Plastic%20Welding-_-44468&ci_src=17588969&ci_sku=44468&ci_src=17588969&ci_sku=44468&gclid=CMjJ5JKmmL4CFU4aOgoddXwAXA
  15. here's my pocket dump. I always carry my Leatherman Wingman, its cheap, stainless, fairly strong and has a good 25 year warranty. I don't worry about beating it up, because it wasn't hundreds of dollars. Of course I carry my wallet, and my keys. My carabiner is made out of AISI 316 surgical stainless steel. It's good until around 70 pounds, which means it can be used to hang fairly heavy things if I need it to. I also carry my Schrade knife. Like the Wingman, this knife is well made, but affordable. Holds an edge fairly well, and I don't worry about beating on it. It too is stainless steel. Also I usually carry a cheap pen, which isn't pictured.
  16. Do you still hear the lifter/valvetrain clatter from your engine? I just rebuilt my 4.0, and everything is perfect other than the clatter I can hear at about 1400 rpm at slow speeds....
  17. Thanks for the replys everyone, looks like I'll be sticking to the diesel oil!
  18. I'm not sure that I want synthetic this early in the engines life. If I were to run a synthetic, I would run amsoil zrod because I already have it
  19. Hi everyone, I recently rebuilt a 1992 jeep cherokee engine and threw it in my 1989 Comanche. After the initial break in I changed the oil and filter, then after the next hour of use I changed the oil and filter again. Now I am reaching the 500 mile point. With all the other oil changes I ran wix filters and Rotella T 10w-30. Should I stick with the diesel oil because of its high zddp and zinc additives, or should I switch to a regular oil like valvoline, havoline..... ect? Another option would be to throw amsoil z-rod oil in, because it is very high in zddp. (~1440 ppm) Suggestions and/or criticism would be appreciated! Thanks, Sam
  20. I've seen that happen. The sound of fiberglass crunching and grinding on cement has to be one of the worse noises I've ever heard.
  21. At the marina I work at, one of the dockhands forgot to chock the trailer of one of our boats we rent. It was windy that night, and the boat was on a slight decline. Well at some point in the night, the boat started to roll. It rolled about 20 feet, then fell off of a 15 foot seawall into the basin of the marina. I came in the next morning, and this is what I found. Always chock your trailers!!!!
  22. I know that this is a warm start for you Canadians, but down here this is one of the coldest days of the year. :dunno: I figured I'd make this video just for fun!
  23. Hi all, a combination of boredom and curiosity resulted in this cold start video. So i figured, why not share my boredom with everyone else!
