tmanhollister Posted March 23, 2012 Posted March 23, 2012 so, I'm back. regretted selling my 89 for quite awhile and found this locally and jumped on it. plan on doing gears/shafts and steering soon. some specs: 1991 5 speed 4.0ho d30/d44 stock rustys l.a. kit. 7'-8' springs fiberglass front fenders and bedsides. bumpers f+r. little stuff here and there. here's a couple pics. the zj is also mine. Image Not Found Image Not Found and the one i sold to m1a1tankertom( Image Not Found
89Comanche4x4 Posted March 23, 2012 Posted March 23, 2012 dudddddddde that new one is sick love the fenders and bedsides i want :eek: :bowdown:
Gjeep Posted March 24, 2012 Posted March 24, 2012 Did you buy that truck in Gilroy off Church Street? Looks exactly like the one I'd see behind car wash in alley.
tmanhollister Posted March 24, 2012 Author Posted March 24, 2012 Did you buy that truck in Gilroy off Church Street? Looks exactly like the one I'd see behind car wash in alley. thats the one. checked out the axles and found it has 3.07 gears....with 35s... ha. thats gotta change soon.
tmanhollister Posted April 6, 2012 Author Posted April 6, 2012 the rear ujoint blew the caps off itself the other day. not sure why. when i was looking at the yoke, there was nothing on it to keep the ujoint centered. usually there are little raised spots that hold the caps from moving? the only thing hold the ujoint to the yoke are the 2 straps, and its pretty impossible to get it centered and stay there. any ideas?
HOrnbrod Posted April 8, 2012 Posted April 8, 2012 the rear ujoint blew the caps off itself the other day. not sure why. when i was looking at the yoke, there was nothing on it to keep the ujoint centered. usually there are little raised spots that hold the caps from moving? the only thing hold the ujoint to the yoke are the 2 straps, and its pretty impossible to get it centered and stay there. any ideas? Yes, there should be. There are raised tabs on the pinion yoke u-joint cup to hold them in. You have a D44, right? I'd pick up and install a new u-bolt pinion yoke and seal like this one on Ebay HERE. Since you have a D44 there's no need to worry about the pinion crush sleeve because the D44 uses shims. Just install the new yoke and re-torque to specs.
tmanhollister Posted April 8, 2012 Author Posted April 8, 2012 the rear ujoint blew the caps off itself the other day. not sure why. when i was looking at the yoke, there was nothing on it to keep the ujoint centered. usually there are little raised spots that hold the caps from moving? the only thing hold the ujoint to the yoke are the 2 straps, and its pretty impossible to get it centered and stay there. any ideas? Yes, there should be. There are raised tabs on the pinion yoke u-joint cup to hold them in. You have a D44, right? I'd pick up and install a new u-bolt pinion yoke and seal like this one on Ebay HERE. Since you have a D44 there's no need to worry about the pinion crush sleeve because the D44 uses shims. Just install the new yoke and re-torque to specs. thanks for the link/info. i will be picking one of those up next week
tmanhollister Posted April 15, 2012 Author Posted April 15, 2012 got the new yoke on, including ujoint. no more vibrations. also installed a mechanical temp gauge as the one in my cluster doesnt work. stays around 190-200 so I'm happy.
tmanhollister Posted April 22, 2012 Author Posted April 22, 2012 getting 4.88s put in the d44 monday. looking for a non-disconnect hp30 to swap in the front then gear. I'm just going to rebuild the factory limited slip with aggressive clutches. for the time being i put my 33s from the zj on it. also ordered the 97-01 front end. should be here in a week. when that arrives ill being doing the body work and picking out a color. pics coming soon!
tmanhollister Posted April 29, 2012 Author Posted April 29, 2012 new front clip. 130 shipped. Image Not Found got this done. Image Not Found Image Not Found Image Not Found paint coming soon
tmanhollister Posted May 7, 2012 Author Posted May 7, 2012 got some tube doors mounted up. still havent geared the d30 yet. ordering browndog mm's soon. Image Not Found Image Not Found Image Not Found
tmanhollister Posted May 19, 2012 Author Posted May 19, 2012 did the first diff fliud change and threw on a ruffstuff diff cover. that thing is thick! also waiting for some brown dog motor mounts to come in, they were back ordered 10 days. paint and pics coming soon
tmanhollister Posted June 1, 2012 Author Posted June 1, 2012 picked up a set of axles out of a 79 bronco. hp44 30 spline and 9' 31 spline 65-67 wms. going to be using the raduis arms converted to johnny joints at the ends. cleaning them up this weekend and figuring out what need to be done.
Gibby Posted August 19, 2012 Posted August 19, 2012 How do you like the flares? Do they hold up well to abuse? I'm looking at buying a set if nobody has really heard anything bad about them.
tmanhollister Posted November 10, 2012 Author Posted November 10, 2012 I haven't really beat on them, but they are pretty thick and I would think they could hold up well.
tmanhollister Posted November 10, 2012 Author Posted November 10, 2012 Got some work done. Motor mounts in, new tranny fluid, paint, d30'abs model with 4.88s, raised sway bar mounts, LCD skids...little stuff here and there. Putting off the full widths for a different rig. Let me know what you think! Image Not Found Image Not Found Now with some 36" tsl's. Image Not Found
neohic Posted November 11, 2012 Posted November 11, 2012 :agree: That's a great example of a different twist on body panels! I'd love to have an excuse to put a set on an MJ but I've got plans for all my trucks. Guess that means I'll need to get another someday... I think it would be a great alternative for our rusty trucks of the north. Yours looks great!
tmanhollister Posted November 12, 2012 Author Posted November 12, 2012 Thanks guys. Yeah it's definitely a different look for the mj.
tmanhollister Posted November 18, 2012 Author Posted November 18, 2012 Took her out today. First time on the 36's and 488s. Everything worked pretty well. Definitely need to upgrade the steering as I can see that puny tierod bending pretty easily. Here's some pictures. Image Not Found Image Not Found Image Not Found Image Not Found
tmanhollister Posted November 21, 2012 Author Posted November 21, 2012 Image Not Found New carpet, bedline floors, speakers, recovered seats... Coming soon.
88whitemanche Posted November 21, 2012 Posted November 21, 2012 Man that trucks looks super sweet! Ever thought about cutting the fenders to match the header panel?
