Would my 89 MJ have this buzzer and if yes where would it be located and whats it called so I can get one. As I get older I forget things much more often.
It's called a chime module and is located next to the fuse panel. There are two varieties, the blue case and the black case. The blue case has the headlamp warning; the black case does not. Plentiful at the junkyards or I'll send the part number if you want to buy one.
um, not to highjack, buuuuut my 90 has auto turn off headlamps. If I turn the truck off with the headlights on and THEN push the switch in they will stay on for about 2 or 3 min and automatically shut off.
but IIRC i have never heard a buzzer for my headlights, but i have heard one for my seatbelt.
Different module - the headlight delay is controlled by the Head Lamp Sentinel module. Has nothing to do with the chime module.
AH, i see.
Even though, it still suprised me the first time i discovered it. I was like "What? No way, headlight delay on a 90 JEEP! Awesome. 8) "
That's the first POS that goes to the trash of anything I drive.
Thank you for sharing that.
Don -do you have the PN for the black box? Assume Cherokees have them too and they will work on a 88 Pioneer? BTW - ROLL TIDE!
Yep - they be rollin'.
Blue: 56001076
Black: 56001077
