Oh Block Warmer.... Oh Block Warmer
Zebvance
oh block warmer...oh block warmer
what are you doing here?
This is Texas,
Don't you know that there is one season here?
Its called Hot! I would never plug you in because you are 25 years old and would probably give me a arson charge with the local PD...
I know this Frankenstein, money pit, rust bucket of a mj came from the maple leaf land many many moons ago, hbut my questions are.....
Should I dare to plug you in for $#!&s and giggles?
How do you only have 100k miles?
Why do you have a 1992 transfer-case?
why do you have a 2001 Cherokee dana 30?
What year is your rear Cherokee dana 35 out of? ( I need to change your brakes)
Did you come with bucket seats?
Did you really begin as a 2wd?
What tramadic episode have you been in to have bondo on ALL FOUR corners of you?
Why is there a E -Brake center console when I have a Floor E brake? ( that doesn't even work...)
Why does your 4x4 light not work?
Why do I always feel like I just got tetanus when I'm working on you?
Why are you lifted 4.5 inches in the front and 9 inches in the back???!?!?!?!!?! YOU LOOK STUPID!
Why is your roof dented, oil pan dented by you upper control arm mount, and trans cooling lines kinked like you have bee rolled over or something?
Why do you have to have your gauges in OIL BARS, KPH, CELSIUS? ( thank goodness for a iPhone conversion apps....)
Why do you have the door-less mod done to you but I cannot pull your doors off still?
Well that's half of my frustration out for the world to see..... If only I had one more beer it would be twice as long....
Love yours truly....
THE PENNY SNIFFER
Unless the cord's shorting, you're unlikely to start a fire with the block heater, as it will only ever increase coolant temperature by about 25°C (45°F), and it typically takes a good eight hours to do that much. Assuming the thing works, you'll likely hear a low hiss after you plug it in, like a really quiet electric kettle. That's about it.
Unless your speedo's very different from mine, it likely also reads in mph, no? Also, mine's marked up to 115mph, unlike the good ol' 85 you got down south. As for the rest of the dash, 100°C is boiling. But I've got no clue what the oil pressure gauge means, either... I just watch where it normally sits and hope "normal" really is normal... :dunno:
As for everything else wrong with it, I'm going to blame the idiotic defector who likely brought it down there for that. Didn't he know you're supposed to bring the rust-free Texas trucks this direction, and not take the incredibly rare rust-free Canadian trucks down there? :nuts:
the gauges..
mm... guess they musta changed them going to '91... mine:
Or else a different speedometer was used in the gauge set with the tach...
I suppose you could always draw yourself an overlay that converts them, and carefully cut and paste?
Oil pressure gauge - one bar = 14.7 PSI (atmospheric pressure). So, if it normally sits around 3 on the gauge, you have approximately 45 PSI oil pressure. You can Google a metric conversion chart or calculator for pressure, temperature, kph/ mph, etc.
Huh, well, let's see what I can answer.
You have a 86 and earlier Canadian gauge cluster. Without even knowing the year of that truck, I know it didn't come with it. It's also the most undesirable cluster, unless you're really bad at forgetting to get gas.
It most likely has Cherokee bucket seats and center console... Hence the ebrake in the console thing.
I bet it did start as a 2wd, it would explain the odd combination of parts... It's also likely why the 4wd light does not work, as the earlier ones used a vacuum switch to actuate it, then it just went to a normal old switch that was actuated by the shift rail in the tcase. Does the D35 have a rubber fill plug by chance?
How'd they do the door mod? Cut hinges, or knock the pins out and weld in bolts?
87 still used the same cluster. I believe they changed in 88, then again in 91 for the electronic speedometer and fuel sender.
Sorry, what?
A properly fitting block heater will seal just as well as a freeze plug. If it's not leaking, it's best to leave it alone. Do you know how many 30+ year old cars there are up here running around with an original factory block heater? I can't quote exact figures, but it's going to be a huge majority...
Oh, yeah, the over the counter ones aren't worth much... One of Motor Trend's Roadkill vids on youtube had a car they were planning on taking from the sourth west to Alaska... figured they needed a block heater, so they got a cheapy. And then went through at least three of them. And they didn't get anywhere close to Alaska. (Maybe CO?)
But since his is a Canadian model, I'd assume it's got a stocker on it.
I'm referring to the cheap over the shelf types. I've had them leak before and just mention it as a precaution. If its not needed a freeze plug would be better.
&nbspThere's decent over the shelf ones... Actually, I don't know anywhere that sells cheap ones up here.&nbspI had one blow apart due to corrosion... And that's it. The ones that corroded had been in there for a while (15+ years). Never had issues with any of the rest of them. I put silicone grease on the o-ring when I install them (DC-4), route the wire appropriately, and enjoy having a vehicle that actually might start.
The 88 and newer ones use red markings and a different connection for the speedometer cable than the 87 and older ones that use blue icons (and blue km/h numbers on the US ones). The 87 and older ones also have a tick for every 1 mph whereas the 88 and newer one have one tick for every 2.5 mph.
Both styles are available with gauges and with dummy lights. I think the newer ones with gauges automatically had a tach, but the older ones with gauges could be had with or without a tach.
Older one with gauges AND tach can be difficult to find. With gauges but no tach is quite common, and I should have one somewhere, but all I can find right now are two dummy light ones.
