So, i replaced my valve cover gasket a few weeks ago, and i overtorqued the bolts, cracking the cover by the bolts on one side. Its leaking all my new oil out and burning off..
Anybody have any ideas as to fixing it?
Can it be welded or does anybody have one laying around? Local JY's don't have any 2.5's or the valve cover itself. New is $78 according to one of them.
Metal?
How did you 'over torque'?
What gasket?
Pics?
I 'snug' all pan and cover bolts........never 'torque'.
I don't use rubber gaskets.
I know the plastic covers use shoulder bolts and there is no way to damage the cover by torquing the bolts down as long as you use the correct gasket material.
Metal? Yeah, it's plastic... idk wth i was thinking...
How did you 'over torque? Maybe "over tightened" is the better word? Cracked by the bolts on the driverside.
What gasket? A felpro rubber style, with some black RTV lining both sides.
Shoulder bolts are only used with RTV formed in place gasket .If you use a pre-formed gasket , do not use shoulder bolts . 1/4"x20 flange head works fine . Could be a good time to change over to Aluminum valve cover :wrench:
I suggest to go to the junkyard and find a 2.5L aluminum valve cover.. I had the same problem you are, switched over and is good as new.
  • 9 months later...
I had the same problem with my plastic valve cover but just by snugging the bolts it still cracked the valve cover...I've been looking for an aluminum cover for months before I found one...I just recently saw another at the junkyard....if I pick it up today....I wouldn't mind picking it up for you for the price of the cover plus ship....
Walt
Look on ebay for a YJ 2.5L valve cover.. Found mine and it works perfect just had to get some bolts and washers and I was good. Good luck.
