boardmanMJ Posted November 5, 2012 Share Posted November 5, 2012 anybody remember awhile back ago about the comapany that was making the bed sides and cab corners for the comanche? i am in desperate need of cab corners for my new truck and i can't seem to recall the website or how much they were. Josh Link to comment Share on other sites More sharing options...
Guest Posted November 5, 2012 Share Posted November 5, 2012 If memory serves, the beside patch panels were a custom deal; made by an outsider to the site. There were a few on here who may have gotten some panels from him; or maybe the whole thing never came around to being made. Someone may chime in with the link to the thread about it. :dunno: Dunno if anyone was ever making cab corners though. :hmm: Link to comment Share on other sites More sharing options...
ftpiercecracker1 Posted November 5, 2012 Share Posted November 5, 2012 Here is a helpful little write up on repairing your cab corner and rocker panel. The person who did this was lucky enough to get a perfect factory match rocker panel from Mopar while they were still avaiable. As far as i know there are no suppliers providing direct fit rocker panels any more, much less cab corners. I would suggest you find a scrapped MJ in a junk yard and cut out its cab corners, this is probably going to be your only option, unless you want to make your own. . .. .. like i did. Link to comment Share on other sites More sharing options...
Jeepman Posted November 5, 2012 Share Posted November 5, 2012 Perfect fit Stamped Rockers are available aftermarket but nothing yet for Cab corners... Link to comment Share on other sites More sharing options...
sinkrun Posted November 5, 2012 Share Posted November 5, 2012 Rockers from A Cherokee will fit you just have to cut them down. There is a company called CTC that make actual Comanche rockers but the fit is TERRIBLE but the can be made to work. They sell on ebay thats were I bought mine around 50.00 for both. ZM jeeps are the ones with bed sides there was a thread on here but with the new club I think its gone. Two door Cherokee patch panels will work to repair a wheel arch depending on how bad yours the height is different but opening is the same again ebay is the cheapest on these also. CTC says cab corners are in the works but not here yet you will have to fab your own. Link to comment Share on other sites More sharing options...
ftpiercecracker1 Posted November 6, 2012 Share Posted November 6, 2012 Perfect fit Stamped Rockers are available aftermarket but nothing yet for Cab corners... got a link? and are you sure they arent just ment to cover up your old rocker? Because like the guy said after you there are some companies that do make rocker panels, but its takes a crap ton of work to get them to work right. Link to comment Share on other sites More sharing options...
Jeepman Posted November 6, 2012 Share Posted November 6, 2012 No They are proper Stamped Rockers and I know first hand because I used them on my MJ after buying the $#!&ty Cheap ones... They are XJ/MJ stamped Rocker Panels for 2 or 4 Door that you just cut off the access length and if you have ever used the old crap rockers you will be happy to pay the extra money for the stamped rockers... As for a Link... Sorry I do not have one as I order them from my distributor so anyone that needs them should just ask for late model XJ because they are the same thing and they also Have stamped Inner rockers available too... Link to comment Share on other sites More sharing options...
flint54 Posted November 6, 2012 Share Posted November 6, 2012 Desert Truck &Auto (a wrecking yard) in Coachella, CA has a 1990 MJ with perfect cab corners. Last month I had them cut the rear wheel wells off for me. If you call them they can fax you a sheet on which you will mark what/where you want cut. They will cut and send. http://www.deserttruck.com/ Link to comment Share on other sites More sharing options...
ftpiercecracker1 Posted November 6, 2012 Share Posted November 6, 2012 As for a Link... Sorry I do not have one as I order them from my distributor so anyone that needs them should just ask for late model XJ because they are the same thing and they also Have stamped Inner rockers available too... Wish i had known about them a week ago. You say distributor, but what distributor? Is the actual name of the company Perfect Fit? Link to comment Share on other sites More sharing options...
huck731 Posted November 6, 2012 Share Posted November 6, 2012 Rockers from A Cherokee will fit you just have to cut them down. There is a company called CTC that make actual Comanche rockers but the fit is TERRIBLE but the can be made to work. They sell on ebay thats were I bought mine around 50.00 for both. ZM jeeps are the ones with bed sides there was a thread on here but with the new club I think its gone. Two door Cherokee patch panels will work to repair a wheel arch depending on how bad yours the height is different but opening is the same again ebay is the cheapest on these also. CTC says cab corners are in the works but not here yet you will have to fab your own. for those that will actually look for this company on ebay it is called classis 2 currentfabrication Link to comment Share on other sites More sharing options...
ftpiercecracker1 Posted November 7, 2012 Share Posted November 7, 2012 classis 2 current fabrication This is the company that has rockers, but are a really REALLY poor fit, every other company i have been to carry the exact same one. I am still waiting to hear from Jeepman as to where he found his rockers. He is the only person i have heard of finding exact fit replacement rockers, except for the guy in the link of my very first post above. Link to comment Share on other sites More sharing options...
91 Comanche4x4 Posted June 21, 2013 Share Posted June 21, 2013 I was lucky enough to score an OEM DS cab corner & rocker online 2 years ago. Very rare find. Only thing I can suggest is to use the cherokee rocker/backer. Try to salvage the back end of you existing Comanche rocker/backer and splice em together. Dead Comanches with decent body metal will be your best bet for everything behind the back edge of the doors. Link to comment Share on other sites More sharing options...
Ochie Posted May 19, 2018 Share Posted May 19, 2018 Sorry to resurrect an old thread. I'm a proud new Comanche owner and I need help sourcing some sheet metal patch panels. I need to replace the rockers and one cab corner. I've searched the forum without much luck on finding WHO makes the best fitting rockers??? Also WHERE can I buy passenger cab corner repair panel??? I've read a lot of informative threads and look forward to being a part of the community. Thanks. Link to comment Share on other sites More sharing options...
87MJTIM Posted May 20, 2018 Share Posted May 20, 2018 You can try Z&M Jeeps. They sell body panels. I picked up a driver's side rocker panel at a Jeep show in York PA. http://stores.zmjeeps.com/rockers-quarters-bed/ I do not recommend the bedside panels. They are not stamped for the flares Link to comment Share on other sites More sharing options...
Ochie Posted May 21, 2018 Share Posted May 21, 2018 Thanks. Is this the right ones?http://stores.zmjeeps.com/rocker-panel-2-door-lh-j-truck-fsj/http://stores.zmjeeps.com/rocker-panel-2-door-rh-j-truck-fsj/ I had read that the fit on many of these were not very good, but the thread was several years old. I'm hoping someone can give current recommendations on the best fitting. Bar anybody else inputting, these will be what I buy. Thanks Link to comment Share on other sites More sharing options...
DirtyComanche Posted May 21, 2018 Share Posted May 21, 2018 1 hour ago, Ochie said: Thanks. Is this the right ones?http://stores.zmjeeps.com/rocker-panel-2-door-lh-j-truck-fsj/http://stores.zmjeeps.com/rocker-panel-2-door-rh-j-truck-fsj/ I had read that the fit on many of these were not very good, but the thread was several years old. I'm hoping someone can give current recommendations on the best fitting. Bar anybody else inputting, these will be what I buy. Thanks No, those are fullsize Jeep truck rockers. J10, J20, Gladiator, etc. They don't list a Comanche option. As said you could try calling him, he might be able to get them, but I doubt it would be any good. Link to comment Share on other sites More sharing options...
87MJTIM Posted May 21, 2018 Share Posted May 21, 2018 He doesn't list MJ specific parts on the store site. He has brought some MJ parts to the York PA Jeep show. Link to comment Share on other sites More sharing options...
Ochie Posted May 21, 2018 Share Posted May 21, 2018 OK appreciate the info. I'm really new to the Jeep scene and don't know the model designations yet. Thanks for saving me from a mistake. Link to comment Share on other sites More sharing options...
Mark Posted April 24, 2019 Share Posted April 24, 2019 http://parts.criswellchrysler.com this website seems to have just about anything and everything for a comanche some of the stuff is pretty pricy but if you can't find it anywhere else it's a good place to go Link to comment Share on other sites More sharing options...
