I really hate to go here, but maybe some folks will offer some guidance; so here goes.
I'm pulling my hair out trying to find well-informed opinions (and hopefully pics) on daily driven mj/xj with 33" - 35" tires with different wheel options.
Before you answer:
I hope to daily drive it (100+ mile daily commute)
I plan on a SOA and home-built longarms (6" or so)
Looking at a 4:1 transfer case kit (so shallow gears can be used)
A stock 4.0 will be in use (until the instant I can afford a stroker)
I have an AX-15
A dedicated set of beadlocks with some real bias-ply tires will be set aside for off road use
*I currently run 32x11.50 BFG A/T KO and love them; but they're too small and I may need better treadwear*
SO:
-load range options (read: don't want some stiff E ply tire)
-visual appeal with cut fenders and 6" lift (can't be too dinky looking)
-reasonable "all-terrain" capability (NO mud tires)
-reasonable treadwear
-low to moderate noise
What's a guy to do?!
i would go with a mastercraft Coarser at they have a really good road life and still do decently out on the trail for a at i had them on one of my Cherokees and hod over 50k on them and they still had a decent amount of tread
Bfg a/t is hard to beat. The hankook dynapro a/t's are good, so are the Yokohama geolander at/s. My next set of tires will be procomps extreme a/t.
If you're driving 100 miles a day then I'd forget this idea. Your gas mileage WILL turn to poop and you will regret it. There's a massive difference between 32" to 33" to 35" tires. I'd just stick with what you have. Spend your money on good quality selectable lockers instead. OX, Ecteds, or ARB.
*sigh*
This is the little voice of restraint and reason in my head.
So the shallow / ricer question I have to ask myself is:
Will the truck look dumb with 33x10.50 15 and my cut fenders... hard to answer I know.
I have been running 3.73 gears with a 4:1 transfer case with 31 inch Cooper STT's for seven years. I commute about 50 miles a day and the bad of this mud tire is that it might last 35,000 miles if balanced and rotated properly. So like you despite how incredible of a mud, snow, ice, and rain tire the STT has been, in a few months I am switching to another tire which happens to be the Cooper AT3 which boasts as a 55,000 mile tire. I have a lift that netted me a little over 4 inches, and I would be lucky to get 32's under it without rubbing. I can't imagine 33-35 inch tire with just 6 inches of lift without major trimming.
http://us.coopertire...rt-Utility.aspx
